Question about Garmin StreetPilot c340 GPS Receiver
Garmin C 340 problems
This problem has recently started happening. When hitting "Address", it goes to spell state, but the alphabet page only flashes momentarily then goes to a "list" that has no states on it. Hitting "back" takes you back to the alphabet page, but touching the first letter of the state takes you back to the blank list page. How do I get this thing to take the "state" like it used to do? Russellc
  • Anonymous Nov 29, 2007
    Sometimes when I start to type in the address, the garmin switches back to the state address again. I tried turning the unit off and back on to resolve the problem. Sometimes it works while other times, it does not.
    Frank
  • Anonymous Mar 12, 2014
    Why cant you give a list of 50 states
I had the same problem and finally found the solution. If you go to "map Info" you will see the version of your preloaded Garmin map database. Well, look carefully because there is a box next to it. Apparently, it needs to be checked or "enabled" before you can use it. Once I did that everything started working. Why this isn't done from the factory is a mystery to me. This should be discussed in the quick start guide IMHO.
Posted on Nov 24, 2007
Http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf The numbers for customer service are included in this.
Posted on Aug 18, 2007
SOURCE:
When I try to spell states it goes right to no matches found on the 1st entry
After powering up the unit and selecting address, the unit displays, "In What State is the Address? and Spell State. When I press Spell State, it has No Matches Found. When I press Back and attempt to enter the first letter of any state, the unit displays "No Matches Found".
Sep 17, 2010 | Garmin Nuvi 350 Car GPS Receiver
Reset did not work. Still cannot enter state. When I hit spell state the gps responds no matches found. When I hit back - the alphabet appears but as soon as i hit a letter the GPS responds no matches...
The problem may be because the text language is British English. To be able to enter a state it must be in American English. To change to American English follow the instructions below;
  1. On the 'Main Menu' press the 'Settings' icon.
  2. Select the 'Locale' icon.
  3. Change the 'Text Language' to 'American English'.
  4. The unit will now allow 'States' to be entered.
Aug 05, 2010 | Garmin Nuvi 660 GPS Receiver
When I go to spell a state, the screen goes immediately to the Select State Screen. It will not allow me to spell the state.
When you type a stae it will automatically show the list of states you can scroll down to check if the states is in the list or if the states is not recognize try to check the region make sure your in lower 48 states.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
Unable to enter new address
Please see this link to:
http://www.sharc.net/discus/messages/6/75.html?1235511886
If this resolves your issue, please rate me as Fixya.
Thanks,
- Jim
Mar 01, 2009 | Garmin Nuvi 660 GPS Receiver
Street Pilot c330 GPS won't let me input an address.
Click on tool icon on lower right corner. Touch Map icon. Touch
map Info icon in center of screen. Touch City Navigator North America NT v8 icon so that the box is checked. Then click on back until you reach "Where To?" screen. If "Touch City Nav..." box is not checked, then you cannot input state.
Feb 09, 2009 | Garmin StreetPilot C330 GPS Receiver
Why won't the key pad allow me to type in the address?
click on settings on the right of the screen, then on map, then on map info at the bottom of the screen, and tick the box for city navigator europe NT 2008 and this should get you going, this drove my husband crazy for days and i just stumbled onto it,good luck
Dec 27, 2008 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 won't accept addresses -
I called garmin and they walked me through the solution - select the NA map version under settings and restart.
Oct 02, 2008 | Garmin nuvi 350 GPS Receiver
Cannot select another state on Garmin 660.
1. From the Where To? View Map, Travel Kit page press WHERE TO
2. Press ADDRESS
3. Press SPELL STATE (should be the 2nd blue box on the page & may read SPELL COUNTY)
4. Press the letter K and Kansas + Kentucky will come up; Press the letter T and Tennessee + Texas will come up, etcetera
5. If the information does not automatically appear, hit DONE and the information will appear. For example on my nuvi 660 if I hit the letter “A” nothing happens until I hit DONE.
6. After pressing the single letter for the sate/province in which you are interested, the unit will prompt you to spell the CITY name.
You will then enter the information as it applies.
Nov 30, 2007 | Garmin Nuvi 660 GPS Receiver
StreetPilot c 340 does not allow to enter address
Ok, you've tried a reset, but have you tried a Master Reset? Doing this WILL ERASE ALL OF YOUR FAVORITES, but it may help. Turn the unit off. Press the "On" button with your finger on the bottom right of the screen at the same time. Release the "On" button, but keep pressing the screen until the unit asks if you're sure you want to reset all data. Press "Yes". See if this helps.
Nov 04, 2007 | Garmin StreetPilot c340 GPS Receiver
Where to only provides the state you are in--can't be changed
It sounds as if you have an older software. However newer software, don't press address, but rather press near... at the bottom of the where to page, and select"a different city" or on the where to page select spell, and spell a name that you know appears in the adjacent state, but not yours...
Good Luck, GB_C
If this doesn't work, upgrade your software, and try anew...
Aug 30, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
235 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
