Hi, I have a Toshiba Satellite A665-s6055 laptop. I can start it up but it won't load Windows. It just goes to the Windows load screen, then to a black screen with my cursor. Also, I can't start it in safe mode, or from a previous point when it did work. When loadi safe mode it shows all the files booting and stops while it it loading the drivers. It also will not repair itself. When I select repair it goes to a black screen. Any help would be appreciated. Thanks, Anthony P.S. Do you think it may be the hard drive?
  • 32,281 Answers
The hard drive could be slightly faulty. Try this first.
To repair missing or corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
Posted on May 06, 2013
emmbritech
  • 5 Answers
SOURCE: My Toshiba A205 S4777 won't start up and I can't use the recovery media to fix it.
Try flashing the bios by pulling the chord out attached to the "watch" battery.
Posted on Oct 13, 2008
tat4u
  • 520 Answers
SOURCE: toshiba equium A60 wont boot up.
reinstal os (windows xp)
ur only gonna end up having to do this later anyway
Posted on Jan 14, 2009
  • 38 Answers
SOURCE: acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Posted on Jan 31, 2009
zohail
  • 1223 Answers
SOURCE: 7720 will not boot
off course it is repairable dont worry look try to install OS thru the following procedure to factory default state
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
if it installs the OS ok then fine if not
pls consider changing RAM take out from beneath the laptop open the cover all screws and take out the L shaped panel then u will see the RAM in front with 2 chips one uper and one lower side try to take out both and then re fit only one in the upper slot and then try to install if hangs again , then try the 2nd chip in the first slot and repeat the procedure if it works ok only try both chips one by one if it resolves ur issue and u find the faulty one replace it with new one with sam specs
in the last case if ur system still hangs then my friend ur hard disk is giving u hard time it needs replacement
when a system boots after bios loading all that is trf from Hdisk to RAM and then OS is loaded if one have problem system will hang or freeze try these solutions and then tell me the results
pls go step by step
and pls rate me fixya if i fixed ur problem
kindly let me know abt it and tell me in detail the messages u get and the system behaviour
Posted on Mar 02, 2009
  • 30 Answers
SOURCE: Computer won't boot Windows Vista. Screen goes black with cursor arrow.
In this case you have to do the PC restore . you can do that in dell machines by shutting down the machine and when it is coming back on just HOLD DOWN THE CTRL ket and the START HITTING f11 key in this case you will lose the data which you have the on the c drive but this issue will get resolved .
Else you can try to restart in the safe mode with networking and then go to the system restore and then select the bold dates in which you have idea you system was working fine . selct the date and then do the system restore . In this case you will not lose the data but you will lose the updates which you have done after that date .
in both the cases system will work .
Posted on Mar 25, 2009
Why Toshiba Satellite A665 Laptop won't start?
Have you tried pressing space bar (maybe its in hibernation mode) ?
or try holding power button for a few seconds (10) then turn it back on.
as a last resort you could try take the battery out, disconnect it from the power adapter, hold down the power button for 30 seconds and then place the battery back in and the power adapter and try powering it on?
Aug 26, 2014 | Toshiba Satellite A665-S6088 16 Notebook...
Toshiba a665-s5170 laptop
Your OS is corrupted so you will need to repair or reinstall the os.
Apr 29, 2012 | Toshiba Computers & Internet
Crash blue screen
Toshiba Satellite A665 Have Problem Wen i Am Using Internet Then Its Com Blue Screen And Memory Er-or Coming And Then Go To Restart
Jan 20, 2012 | Toshiba Satellite A665-S6070 Notebook
I need driver software for lab top toshiba satellite a665/s6086
all toshiba satellite A665-s6086 drivers: --->click here<----
and watch the video
May 19, 2011 | Toshiba Satellite A665-S6086 Laptop
How and where to download all drivers for toshiba a665-s6093 after reinstall the os with windows 7 64 bit some of fitur like hot key and etc not working properly....pls need help asap !! thanks
Hi
Go the website of the manufacture, choose your laptop model (
Satellite A665-S6093), and the operating system ( 7-64bit),
and download the software utility for the keyboard
Please tell us your results
Good Luck
May 16, 2011 | Toshiba Satellite A665-S6093 Laptop
Where is the task bar on my toshiba l650 laptop computer
If you're using Windows 7, the task bar is the bar located on the bottom of the screen that has the Windows button, your shortcuts, and the time/network status.
Mar 12, 2011 | Toshiba Satellite A665-S6086 Laptop
How i can download windows 7 original copy for my laptop toshiba satellite a665-s6086 intel core i3
If you have purchased your laptop along with pree install windows ,please follow the beloow link.
http://www.pcrecoverydisks.com/toshiba/toshiba-system-restore-vista/
Choice your brand and OS .
Hope this helps.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Jan 17, 2011 | Toshiba Satellite A665-S6086 Laptop
Computers & Internet Logo
David Payne
David Payne
