Question about Crosley CR19CD CD Player
How to load a cd - Crosley CR19CD CD Player
CD drawer will not open
Hello
There is a loading belt that fastened with a loading motor pulley, which gets the CD tray in and out. If this belt or the loading motro has trouble, the CD tray wont cole out, or load in properly. You have to check and find out which part is faulty. In normal cases, replacing the loading belt will rectify this problem. OK.
Dec 25, 2011 | Crosley 4-in-1 Entertainer CD Shelf System
Cd is stuck in cd player
Failure of the CD loading section, it can be due to fault in the loading drive , failure of power to the loading section or if there is a mechanical fault like jamming, failed gears or drive.
Also if the CD is faulty , broken or warped it can be stuck within.
You need to remove the covers and the tops lid to get access. the loading motor section must be accessed so that a manual turning will allow the cd to come out.
Check the loading section drive IC, the motor and the processor input feed voltage to the IC.
This will give you an idea of the fault.
Aug 09, 2011 | Bose Audio Players & Recorders
My NAD cd player CD slot goes in and then opens...it does not retain the CD inside to play...
Hello
This fault is due to loose tray loading belt or weak loading motor. You just change the loading belt with same type. Never use a belt more than tight. Use the same size. If belt changing does not help, replace the loading motor. OK.
Nov 21, 2010 | NAD C542 CD Player
Hello, How can I load 6 cds into the audio system of my 2007 honda accord? I do not have the owners manual, kindly assist. Thanks.
Look on the face of the radio for the Load button. Turn on the ignition and then change it to CD by pressing the CD button. Stick a CD in the slot and then press Load. Wait for the CD to load. Now stick another CD in the slot and press Load. keep doing this until all 6 are loaded.
Aug 17, 2010 | 2007 Honda Accord Sedan
2004 honda accord CD player not working
I have the same problem I bought one with the same problem. Does any one have a solution.
Help
Dec 02, 2008 | 2004 Honda Accord
Hard time loading cd
hi does it try and load ie does it feel like the cd is slipping?
it could just be the rollers are dirty, thease pull the cd into the mech.
Mark
Blue ICE
Feb 28, 2008 | Sony CDX-M610 CD Player
Loading tray will not load or close-reopens immediately
Sounds like the tray position switch has gone wrong.
Sep 30, 2007 | Onkyo DX-C340 CD Player
Crosley CR19CD CD Player Logo
23 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
