Question about Garden
What size belt does the honda xr2600 rototiller use
I need a replacement belt for the roto tiller
  • 10865 Answers
SOURCE: rear tiller won't go into gear.belt needs replacing
find your model number from the list on this link and click to get your manual
http://www.managemyhome.com/mmh/owner_manuals/search?query=Craftsman+rear+tine+tiller
Posted on May 20, 2009
SOURCE: pull rope broken on craftsman rototiller
cluch calbe
Posted on May 23, 2009
wadembly
  • 513 Answers
SOURCE: Can I get the specs for belt 727 A?
DID THE BELT SHRED OR what happened if it is still decent mesure width on top is it a v-shape belt or flat & last thing is cut it & measure it if its still decent that will give you the specs or if theres other # on belt & who its made by
Posted on Jun 05, 2009
  • 22 Answers
SOURCE: How do I remove the wheels on a 1985 Troy Built Horse Rototiller?
Horse wheels are held on with a single roll pin. Pound out the roll pin and pray.....that the rims aren't rusted to the shaft. If the rims are rusted to the shaft, you have two choices. You can either put the new tires or tubes on the rim with the rim on the shaft...or you can work at getting the rims off the shaft. If you put tubes in, be sure the rim is free of sharp edges.....or you'll be sorry.
To get the rims off if they're rusted on, I've used a variety of techniques over the years. The most effective is to weld a nut on the spot where you removed the end caps. Use a nut that's the same thread as your bearing puller. Then use the bolt from your bearing puller to put pressure on the end of the shaft, pulling the rim off. A torch helps, but be careful or you'll be putting new seals in too.
Posted on Jun 14, 2009
SOURCE: sears rear tine rototiller 32-29978 manual
Here is a link to a JC Penneys tiller that uses the same Briggs&Stratton engine 190402-1835-02 as my Sears 32-29978 8HP tiller.
http://dl.owneriq.net/a/af17c4af-5fe8-2b94-0155-02ad54e688e6.pdf
Posted on Mar 09, 2013
Have this rototiller without a manual and need to know about fuel
the mixture is usually on the machine somewhere--if not go the honda website and look up info for that model
May 08, 2010 | Honda 25cc 4-cycle Mini Tiller
White smoke honda mantis rototiller
You're okay the white smoke is the oil burning off the muffler. In time it will stop, just park it somewhere and let it run until it's done. If the problem persists check your air filter and make sure it's not stained with oil, if so you can wash the foam part with soap and water but the paper will need to be replaced. (DO not put foam back on unit until dry.) The oil level should be up to the bottom lip of the dipstick access when the engine is evenly horizontal.
Apr 03, 2010 | Honda 25cc 4-cycle Mini Tiller
Replace belts on Montgomery Ward rear tine rototiller Model number GIL39012B need diagram
Go here and you can download a free manual for your machine.
http://lawnandgarden.manualsonline.com/manuals/mfg/montgomery_ward/tmo39083a.html
Oct 24, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Can I get the specs for belt 727 A? I need to replace this weekend and ARDISAM won't give me a size. Can't afford to overnight. Earthquake Gear Drive 5 HP rototiller. would appreciate help=
Jun 05, 2009 | Ardisam 5.5 Hp Rear Tine Rototiller
Need manual for roto-tiller model#135202 made by MTD
I don't have a manual and I need to know what size belt to purchase. Any help would be nice.
Feb 19, 2009 | Mtd Products Yard Machines 158CC Tiller
I am looking for fender for honda fg100 rototiller?
If It is a Honda FG100 like in the title the part number is 65141-V06-003
If it is a FG110 like in the description the part number will be 63411-V25-000 FENDER, RR. and 65141-V25-000 FENDER, FR.
Nov 24, 2008 | Honda Hmantis Mantis Garden Tiller with...
Roto tiller stopped working
i bought three rototillers an every one stopped working after one use an i took it to a dealer an he said it was the coil . why is your coils going bad ?now it wont start needs a new coil agiian i think you should be responsible seeing i bought three it was under warranty but i didnt get it out in time .i like it when it works but if it s gonna do this i wont buy any more of your tools my emalis dugie54 frontiernrt .net i would **** to hear from you ty bob .
Sep 02, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
