Question about Sharp LC60LE835U AQUOS Quattron 60" 3D LCD/LED HDTV LC-60LE835U
Vertical lines showing up after being on for awhile
Some time after being powered on with a signal (cable or player), the screen begins getting vertical line blocks. The screen seems like it has 4 horizontal blocks, and each block begins flickering (well, its either messed up for a few seconds or normal for a few) between the normal image and vertical lines. After several seconds (10-15 usually), the screen stops flickering and just has vertical lines. If the TV is powered off for a few minutes and turned back on, the image is fine for abit. Doesn't seem to have a set time before messing up. This problem did occur several months ago one evening, but I powered it off for about 20 hrs, dusted off the externals and back openings and the problem never came up again this week.
    Problem Solver:
  • 9 Answers
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
Posted on Jun 26, 2013
freetek
  • 5568 Answers
SOURCE: green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Posted on Jul 09, 2008
  • 346 Answers
SOURCE: Blue horizontal and vertical lines
poor convergence
Posted on Nov 12, 2008
  • 100 Answers
SOURCE: Horizontal and vertical lines on the screen
i do no know take it back to the shop you got it from
Posted on Jun 04, 2009
tvservice306
  • 458 Answers
SOURCE: black horizontal line, red parallel vertical lines
REPLACED LCD PANEL
Manufacturer Sharp Part Number RF-R1LK420D3LF2 Description 42" WIDE LCD PNL -
Posted on Sep 28, 2009
dave1645
  • 834 Answers
SOURCE: our tv has vertical lines running through a black
this is a heat realted problem with your T-Con board you should have a tech replace it not to expenxsive
Posted on Nov 20, 2009
Vertical green line on right side of tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 03, 2014 | Protron PLTV-32 Television
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
Vertical Lines - Differnt Colors TH-42PHD7WK & TH-42PWD8GS
hi,im a hdtv technician i have encountered already for that kind of trouble.the problem of your lcd is the panel.the panel is defective replace it with a new one lcd panel. (olevia,syntax and kolin lcd thats the brand i assingn.)
Aug 01, 2009 | Panasonic TH-42PHD7WK 42 in. Plasma...
My display is frozen at on. Vertical Lines appear on screen
Try to hold down the off button and restart it, if it still shows the same screen take it for servicing.
Feb 23, 2009 | SanDisk Sansa e260 MP3 Player
Sansa E200 screen stuck scribbly black vertical lines
When it is on, holding the power button in for 5 or more seconds hard resets the device. Give that a try. If not. it's possible it's been bounced one too many times and needs the LCD cable re-connected or the controller is bad for the LCD.
Dec 31, 2008 | SanDisk Sansa e200 MP3 Player
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Samsung TV stopped displaying picture
No picture but sound can mainly be of two problems, most of the times it is caused by a faulty vertical deflection ic, you can diagnose this by slightly increasing the screen voltage by turning the screen control on the LOT, a horizontal line will appear if the vertical ic is shot, and the other problem is the CRT base, but this is less common for shot base won't go off at once, it will show picture faded in the beginning. Now another problem could be the horizontal output transistor, if the tv has a high power sound output, the sound power supply will come from smps itself instead of from LOT, check that too, to confirm this, check if the CRT filament is glowing. Good luck.
Jan 17, 2008 | Televison & Video
Shrinking screen.
hi there, you do have a vertical section problem and at the power supply section problem. do some test, check for some cold solder at the power supply section, test some electrolytic capacitor at the vertical section. ty
Jan 01, 2008 | Televison & Video
Sharp LC60LE835U AQUOS Quattron 60" 3D LCD/LED HDTV LC-60LE835U Logo
269 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
