Question about Car Audio & Video
Jensen jcd 3010 no LED
Red power button is lit up but power button will not turn on radio. New radio but has not been turned on in 2years. Any suggestions please
Jexx
  • 148 Answers
SOURCE: I need help! jensen 3610
Hmm, did you hook up the red ignition wire?
Posted on Nov 05, 2006
Benimur
  • 6966 Answers
SOURCE: won't power up
Hi, The owners manual says that if the red light is flashing, it is an indicator that it is ready to be turned on (use remote or onboard on button); flashing red & green - too high temperature inside, the unit is overheated. Check and clean the air filters; If the red light is steady, abnormal condition and you have to call for service. A copy of your manual is available at http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_xb25_20_sb20.pdf Hope this be of some help. Pls post again how things turn up. good luck and kind regards.
Posted on Jul 31, 2007
SOURCE: Unit will not turn on from standby
I had a similar problem and it was caused by my cable box being in scart 1 as soon as I changed over to scart 2 the problems went away,
Posted on Jul 24, 2008
SOURCE: Won't Turn on, standby LED lit
HI,
I am having the same problem, any solution? Thanks! -Steve
Posted on Aug 31, 2008
SOURCE: Westinghouse W33001 Will not power on
I had that happen to my tv and took it to be repaired and it was the power pack where it attaches to the tv it just like snaps on and will arch and burn the power pack and it wont power on so the repair guy charged me $89 parts and labor he put one in but sodered it so it will not draw moisture and arch and it works great now....
Posted on Oct 26, 2008
XHDR6435 radio was working fine yesterday, now it will not turn on. the red led behind the faceplate flashed when i turn on the car, and cds will load and eject but the radio will not power up. i habe...
I just Spoke to tech support. This is what they said:
1. Key in the on position and the red power button lit, remove the face plate.
2. On the left bottom side press and hold the reset button, with a pen, for 10 seconds and let go. The red led on the right should flash.
3. Reinstall the face plate.
4. Push power. The unit should come back on.
Mine worked, and i was about to tear it out and return it. So try this first or even call tech support for Dual 1-866-382-5476.
Jun 14, 2011 | Dual Electronics XHDR6435
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
Does the small jensen power button light stay on all the time?I installed it on a boat, the dim blue light its lit all the time!
Yes it does. I installed the same unit on my boat and ran an inline switch to the battery to turn it off so as to not wear the battery down.
Jul 16, 2009 | Jensen CD-3010 X CD Player
Scource button is red but unit doesn't seam to have power?
your red ignition wire is not getting 12 volts. that is why the cd player will not turn on. to test your voltage either buy a voltage tester or take it some where to have them hook it up and test it
Feb 24, 2009 | Jensen VM9510 Car DVD Player
Led light constantly stays on remote rcr4358
First off, put in brand new batteries. Not just batteries that are kind of new, i mean BRAND SPANKING NEW batteries right out of the packet.
If you still have a problem:
~hold down the DVD-VCR button-> the red led will stay lit.
~holding down the DVD-VCR button press the number 2 --> the red led will turn off
~Release the DVD-VCR button--> the red led blinks 4 times and turns off.
Hope that helps!
Rate me!
Feb 11, 2009 | RCA Universal Remote Control
TV WILL NOT TURN ON
The power supply, and or one of the circuit board is defective. The set will require shop service.
Jerry G.
Jul 26, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Programming the jensen jr400 universal remote
1) Turn on the Proton TV;
2) Press the "TV" button on the JR400;
3) After releasing the button, the red LED indicator should blink twice;
4) Press and hold the SETUP button until the LED blinks twice;
5) Release;
6) Enter 9-9-1 on the numeric pad. Red LED blinks twice;
7) Press POWER;
8) If TV doesn't turn off, press TV again;
9) Repeat #4, #5, #6, and #7. If TV doesn't turn off, go back to #4, until the TV responds.
10) Go on to the next device, i.e. DVD, VCR, etc.
Feb 17, 2008 | Jensen JR400 Remote Control
Oct 20, 2006 | Jensen CD3610 CD Player
Car Audio & Video Logo
35 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
