Question about LG Wm3470hva Wm3470hva Front Load Washer
Wm3470hva no power
Not getting power past plug
Unplug the washer from the wall wait about 5 minutes, plug it back in to the wall and press the power button. You should see all of the lights on the front come on and start cycling. wait about 2 minutes and you should be ready to start washing.
Posted on May 18, 2015
My new LG front load washer has a deep small scratch in the outside of the plastic door. Should i be concern
Take the reimbursement because the minute scratch is not effecting the performance and you are the only one who is aware of the condition. As for the noise, a bit of One Lube spray on the hinge will take care of that. One Lube is a special oil/silicone application that works on all moving parts that tend to make noise, and it lasts far longer than all other products. Look for it on the internet, or ACE Hardware.
Apr 15, 2014 | LG Wm3470hva Wm3470hva Front Load Washer
When I started my washer wm3470hve for first time after half an hour it started jumping.it was really scary my house was shaking with the noise.
6his can happen when you either overload the washer or you have a low amount of stuff in but it is heavy. would seem 4.0 is the max you can have in the drum at a time. if it persists at this with varying loads. then the shockers have gone weak and need replacing. or the drum has come out off balance. this can because of the bearing or something has dented the drum. somtimes putting shoes in to was can do this type of damaged.
Oct 28, 2013 | LG Wm3470hva Wm3470hva Front Load Washer
Will not boot past XP start up screen
Disconnect power to the computer (unplug it) and then remove the RAM memory sticks, plug them back in, reconnect power to the computer and try another restart, many times this works.
Feb 06, 2012 | HP Media Center m7257c PC Desktop
Cricut expression 2 has no power, will not turn on
Any resolution to this issue? I like stone234 have narrowed it down to the cricut not getting power past the power board. I tested the two prongs that feed the red and black power for the main board and no voltage. Cricut Exp 2. Powered on as soon as I plugged it in. Plugged in usb to computer, I didnt have the software so i searched for it then started downloading it and noticed the screen on the unit was frozen. unplugged it and after plugging it back in it wouldn't power back on.
Nov 05, 2011 | Cricut Expression Cutting Machine
The timer works but gets "stuck" when it comes to the ON time. it will continue this cycle if i force it to click past the ON time; but when it comes around the next day it sticks again.
You posted under malibu power pack.
When clock motor gets weak, it can no longer push timer dial past the trip point switch.
Right now the clock motor is overheating and will stop functioning.
This timer does not have replacement clock motor, but comes with 5-year limited warranty.
Buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
For complete troubleshoot, trippers, manuals and warranty information:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 14, 2011 | Malibu ML900TW 900 watt Power Pack Timer...
Projector won't power on. Plug it is and all I get
the lamp is past 2000 hours and needs replacing and the timer needs resetting.
Aug 17, 2009 | Canon LV-S2 Multimedia Projector
New GARMIN 660 Won't get past the Intro screen
Problem solved: I got through to Tech Support. They suggested a 'hard reset', which solved the problem: Put you finger on the lower right screen while you power up and it will do a hard reset---and it will get past the "loading maps" screen, where it had been stuck.
Dec 25, 2007 | Garmin Nuvi 660 GPS Receiver
LG Wm3470hva Wm3470hva Front Load Washer Logo
238 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
