Emailair Manual I require to know the cooling and the heating capacity in KW of a emailair airconditioner package unit model number RM 230H and a RM 120H
nanbuenbrazo
  • 553 Answers
SOURCE: require specifications for an Emailair split level
Capacity which normaly known as Horse Power
or RA rating
The voltage input
Ampere ratings
voltage phase ex. (single phase or three phase)
Type: Split type
since it is split type there are several classification(wall mounted, foor mounted or ceiling mounted)
Posted on Oct 31, 2009
  • 1768 Answers
SOURCE: I cannot read the model of Package AC with electric heat strips,
Here is a site that may provide you with all that information.
http://www.furnacecompare.com/air-conditioners/frigidaire/P3RA-036K.html
Posted on Jun 18, 2010
SOURCE: I have a Carrier Airconditioner split system unit
how much do I have to pay for a field power supply conn in my split system air conditioner carrier
Posted on Oct 21, 2010
hvac1960
  • 2133 Answers
SOURCE: I cant get cooling from
Only in some models, there is an option to operate manual. Check near indoor display. If there is button press it. But you can't change temp setting and mode as you like.So, It's advisable get new remote.
Posted on Dec 29, 2010
  • 1833 Answers
SOURCE: Am trying to find a
Sorry, but no user manual or instruction manual is available for Emailair WS066HC right now. You have to wait. But it sounds like the heating element within the air conditioner is not working. Tou can try with replacing them. You can also contact with Emailair services at " http://www.emailair.com.au/Index.html".
Posted on May 28, 2011
How do I find a fan or fan motor for an Emailair air conditioner 110RC Room
you have to find an appliance parts house you can chesk online to you will need serial no. model number. rotation of the motor amps and hp. the best i to take the motor with you
Jul 20, 2014 | Heating & Cooling
Green light flashing on wall unit - no cold air?
Compressor should switch on after 3 minutes.And if it does and still no cold air coming out of the inverter.Then unit needs to be gased.
Jan 06, 2014 | Heating & Cooling
I cant get cooling from my air con,model-emailair WS066H,but I do not have a remote control for it,can i control it manually.
Dec 29, 2010 | Heating & Cooling
Can't find a manual for air conditioner
BTU means "British thermal units" and is a measurment of cooling and heating capacity. Other units are Kw "Kilowatts", and HP "Horse Power".
To convert
Multiply by
To obtain
kW
1.341
hp
kW
3,413
Btu/hr
hp
2,545
Btu/hr
May 21, 2010 | Fedders Q Chassis A6Q10F2A Air Conditioner
Installing rv roof airconditioner heat strip
I see what you see also in the manual. The difference is the Heat Strip package that part is optional and the 600212-001 with the optional heat strips becomes the new 600315-001 I talked to Dometic Duo-Therm and the models are the same but they both are not heat pumps but the new heat strip package comes on when told to go into heat mode when you change the thermostat to heat. The part you purchased will fit both model numbers you listed for your roof top air conditioner. Thanks, Sea Breeze
May 09, 2010 | Heating & Cooling
Require specifications for an Emailair split level air con model CWS 034A
or RA rating
The voltage input
Ampere ratings
Type: Split type
Oct 31, 2009 | Heating & Cooling
Why the word ton used for airconditioner.
hi there..
this what i found for you...
The unit ton is used in refrigeration and air conditioning to measure heat absorption. Prior to the introduction of mechanical refrigeration, cooling was accomplished by delivering ice. Installing one ton of refrigeration replaced the daily delivery of one ton of ice.
  • In the United States, a standard ton of refrigeration = 12,000 BTU/h = 200 BTU/min ≈ 3,517 W. It is approximately the power required to cool 1 short ton of water by 1 °F every 10 minutes; or the power required to melt one short ton (2,000 lb) of ice at 0 °C in 24 hours.
  • A ton is also a unit of energy equal to that power for a period of a day, or 24 h × 12,000 BTU/h = 288,000 BTU ≈ 303.9 megajoules.
  • A less common usage is the power required to cool 1 long ton of water by 1 °F every 10 minutes = 13,440 BTU/h ≈ 3,939 W.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Feb 24, 2008 | Heating & Cooling
Heating & Cooling Logo
162 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
