Question about Iomega Computers & Internet
LDHD-UP2 Won't Format
I have an LDHD-UP2 that's worked flawlessly up until now. I was in the process of copying some files over to the HD and something screwed up. Now whenever I plug the thing in it shows up in My Computer has Local Disk (E) and says it needs to be formatted before I can use it. The only problem is when I go to format it and reset it to the defaults it won't format. Any suggestions on how to fix this?
  • 5 Answers
SOURCE: not able to format my pendrive
Make sure you are attaching your pen drive into an USB 2.0 port (also called "high speed USB port"). It must be formatted to FAT32, if it still fails you might try the HP USB Disk Storage Format Tool. If you are using Windows 98 then you need special driver for your pen drive.
Posted on Dec 22, 2008
  • 298 Answers
SOURCE: unable to format the drive r copy files to the drive
Pocket Fuzzies?
Get a bright light and look into the USB connector of the Cruzer. It is possible that there is lint, paper bits, cookei crumbs, etc in there and that is your problem. The outer 2 connections of the USB is DATA and the inner two Power. B/C it is able to flash,you are getting power... but the data lines may be dirty, covered, bent, etc.
Clean it up and try again. Flat toothpick, small ty-wrap or Proxident (dental/braces) brushes work well for this - DO NOT use anything Metal!! It will scratch the connectors and vastly shorten their life (they are GOLD plated)
Short of that, goto HP site and get their USB format tool (get it here: http://files.extremeoverclocking.com/file.php?f=197 ) and try reformatting... if that doesn't work, it is hosed and only I can fix it so let me know ;-)
Posted on Jan 17, 2009
get_fixya
  • 32 Answers
SOURCE: windows was unable to complete the format
sir
u dont need to buy a new one. You can download file shredder from here . do following things :
  1. download and install file shredder
  2. shred all the files which are in pendrive(after shredding u will not be able to recover them)
  3. then try to format it .,
thankyou for using fixya
dont forget to rate the solution
have a nice day
Posted on Mar 12, 2009
SOURCE: Unable to access external WD 500 Gb drive: "You need to format the disk"
I have battled this for a few days. Your mentioning USB leads me to a possible solution.
I had a 500GB drive and put it in the USB enclosure and could only see 128GB one time, 138GB another. I found that external drive enclosures have their own IDE controller chips with older ones limiting the size of the drive they are able to "see".
The best test is to internally mount the drive (perverts will read this differently than intended and risk injury due to shock!) to make sure it can be seen. If so then the next best step is to spring for a new drive enclosure, one that supports the higher capacity drive. It worked for me! My old external enclosure's IDE controller could not handle the higher capacity drive and the new one was perfectly happy with it. Good luck! - Andy C
Posted on Apr 09, 2009
  • 3 Answers
SOURCE: How do I format the Iomega LDHD-UP 1TB in Mac's Disk Utilities?
Sooo easy after a lot of research the fix is "format the disk in os x 10.4"
Sad but leopard have an issue with disk utility wiht this kind of disk .
Cause the original format is FAT 32 ,so....
The fix is format the disk in a mac with 10.4
i do it and works so fine !!!!!!
Posted on Jul 29, 2009
Lost installation CD For LDHD-UP2
Down load what you need from asus.com
Nov 01, 2013 | ASUS Eee 4G Notebook
I purchased a external harddrive Model LDHD-UP2 31882100 and have lost my harddrive for the same
That's possible. Anything made can break. I feel your pain because I've had two Seagate external hard drives to go belly up on me. It's like now days you need a backup to backup the backup.
Thank God for the Cloud Technology. You should look into Google Cloud. You can get 5GB Free to back up your data and you can access it from anywhere.
One more thing, if you want your data off the external drive there are places that will do it but it's going to cost you between $1,000 - $1,500.
Jun 03, 2012 | Iomega Computers & Internet
Why wont my computer recognize my LDHD-UP2 external hard drive?
can you try this sequence
turn off power to both computer and ext drive, after logging off computer
leave ext drive power OFF
connect ext drive to another USB port
turn computer back on let it boot up ext drive is plugged in but no power
once computer stabilizes, then turn power to ext drive on
let me know if this helps.
May 17, 2012 | Computers & Internet
Iomega LDHD-UP2. Have proper drivers for my desktop pc and new laptop pc. No problems connecting and recognizing files loaded onto it from desktop, through laptop. Problem is however, for instance, any...
you might have to uninstall the mp3 from your laptop restart your computer then reinstall the mp3 player or update it
or you might have to update your mp3 player you might need to update other programs which are used
by mp3 ie: adobe
hope it helps
Oct 13, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
Good morning. I was on the drive yesterday, all was fine. I just plugged it in, and it won't even go on. We had storms in the area lat night, and I know we lost power for a bit. It was plugged into...
First don't worry about the content of the drive, it is probably a burned powersupply or no power in the electrical outlet, check if you have power with a good multimeeter in the house outlet and at the plug of the power supply, if you have power than bring it to a certified technician it could be the system board inside that is dead, you could always take the drive out and plug it in a desktop computer to recover the data (I would be surprized that the drive it self is dead) but with lightening you never know!
Aug 20, 2011 | Iomega Computers & Internet
I lost the installation cd driver for my external hard drive P/N 3188210, Model No.LDHD-UP2.I need a driver to open up my files in this Iomega HDD external hard drive. Kindly provide me with an...
hi if you are lost your driver to download your device suitable driver use http://devid.info step to download driver my computer manage, device manager, property on device whose driver are not found copy device id code displayed on example above site copy it and use to download suitable device driver after download extract and go to update driver whose device are installed enjoy
May 21, 2011 | ASUS Eee 4G Notebook
Hello: I have a DMC Xclef and the on-disc software
My xclef 500 hard drive just died after about 45,000 hrs, 7yrs of use. I was just barely able to retrieve the syst files off the disc and transfered them to another hd. Had a 160gig hd, but had to format it to 100 gigs for the player to use it. I have copies of the file folders that I could post to a site, if it allowed me to. Too bad this site won't let me post files.
Apr 06, 2011 | Digital Mind Corporation HD-500 MP3 Player
Computers & Internet Logo
56 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
