Bose av18 dvd player won't eject dvd. Saying opening but won't. How can I open it or reset
SOURCE: Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Posted on Jan 28, 2007
Siliconchip
  • 52 Answers
SOURCE: bose 321 cd/dvd tray stuck closed
Please kindly check if this is d model of your 321
Posted on Jan 03, 2008
  • 4 Answers
SOURCE: bose 321 DVD System
Remve the power-plug from power socket of your house. Leave unpowered for 2 mins, then connect and power-on. Lets wait for display ''Bose -3-2-1' off. Then push eject.
Posted on Jan 13, 2008
SOURCE: CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Posted on Nov 02, 2008
    haghead
    SOURCE: Fault Ecplipse car DVD
    well i have one of the same player and i have the DVD software but its the only one i have and I'm in Jamaica.my email address is bylescornelius@yahoo.com.
    Posted on Apr 24, 2009
    BOSE LIFESTYLE 38 DVD PLAYER WON'T OPEN TO EJECT THE DVD
    The DVD could be stuck inside the player or the drive may have failed.
    Sep 08, 2014 | Bose Lifestyle 38 System
    Bose 321 II dvd drawer won't open, fixes here & elsewhere not working. I put in a recorded dvd. It tried to read it, & never gave me the not supported msg as I started trying to eject it...
    Hi Donna,
    Please do be frustated.
    Your lovely Bose has problem with its mechanism that cause load / unload totally out of order. If you hear some noise while you turn on the bose or when you hit some buttons, it is telling us the motor still work. Now we need to check the broken gears ( or other mechanism linkage).
    If you able assemble this Bose, go ahead to find and fix it mehanism ( you may need some parts replacement.
    Note : Be carefully with its laser lens while power on ( avoid direct contact to your eyes).
    Best luck,
    Jay
    Sep 26, 2011 | Bose 3 2 1 GS Series II DVD Home...
    I can not eject a disc from the disc player. I've heard this is a common problem. Thanks. Curt Pasawicz
    Hi curt730,
    You're right, this is a known issue for years with Bose Lifestyle. You may try these steps to resolve the issue:
    Note: You will need a flashlight and a small screwdriver.
    1. First, disconnect the base unit from the system.
    2. Turn the base unit upside down and find the access hole embossed with "Manual magazine release" on the CD player side.
    3. Then, using the flashlight, look inside the base unit at those access holes and find the fine spring and locate where it fastens to the sheet metal of the CD player.
    4. The moment you find the spring you should see that it connects to the CD player chassis at the forward end and a piece of sheet metal that is on top (actually underneath when the base unit is right-wide up) of the CD player chassis at the rear end. This is the manual release mechanism.
    5. Finally using the small screwdriver, push the release mechanism rearward to release the CD magazine from the player. The magazine should pop out.
    If the magazine is not released, then the CD that is still in the player has not been slid back fully into the magazine. In this case you'll need to plug the base unit back into power and hope that the CD is retracted, allowing you to push the release mechanism rearward. If not then you'll have to open the base unit to access the CD player.
    Hope this helps.
    Thank you for using FixYa.
    Jun 08, 2011 | Bose Lifestyle 28 System
    Watching dvd, it began to skip, tried fast forwarding, then took dvd out and wiped it ,put back in and now won't eject won't open or closeCan't get dvd out
    try unplugging the power for 30 seconds and plug it back in and power up then hit eject, if that does not go to the players manufacturers website and search for how to reset (your model #) dvd player in the troubleshooting section, each player is "hard reset" differently, most of the time doing a hard reset will allow you to eject a disc that is not jammed, hope this helps.
    Aug 13, 2009 | Bose Lifestyle 28 System
    When I press the Eject Button on the Bose 321 DVD Player the tray does not open up. I can hear the sound as if trying to open
    normal issues with cd/dvd trays - gear/rubber of the tray transport worn out.
    manytimes it helps if you always keep a cd/dvd in the tray (don't keep the tray empty)
    it may also help if you can keep the bose 321 vertical.
    May 30, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
    Open/close tray disc stuck bose Lifestyle 48
    Problem:
    I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
    Solution:
    Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
    Feb 17, 2009 | Bose Lifestyle 48 System
    CD stuck in disk tray of (original) BOSE 321
    NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
    Nov 23, 2008 | Bose 3·2·1 II System
    DVD is stuck in Bose lifestlye 48 media player
    We had a power surge during a thunderstorm that dimmed our lights, and after that the CD opened as normal.
    A friend suggested that I pull the power connector, press the open/close button and hold it down as I reconnected the power connector. The power surge beat me to that, so I don't know if it works. It was more than "Tech Support" could offer however.
    Mel47
    Mar 11, 2008 | BOSE48 - Lifestyle 48 Home Entertainment...
    Bose 321 DVD System
    I love my Bose 321 DVD system, but a few days ago, it started acting weird. I put in a DVD, and it reads - "No Disc".....and I'm not sure why. I cleaned the disc, and I also played a DVD/CD Maintenance kit - I'm not sure what is wrong. It seems like I have a problem within the system - what can I do?
    Dec 10, 2007 | Bose (321GS) System
     Grubhead
    Grubhead
