Ok, i have this ALTEC LANSING Powered Subwoofer
Ok, i have this ALTEC LANSING Powered Subwoofer PSW10 and i pluged my ipod in through the cord in one of the pictures and it doesnt work. But another problem it that the original sub had been completely trashed so i replaced it. I domt think i did anything wrong so i took it apart and found another problem. Not sure what to make of any of this. PLEASE HELP
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
CLUEPATEL
  • 138 Answers
SOURCE: AVS500 altec lansing computer speaker system powered subwoofer
Its due to your speaker power supply failure or switch! get them checked your speakers will be ready!
Posted on Dec 08, 2007
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
Altec lansing acs33
the subwoofer plugs into the wall on a 110 volt outlet. then use mastervolume control.. RANDY
Apr 28, 2014 | Altec Lansing Multimedia Computer Speakers
Just want to know what it would cost to buy the altec lansing speaker moder acs 45.
It will cost you about $75 for the Altec Lansing ACS45.2 Powered Subwoofer Speaker, which I am assuming is what you're talking about, since the only thing that comes up under ACS45.2 is that. It should cost you about $75, although you will generally only find used ones because Altec Lansing no longer sells them.
Apr 10, 2011 | Computers & Internet
Ah i have altec lansing acs 45.1.the problem is i dont know how to wiring.can u pls help me.ynx
ok first plug run a1/8 two sided head phone jack[male] from the computer to sub woofer you should have two imput jacks makes no differance ok the left sat speaker has a 6 pin din plug round looking plug insert into subwoofer and then plugac cord in the wall you should be good togo "note right sat speaker is attached to the left good luck
Nov 16, 2010 | Altec Lansing ACS 45.1 Computer Speakers
Hi i have a altec lansing T612 which my two yr old son damaged by pulling at my ipod whilst docked and has damaged the connector, my ipod works fine in my car but the dock doesnt work, can i buy a...
Ok if the dock connector has broken itself then you wont get much use from it. Im sorry but i can't help you on this today. But i will look for some answer's and stay in touch.
Thank's
Mar 16, 2010 | Altec Lansing T612 - High End Speaker...
A pin on my power cord broke off. What can I do?
You can solder it back on (ensure the power cord is not plugged into the wall)
Someone else has had a similair problem here:
http://www.fixya.com/support/t405246-finding_replacement_power_supply_altec
Aug 22, 2009 | Altec Lansing M602 Powered Audio System...
No sound coming from ACS 48 Altec Lansing speakers
Hi janros123 - I don't know if this will help - I have a subwoofer ACS48 that needs satellite speakers (they are blown). Want to buy my subwoofer or sell your satellites? I will buy your broken subwoofer, too...thanks, and good luck! Greg illdooyoo at gmail dot com
May 16, 2009 | Audio Players & Recorders
Lost cord!
I have them for sale AC Adapter For Altec Lansing speakers inMotion iM600.Price is $15.95 Plus $6.95 shipping . send me your email and address to this email address.princemonac0@yahoo.com and I will invoice you through paypal. Thanks
Mar 25, 2009 | Altec Lansing Inmotion-IM600...
Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
May 15, 2008 | Altec Lansing Multimedia Computer Speakers
Nov 02, 2007 | Altec Lansing 621 Computer Speakers
146 people viewed this question
 Grubhead
Grubhead
