Question about BenQ PB6210 Multimedia Projector
No Power My projector has no power. Have tried changing the cable.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 51 Answers
The problem may not necessarily be from the cable. It has to either be from the socket you plug it or the internal Power IC inside the projector. If your socket is working fine then you may have to take it to an experienced technical expert who will trouble shoot and diagnose the problem but since you said the projector is not powering, its likely the inbuilt power IC is damaged by maybe a surge in electrical current. Hope this helps... Cheers
Posted on May 06, 2013
My dell xps 1210 laptop wont show image on viewsonic pj588d projector. it works on another laptop but not on xps 1210
Try F1 or Fn and F1 or connect up the projector, power up the projector select VGA input (or whichever input is connected to the laptop) power on the laptop.
Dec 27, 2014 | Dell XPS Computers & Internet
NEC VT470 Multimedia projector
Try to reset the projector. Turn the power off. remove the power supply cable from the main socket. Leave it for 30 min. Turn on again. Before turn on(Make sure) 1.0 power cable install correctly 2.0 Lamp cover install correctly. 3.0 No excessive heat around the projector All this can be refer to the user manual.
Sep 23, 2007 | Nview Z215 10.4" LCD Panel with Video(16.7...
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
I changed my desktop background and now my projector will not display
I would start by cycling this through the f4 option again first. Next I would connect the projector to the computer and then booting up the computer. Next I would disconnect the projector...turn it off, connect the projector again and then power up the projector. Try every combination of sequencing to get the computer and projector to talk to each other. It would not be a bad idea to change out the cable and try a new one as well. If it is a ceiling mounted projector then connect straight to the projector and try that.
Jan 07, 2013 | Hitachi Office Equipment & Supplies
I cannot power up my Sanyo PLV-70 projector. I have changed the power cable but the box is still dead, no sign of any power input.
try another wall outlet if that dosent work try a nother cord, than if it still wont respond it could be a blowed fuse or a bad power bord.
Jun 04, 2011 | Sanyo PLV 70 Multimedia Projector
How do you change the bulb?
Hello :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
Here are the steps that explained in the manual :
Lamp Replacement Procedure:
1. Switch off the power to the projector by pressing the Power/Standby button.
2. Allow the projector to cool down for at least 30 minutes.
3. Disconnect the power cord.
4. Use a screwdriver to remove the screws from the cover.
5. Push up and remove the cover.
6. Remove the 2 screws from the lamp module.
7. Pull out the lamp module.
PLEASE RATE !
Apr 13, 2010 | Optoma EP747 Multimedia Projector
I press the power on and the lamp led not the
Hello :
Try to change the bulb .
Here is how :
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
please rate !
Apr 12, 2010 | ViewSonic PJ458D Multimedia Projector
LCD projector shuts off durning use
u have not mentioned how long u have been using this projector. either the lamp life is low or the circuitry protecting the lamp temperature is defective or even the air intake of the fan is inadequate, a filter is fitted for air flow if this is clogged or blocked, lamp temp will rise and unit shuts down. if lamp indicator is yellow or red it is time to change the lamp. if it is red - lamp is totally out, if u turn on the unit four times without replacing lamp, the unit simply wont turn on. one other possibility is power cable and power connections. check power cable too.
Apr 07, 2010 | Sharp Notevision PG-A10X Multimedia...
No power to projector
Generally when the globe goes end of life and needs replacing the unit will fail to power up. Try another globe if you have one spare.
Sep 10, 2007 | Compaq iPAQ MP2810 Multimedia Projector
BenQ PB6210 Multimedia Projector Logo
82 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
