Question about Garden
Castlegarden 13.5/102 drive belt - Garden
I have a castlegarden ride on one side off deck is not mowing what would be wrong
could be the blade is loose or already came off. the belt may be loose.
Sep 30, 2017 | Garden
Castlegarden ride on lawnmower. Where's the carbon?
CARBON????we have no idea what you MEAN OR WHAT you want
Jun 14, 2015 | Garden
How to take out bearings out of housing on castlegarden 17,5/102 deck
Hard to say without model numbers but from what I seen about them it looks as if you have to knock it out from the underside of the deck pushing it thru the top. Use another bolt to put in blade hole so you don't ruin regular one. Hit it with a hammer or press it out.
Aug 03, 2014 | Briggs & Stratton Briggs Stratton...
Flymo coil pack
What is the question do you need one? They have a Tecumseh engine so getting a coil shoulnt be to hard I bet one off a blown up Toro snow blower would work.If you want any info let me know . I used to have a couple of Flymos
Apr 11, 2014 | OEM Replacement Parts Lawn Mower Spindle...
Castlegarden TCR 102 mover wont get into gear
Hydrostatic or geared transaxle??
Mar 28, 2014 | Garden
I have a 2005 xj 160 hd 15.5 hp castlegarden ride on.The full bag alert has stopped working, I have changed the sensor but still no go.What else could be wrong
call factory service and ask. phone number on sticker on machine and in owners manual. I assume that you have some kind of ride on lawnmower. also, no one ever thinks of reading the owners manual troubleshooting guide. of course before you can read it,first you have to find the owner's manual. You can download a pdf owners manual from the manufacturers website.
Oct 02, 2013 | Garden
Replacement blade for castelgarden C390 lawnmower
What Geographic location please?
UK:
http://www.ebay.co.uk/itm/Mountfield-Castel-Garden-EL390-R-C390-K390-Mower-blade-/280561700508
The blades on most sites are listed under Mountfield / Castel / Lawn King
There are 41cm and 37cm blades listed as fitting this mower. Seems odd that there is a 4 cm difference for the same mower.
As best I can tell this takes a 15 inch blade PN: 81004117/1 (
http://www.gardenhirespares.co.uk/product_list/81 See 15 inch blade
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | OEM Replacement Parts Lawn Mower Blade...
How do i remove a belt from a 2001 hyundai xg300 car
Removal & Installation
  1. Raise and support the vehicle.
  2. Remove the engine splash shield.
  3. Rotate the drive belt tensioner clockwise to release the drive belt tension.
  4. Remove the drive belt from the alternator.
  5. Slowly release the drive belt tensioner.
  6. Remove the drive belt from the accessory drive pulleys.
To install:
  1. Install the drive belt to the accessory drive pulley.
  2. Rotate the drive belt tensioner clockwise.
  3. Install the drive belt to the alternator.
  4. Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
  6. Install the engine splash shield.
  7. Lower the vehicle.
Accessory drive belt routing—1.5L engine
Accessory drive belt routing—2.0L engines
Accessory drive belt routing—2.4L engines
Accessory drive belt routing—2.5L and 2.7L engines
Accessory drive belt routing—3.0L and 3.5L engine
Oct 17, 2009 | 2001 Hyundai XG300
How do I change the timing belt on a 2003 Tiburon
2003 Hyundai Tiburon 2.7L MFI DOHC 6cyl
Inspection
Inspect the drive belt for signs of glazing or cracking. A glazed belt will be perfectly smooth from slippage, while a good belt will have a slight texture of fabric visible. Cracks will usually start at the inner edge of the belt and run outward. All worn or damaged drive belts should be replaced immediately.
To install:
Fig. Accessory drive belt routing-3.0L and 3.5L engine
Fig. Accessory drive belt routing-2.5L and 2.7L engines
Fig. Accessory drive belt routing-2.4L engines
Fig. Accessory drive belt routing-2.0L engines
Fig. Accessory drive belt routing-1.5L engine
Fig. Accessory drive belt routing-3.0L engine
Fig. Accessory drive belt routing-2.5L engines
Fig. Accessory drive belt routing-1.8L and 2.0L engines
I hope help you with this (remember rated this help) Good luck.
Sep 15, 2009 | Hyundai Tiburon Cars & Trucks
Cant find 97 ford taurus serpentine belt diagram
Drive Belt Replacement ani_caut.gif WARNING: IF EQUIPPED, DO NOT ALLOW DRIVE BELT TENSIONER (6B209) TO SNAP BACK AS DAMAGE TO DRIVE BELT TENSIONER OR PERSONAL INJURY COULD RESULT.
NOTE: Minor cracks in the V-grooved portion of the serpentine drive belt (8620) are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
NOTE: Conditions requiring drive belt replacement are excessive wear, rib chunk-out, severe glazing, frayed cords or other conditions. Replace any drive belt exhibiting any of these conditions.
NOTE: When installing drive belt on pulley, make sure that all V-grooves make proper contact with pulleys.
Drive Belt, Serpentine—Except SHO
Removal
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP FROM DRIVE BELT TENSIONER OR PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise on 3.0L (2V) and 3.0L (2V) FF, rotate the drive belt tensioner counter clockwise on 3.0L (4V) to remove drive belt from pulleys. Make sure spring keeper engages into slot.
    Drive Belt Tensioner—3.0L (4V)
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner).
  1. Rotate drive belt tensioner as described under the removal procedure and install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys. Make sure spring keeper releases or improper belt tension will occur.
    Pulley, Routing—Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
    Item Part Number Description 1 10300 Generator 2 6C348 Idler Pulley 3 3A674 Power Steering Pump 4 19703 A/C Compressor 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 8501 Water Pump 8 8620 Drive Belt
    Pulley, Routing—Accessory Drive Belt 3.0L (4V)
    Item Part Number Description 1 3A674 Power Steering Pump 2 8501 Water Pump 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10300 Generator
3.4L SHO Engine
Removal
  1. Remove the right front wheel and tire assembly. For additional information, refer to Section 04-04.
  1. Remove the inner fender splash shield.
  1. Remove the alternator shield.
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE WRENCH DOES NOT SLIP FROMDRIVE BELT TENSIONER OR POSSIBLE PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 3/8 inch ratchet on the lifting lug, rotate drive belt tensioner counterclockwise (upward) and engage spring keeper. Remove drive belt from drive belt tensioner.
  1. Lower vehicle.
  1. Remove drive belt.
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner ).
  1. Raise vehicle on hoist.
  1. Rotate drive belt tensioner , as described under Removal procedure and install drive belt over drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys. Make sure the spring keeper is released or improper belt tension will occur.
  1. Install the alternator shield.
  1. Install the inner fender splash shield.
  1. Install the wheel and tire assembly. For additional information, refer to Section 04-04.
    Pulley Routing—Accessory Drive Belt, 3.4L SHO
    Item Part Number Description 1 3A733 Power Steering Pump Pulley 2 6B217 (RH) Idler Pulley 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10346 Generator 8 6B217 (LH) Idler Pulley 9 6B217 (Center) Idler Pulley
Drive Belt, Water Pump
Removal
  1. NOTE: If removal of the water pump drive pulley is required, refer to Section 03-03.
    Rotate drive belt tensioner clockwise by hand and remove drive belt from drive belt tensioner .
  1. Remove drive belt from water pump drive pulley and water pump pulley.
Installation
  1. Position drive belt onto water pump drive pulley and water pump pulley.
  1. Rotate drive belt tensioner clockwise by hand and install drive belt over top of drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys.
    Pulley Routing—Water Pump Drive Belt
    Item Part Number Description 1 6B209 Drive Belt Tensioner 2 6A312 Crankshaft Pulley 3 8501 Water Pump 4 8620 Drive Belt
Jun 01, 2009 | 1997 Ford Taurus
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
