Question about Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp tv troubleshooting
No sounds
    Top Expert:
  • Sharp Master
  • 75,581 Answers
Check its speaker first. If it is found OK, connect the set to any external amplifier If no sound is produced by external amplifier too, the main digital board has the fault. If there is sound by external amp, and not with TVs internal speaker, the fault is with its audio output stage circuit. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong. http://electronicshelponline.blogspot.com/
Posted on May 06, 2013
Sharp TV LC-40LE550U - No picture or audio on any inputs, replaced Power Board with no luck
The main board is the problem. That board is the source of audio to the speakers and it controls when the LED driver is powered.
Feb 12, 2018 | Sharp Televison & Video
Where can I find a service manual for SHARP LC40LE550U?
Try updating the firmware before repair /replace of parts.
I am sure you would have tried troubleshoot shown on page 38 of the user manual.
http://www.manualslib.com/manual/751149/Sharp-Lc-40le550u.html?page=40 Sharp LC 40LE550U Operation Manual Appendix Troubleshooting
Mar 02, 2016 | Sharp Televison & Video
My 32 inch Sharp TV power light is blinking with no sound and no picture. It was on and just turned itself off and now the power light is blinking. What can I do?
Could have been a power surge. There should be a reset button on the tv somewhere. You did not mention model number. Look in your manual and troubleshooting section. Look for info to reset. As well, you should definitely add a surge protector to the mix. That is between your electric outlet and the tv plug in
Jan 12, 2015 | Sharp Televison & Video
Sharp aquos troubleshooting
i have a sharp aquos model lc-62c42u. when i power it on works great for about a minute. after that my screen has blue fuzzie lines with the picture still in the background. Ive already tried the INIT reset along with the K. is there any type of schematic I'm able to find on troubleshooting the power supply board.?
Jan 07, 2014 | Televison & Video
Troubleshooting
using the TV remote access the menu then go to sound settings and turn the speakers back on
Nov 10, 2013 | Sharp LC46LE810UN 46 in. LCD TV
How can I connect a 5.1 sound system to a sharp
Sharp televisions don't work like you need them to when connecting them to a 5.1 sound system. You can connect them with a fiber optic cable from their digital audio out to the sound system's digital audio in BUT when you turn everything on no sound comes out of the sound system. So you start checking connections and troubleshooting, call Sharp, and maybe even call the sound system manufacturer. You may get a customer service representative knowledgeable enough to explain to you that Sharp televisions were designed without center channel capability. This means that the only use for the digital audio out is to get sound from your sound system when watching tv channels when your Sharp television is connected to your rooftop antenna only or directly to basic digital cable with no cable box or satellite tv receiver. Yes I just stated that you only connect the sound system to the Sharp television when you are watching over the air broadcasts or basic digital cable without a cable box.
People say "but that doesn't make any sense." But it is true. Sometimes you will get lucky and connect a Sharp television to the sound system with the fiber optic cable and get sound out of one of the devices you've connected to the Sharp television with an hdmi cable. You will then be directed by the customer service rep to connect all your devices to the sound system and connect them all to the television as well OR connect all your devices to the sound system with hdmi cables and connect the sound system to the television with one hdmi cable.
Jul 19, 2011 | Sharp LC40E77U LCD TV
Sharp 37" tv flat pannel
It is blinking because it sensing shorted circuits that are drawing too much current so it goes into safety shutdown mode, the shorts will more likely to be in the inverter board which draws the most power from the power supply module, try disconnecting the power cables to the inverter board to see if the TV will come on without the pictures but still has sound.
Learn more how to Troubleshoot LCD TV here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Apr 01, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp AQUOS LC-32D44U 32 in. LCD TV Logo
51 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
