Question about Arris Dct6416 Phase Iii Dvr Digital Cable Receiver Box Dct 6416
Dct6416 keeps plugged into TV but when I turn off TV it keeps immediately turning back on again. any ideas?
LG 50PG20. My TV keeps turning off by itself! We can turn it back on immediately but less than 5 minutes later it does it again. How can I fix this?
This problems it is the causes by the tv power supply board.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 24, 2010 | LG 50PG20 50 in. Plasma HDTV
Stupid tv!
Sounds power supply board is bad in your TV and most probably replacement of all electrolytic capacitors in power supply board will solve the issue.
Take TV to local TV repair shop for repair.
Thanks.
Aug 30, 2009 | Akai LCT3201TD 32 in. LCD Television
OLDER 32" TV WON'T TURN ON/KEEPS TURNING OFF
re solder your tv,if its not works, check the horizontal output transistor
Oct 01, 2008 | Samsung DLP HL-P5663W 56" TV
TV turns on, then immediately off again
hi nel2874
so, you have a television that turns off immediately after you turn it on.
It sound like your power supply on the unit is out. Because I don't know the value of your unit I cannot comment on replacing the unit. But I would recommend that you use our website to find a Flat Panel TV Repairman near you. You may want to call to get an estimate on replacing the power supply before considering replacing the unit.
Jun 22, 2008 | Televison & Video
TV Pops & turns off
There are no tubes; generally the pop happens because of high voltage. It is being shorted out and the pop is either the flyback transformer or the horizontal transistor oscillator. these two are reponsible for creating the high voltage cycle for your television; when either of them or their circuitry is shorted out you hear that "pop" which is the emergency cut off circuitry coming into play to protect the rest of the television.
May 17, 2008 | RCA Televison & Video
AKAI LCT2721AD On/Off Problem
My Philips LCD TV had the same problem. If your Voltage system is 110 AC till 127 AC and no transformator, then it is probably caused by one of the 4 main transistors, which are likely not originalfrom AKAI, but made in Malaysia or closeby there.
My TV works perfectly after 1. Replacing the burned or semi-burend transistors (in the back panel) 2. After repair (=US 60 plug the TV in a outlet from transformator set to 100 V.Good Luck!
Apr 15, 2008 | Akai LCT2721AD 27 in. LCD Television
TV Turns off on its own
Just keep smack'in it around, it works for me. It is the 'protection overload circuit' taking over and shutting the TV set off. This is because it detected a short or near-short circuit somewhere. Most common is high voltage, deflection amplifiers and main power supply. It's pretty much a common fix for an experienced tv repairman. It might set me back in the ballpark of $200 - $300.
Jul 03, 2007 | Sylvania SRT4127P TV
No picture, stuck on Video 1, volume self-adjust to maximum
the tacticle (micro switches)on the front of the main chassis have most likely gotten wet at some time,I suggest replacing them all.
Apr 02, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Arris Dct6416 Phase Iii Dvr Digital Cable Receiver Box Dct 6416 Logo
26 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
