Question about Hayward 100k Btu Propane Gas Pool Heater H100idp1
Gas valve not opening and letting propane through. I have tested all the temp switches and air and water pressure switchs using the by pass method. Not 100% sure its the gas valve or the ignition mod. Its getting spark, fan is on, gas valve just isnt opening, Help?
    Top Expert:
  • Hayward Master
  • 5,726 Answers
If voltage to gas valve then replace valve
Posted on Mar 19, 2016
  • 61 Answers
SOURCE: Hayward Spa Heater ignites for 2 seconds and shuts off.
Sounds like this is a flame sensor issue. It is not detecting the flame.
Posted on Apr 04, 2009
john224
  • 1378 Answers
SOURCE: Hayward heater not working
You'll never get enough gas from a 20 pound tank. Even 100# tanks struggle to evaporate enough gas to keep up with that heater.
In the mean time, what is the output pressure on your regulator?
Posted on Jun 15, 2009
  • 12 Answers
SOURCE: hayward h250ed1 heater wont stay lit
Try cleaning your filter if dirty there will not be enough flow to llet heater fire. If filters clean you can try jumping the pressure switch.
Posted on Jun 25, 2009
  • 64 Answers
SOURCE: Hayward pool heater H100ID keeps blowing GFI
First, I don't see any heaters in my parts wired thru a GFCI. Why did you resolder inputs on board. Usually, those are not repairs that are acceptable. If the pins have shorted, then you need to replace the board. Could be a problem with the ignitor, but this might be one that you will need to call a pro in for. Did you install the heater yourself???
Posted on May 20, 2010
  • 760 Answers
SOURCE: replacement for the pressure switch
www.haywardnet.com You can order parts here as well as download a complete manual with parts list.
Posted on Aug 01, 2010
Is a 650 delta gas valve for natural gas be used with lp
no.
propane burns much hotter than natural gas, and has higher pressure
gas valve and burner and orifice must be changed to switch between natural gas and propane
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Most manufacturers do not support converting gas on heater.
Gene
Sep 13, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Air energy electric pool heater shows low pressure, low temperature and will not turn on
low pressure will either be gas or water. technician with a manometer can check gas inlet and manifold pressure. ensure adequate water flow from pump. pressure switches generally close at 2psi. you can jump the pressure switch if you think its faulty, or use ohm meter and check continuity of pressure switch
Oct 03, 2013 | Pentair MAXITHERM 333K BTU PROPANE GAS...
Pool heater
If you have bubbles, you have a suction leak. That means the pump is pulling air into the system. Sometimes it's just the basket o-ring under the pump lid needs replacing. If the pump has run hot (without water) for a while, it may have caused shrinkage at the inlet to the pump. Unless it is underground, suction leaks are fairly easy and inexpensive to fix. Heaters will not work properly with air in the system.
Jun 23, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Heater takes a long time to fire up.
There is a flow switch if that's not working. same problem needs to be tested Gas valve solinoid could cause this Igniter could cause this problem Gas pressure regulator wrong pressure should be about 2.7KPA LPG Gas valve should be set to about 2.6 KPA LPG
Mar 28, 2013 | Rheem M206A 206K BTU Pool and Spa Propane...
Porter-Cable compressor does not cut-off and pressure relief valve opens.
bad pressure switch or pressure switch port may be plugged up or could be wired wrong
Feb 26, 2012 | Air Tools & Compressors
My whirlpool washer stops and the water tap closed light comes on, plus on the time remaining FH comes on
the hot water tap has to be on aswell because it picks up the outside temperature and if its too cold it will ask for a squirt of hot water because the water has to be at a certain temp to react with the detergents properly just this model that does it
Jan 05, 2011 | Washing Machines
Have an error code GVP
You didn't indicate what model heater you have, but here are some of the fault codes you might see. Could it have been GVO? You can download a manual for your exact model at www.raypak.com
BD1 Board failure
EEP Microprocessor error
FAN Blower pressure failure
FFL Flame sensing when pilot and gas
valves are closed
GVC Gas valve closed
GVO Gas valve open
HL1 High limit switch #1 open
HL2 High limit switch #2 open
IGN Ignition failure
ILO Ignition lockout - Propane units only
PRS Water pressure switch open
ROL Heat roll-out safety switch open
SNS Sensor failure, Water temp. below 36°F
or above 110°F
VNT Vent switch open
Aug 03, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
My refilled 60 # propane tank leaked and then stopped flowing.
Rick, if the tank is normally plumbed for a horizontal position, and you have it standing vertically, then you are feeding liquid propane to your pilot light, hence the frosted hose etc., and a tendency for the pilot light to go out as it has too rich of a fuel to burn. There should be no vent to allow air in as propane is pressurized, and only attains zero pressure at 40 below zero farenheit. The valve you speak of should have been the liquid vent valve which is used during filling only, and is closed during any other use. Your supply valve should be in the wide open position. The pressure relief valve is only operational when the tank has been overfilled or overheated. You should have a pressure regulator between the tank and the appliance you are trying operate. Hope this helped. Marvin
Jan 04, 2010 | Bosch AquaStar 125FXKIT-LP 125FX Liquid...
Get an fh error after the washing cycle but once paused and restr. cycle it completes teh cycle what could be the cause
FH_ This will occur when No water is detected entering the machine or The pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
• If there is water in the unit:
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub
and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
and Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power.
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Replace failed component.(Which will be the CCU, if the pressure switch and hose are operational. Follow the procedure below to confirm optimal pressure switch functions)
The water level switch(aka pressure switch), is responsible for regulating the water fill level in this situation. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
I would advise to Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If there is water present, the switch must be replaced.
The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. It will be necessary to test each of the three possible pairs. replace the switch if it fails the continuity test.
Nov 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean when it flashes FH on my washer
OR
Nov 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hayward 100k Btu Propane Gas Pool Heater H100idp1 Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
