Question about Toshiba TN61X81 61" Rear Projection Television
Toshiba TN61X81 HD Cinema Series Sound Problem
First I want to say that I have never had any problems with my tv. ... Until now. I purchased a Playstation 3... Everything worked fine for a couple days ... Now all of a sudden the sound on my TV is completely messed up. There is sound.. however it is only pushing out the BASS. There is no MIDS or HIGHS. I tried EVERY input on the TV and its the same thing for all of them. I tried unplugging the TV and plugging it back in. Still nothing. Any help is appreciated. Jonathon
    Problem Solver:
  • 18 Answers
What type of connection did you use for your playstation 3 to your tv....
Posted on Aug 10, 2007
SOURCE:
Toshiba tv cinema series problem doing the software upgrade when the upgrade starts to download after a couple of minutes it gives me a error msg saying it couldnt download. I am using the download via...
Check the settings on the wifi portion of the television. If you have a cat5 connection try using that to connnect to internet. If you still have the problem, activate the factory reset process on the television and then use setup again. Then try the update.
Mar 02, 2014 | Toshiba 55WX800U Cinema Series 55 class...
Toshiba tv cinema series hd speakers
Check its speaker/s first. If found OK, check and replace damaged component/s at its audio output section circuit. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 31, 2013 | Televison & Video
I have a 65 inch toshiba cinema series it's says
if a large rear projection set that just says HD, it likely is HD ready which means it needs a set top box connected to the Colorstream input marked 1080 on the rear of the set--It will only likely be 1080i and not p---owner manual would confirm this.
May 28, 2012 | Toshiba Televison & Video
I have a 55 in Toshiba Cinema Series HD the colors are out of alignment so I have three pictures stacked behind each other. Is there an adjustment or repiar
I have a Cinama Series HD Toshiba and it has a Problem with the picture theres red letters behind the white , it like the colors are stretched, theres red eye above the real eyes and same with the teeth area, what could be the problem?
Nov 09, 2010 | Toshiba TN61X81 61" Rear Projection...
My Toshiba cinema series HD separates the red & blue color.
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 18, 2010 | Toshiba 57H82 57" Rear Projection...
I am repairing my sister TV {Toshiba TN61X81}. The original was no picture and with sound. Upon troubleshooting the vertical deflection, ihad move the screen control for all 3 crts to see the horinzontal...
The easiest way I have found to set the screen controls is to tune into an old black and white show, turn the green up until you see retrace then slowly turn it down until it just dissapears then adjust the blue and red for a true black and white picture.
Sep 08, 2009 | Toshiba TN61X81 61" Rear Projection...
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Toshiba cinema series convergence problem
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Convergence adjustment procedure to many brands of projection TVs are given in detail.
Jul 10, 2017 | Toshiba CX36F84 TV
Open Questions:
Toshiba TN61X81 61" Rear Projection Television Logo
186 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
