Question about Nokia 1100
Nokia N70 power connection
The female connector in the base of the phone, that the charger plugs into is damaged. It is a small component(4x4x8mm) that lifts out once the phone is dismantled. It has FOXCONN printed on one side and 5512A on the end. Where could I get a replacement?
    Problem Solver:
  • 13 Answers
It is available at all nokia repair centers or maybe even at your dealer.
Posted on Aug 23, 2007
SOURCE:
How to defragment nokia n70
Connect your phone to a charger and let it charge until the battery is full. Leave the phone plugged in throughout the procedure.
Unlock the phone by pressing "*" then "unlock.
Type in the code "*#7370#" then enter your security code. The default security code for Nokias is "12345."
Wait 2-to-3 minutes for the format to complete, then your phone will switch itself back on.
Jul 10, 2012 | Nokia N70 Cellular Phone
Charging problem
hi :) have your phone has been water damage ?? most after water damage,phone mother board's charging piont will be pro,tat only way u can do,pls send to mobile shop for repair it.
Jul 08, 2010 | Nokia N70 Cellular Phone
Nokia n70 charger will not enterphone pin
Hi
Be sure that you are plugging in the right charger because some Nokia chargers are not compatible with the N70..
Also be sure that you are plugging the charger into the right port,The charging port of the N70 is the smallest hole under the phone.
Cheers
Mar 28, 2010 | Nokia N70 Cellular Phone
Address recovery from the N70 phones
hi sir,
Either your charger port has got damaged due
to moisture or your charger is not working properly. Go to the Nearest nokia care centre (service centre). They will solve your problem in seconds.
thanx and regards
sukhvinder
Aug 06, 2009 | Nokia N70 Smartphone
My Nokia N70 doesn't charge.
Either your charger port has got damaged due to moisture or your charger is not working properly. Go to the Nearest nokia care centre (service centre). They will solve your problem in seconds.
Jul 12, 2009 | Nokia N70 Smartphone
Not charjig properly
its due to the battery terminal short lik. it means tht a small ic wil be thr of charging in ur phone . whn u connect and disconnect hardly ur charger..it wil be gone by short circuit.. as we c in switch board. get it repaired in any hardware shop.. its a hardware probz nt software.
Dec 18, 2008 | Nokia N70 Cellular Phone
N70 dont run
i would appreciate if u do restoring of handset after creating back up of all data....and ur handset display module chip may b damaged......
Oct 15, 2007 | Nokia N70 Cellular Phone
Wont charge!
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models.
Aug 19, 2007 | Nokia 6300 Cellular Phone
It will not charge
1. The charger may be damaged To check if the charger is damaged, use another functioning charger. The charger cable has a tiny wire that easily breaks when used without proper care. If the phone still does not charge with a functioning charger, try next step. 2. The battery may be damaged Change the battery and try charging again. If the phone still does not charge with a functioning battery, try next step. 3. The battery terminals may not connect properly with the battery connectors Check the battery connector to see if the battery and the connector connects well. The phone will indicate charging only when there?s enough power supply from the battery. click here Solution Procedure: If problem is confirmed, adjust the battery connector using tweezers to reach the battery terminal and establish connection. Or try next step. 4. The charging pin may be damaged or does not connect well with the board's interface Check the charging pins to see if they are well connected to the mother board. Sometimes the charging pins wear out or loosens from its connection with the mother board. click here Solution Procedure: Check if the pin is bent. Straighten the pin using tweezers. Make sure the board interface is also clean otherwise, you will need to clean it by rubbing its surface using an eraser or brushing it with a board solution. Or replace with a new charging pin. Make sure the charging pin touches with the board interface to establish connection. 5. The CCONT IC for DCT3 or UEM for DCT4 or the "K" resister for non-Nokia models may be damaged If the phone still does not charge after adjustments are made, the problem is CCONT IC for DCT3 or UEM for DCT4 or ?K? resister for non-Nokia models. click here
Aug 16, 2007 | Nokia 6111 Cellular Phone
Nokia 1100 Logo
29 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
