Question about LG Computers & Internet
Warranty check hdd
WORKING BUT NOT READING
  • shabeeb May 08, 2013
    repairing is posible?
    Sergeant:
  • 180 Answers
If u finish download this cd tray to find partition table doctor tray to make "fix boot"http://www.softexia.com/hirens-bootcd.html
Posted on May 07, 2013
Seatools test code 606060d0 hat does it mean
this code usually suggest that this is lba (logical block addressing) issue, i am suspecting your pcb board being at fault or usb port or usb cable or power source. i assume that this is on external hdd?
asking that sort of the question you should provide manufacturer of hdd, internal or external, what wer the symptoms, what is the size of hdd, what o/s you use, this is helping in providing detailed and correct solution. as you supplied only fragmentary data - only generic solution can be provided.
before you do anything else, check your power supply, check your usb cable and check usb port, check all three on another computer as well.
if power supply, usb cable and usb port are ok, and hdd is out of warranty, then i would suggest opening of the case and connecting hdd directly to the computer via sata cable. and internal power supply.
if hdd works correctly, switch to power supply supplied with the casing, if you can read the data, that way you will exclude power supply as culprit, it works...
that will left only and only pcb and usb port/cable.
hope this short info will help you - do not forget to vote...
Mar 02, 2015 | Computers & Internet
Says hdd is not installed
you must be in process of installation of an OS. if the same is coming while installation then you have to check your Hard disk, may be media of the HDD is corrupted. if have some problem that can be fixed but if the media section is damaged you have to changed the HDD (contact vendor if the same is in warranty, normaly HDD have 3 to 5 Year Warranty)
Jul 30, 2011 | Computers & Internet
After pressing powerbutton startup stops with a black screen and text: schrijfleesfout
- this means "disk read error"
- you might have a faulty HDD
- try to restart the system and boot to bios by pressing F2
- check under system information if the HDD is detected
- if it's detected or not detected, try to reset Bios to default by pressing F9 and F10
- upon doing this and still the same error then call acer if the laptop is still under warranty to have them replace the HDD
Jul 13, 2011 | Acer Aspire 3610 Notebook
St3160827as seagate hdd is not detecting in bios , other new seagate hdd is working fine with the same connection(sata cable and power card) I have imp data in that hdd ,pls help me how to get data...
Turn your computer off.
Disconnect the power cord.
Disconnect all other disk-drives and CD/DVD drives, leaving only the "suspect" drive connected.
Restart your computer, and enter BIOS SETUP, and see if the drive is detected, and how it is connected (primary/secondary, master/slave).
Read the model-number and serial-number and manufacture-date on the disk's label,
and access Seagate's web-site, to check the warranty-status of the drive.
If the warranty is valid, Seagate will replace the drive, at minimal cost to you.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 03, 2010 | Seagate (ST3160827AS) 160 GB Hard Drive
I need to check warrenty for 160 gb sata harddisk
Hi Welcome to Fixyah,
For checking of warranty all i know for that is 2yrs warranty or you may visit www.seagate.com for checking the warranty.
Aug 11, 2010 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
Cannot read from the drive. Can this be solved?
If it's recognized when you plug it in, you might have a HDD issue. Was it ever working, did it just stop? Was the external drive ever dropped or hit hard?
Try downloading a diagnostic tool with from your HDD manufacturer, or a reputable one like Seagate, or Western Digital (google :Data Lifeguard Diagnostic for Windows). Hopefully it will at least let you get your data off, but I'd backup and see if you can't get a warranty replacement for the drive, it will likely fail sooner than later.
Nov 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Rdr hxd 995. Says 'no disc'. Can't access hdd.
The E01 error is a hardware error with the drive. I would try a new disk fist to see if it's just having trouble reading the one you're using but if that doesn't work it's most likely a failure in the drive itself and needs to either be sent in for warranty or replaced.
Hope this helps,
Chris
Aug 19, 2009 | Computers & Internet
Bose lifestyle fault code 802 hi there- i have a bose lifestyle 48 and on display it reads format unsupported when i try to listen to cd's gut not on dvd's - in addition i am unable to store music into the...
Unfortunately, an 802 error is bad. That means hard drive (HDD) failure. This can happen to any hard disc drive, and there's no way to predict it and no way to fix it from home.
If you even try to troubleshoot it (reset etc), you could loose more data (music you've already stored to the system). If you try to access 'stored' music- the error will continue. Also, every time you turn the system off, it checks your HDD, and will probably cause the 802 or 801 errors to display again.
The "Format Unsupported" message may be related, but usually temporary. The 802 (and also 801) errors mean irreversible HDD damage so it doesn't matter.
Call Bose tech support immediately.. They can repair it for $165 and give a new 1 year warranty. And if it's already under warranty they will repair for free. In either case they will replace your HDD with a new one, and transfer any salvaged music files from your existing drive to the new drive.
May 31, 2009 | Bose Lifestyle 48 System
Cannot detect external sata hard disk
I would start by swopping the Internal Sata Cables around and check if that solved it.
If not then there's probably a problem with either the E Sata HDD Controller board or Even the HDD or the Sata cable going from the Motherboard to your input E Sata Port.It's a matter of elimination.
So Remove the HDD from the Enclosure and plug it directly into the Motherboard and see if thats picked up.If it is then the HDD is fine.If not, get it replaced and it might still be under warranty.Check with the manufacturer.Continue reading if the HDD is fine.
Then use the Sata Cable from another HDD and connect it straight to to the E Sata Enclosure and see if the Operating System picks it up,Make sure the HDD you removed is plugged back into the enclosure.If that doesn't work then the problem lies with the Enclosure itself and you should get it replaced.
If it does the the problem lies with the cable itself and you should replce that.
Hope this helps you out.
May 08, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Hard Disk Sound
A little noise is normal while the HDD is working. Use the warranty if it is too loud.Extra loud is usally a sign of failing HDD.
Sep 17, 2007 | Toshiba Satellite U205 Notebook
Computers & Internet Logo
69 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
