Question about Vizio Televison & Video
How to manually set up channels - Vizio Televison & Video
    Top Expert:
  • Vizio Master
  • 74,136 Answers
Check its user manual for details.
Posted on May 06, 2013
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
How do I Change the frequency on a Rkio Nike TWo way radio
Hi Gary - I copied this from the RIO NIKE manual:
mode button
Press MODE to select the setting you want to change.
The normal display is replaced by the adjustable setting.
Use the + and - buttons to adjust the settings.
These are the settings you can change.
1. Main Channel (1-14)
2. Sub Channel (1-38)
3. Channel Scan (ON/OFF)
4. Sub Channel Scan (ON/OFF)
5. Button Confirmation Tone and Roger Beep ON/OFF)
6. Vox (OFF, ON LO, ON HI) (psc[communicate wxonly)
When you have proceeded through all adjustable settings, the normal display will reappear. Or, press TALK at any time to return to the normal display.
select main channel
There are 14 main channels.
To select main channels:
1. Press MODE until CHAN is displayed.
2. Press + and - keys to select the main channel.
select sub channel:
Each main channel has 38 sub channels, sometimes called
CTCSS channels. Select one of these sub channels to transmit
on a channel that is free from traffic.
To select sub channels:
1. Press MODE until SUB CHAN is displayed
2. Press + and - keys to select the sub channel.
Note :If you select channel "0," you will be able to receive transmissions from all the sub channels of the main channel you selected.
Download manual:
Jan 27, 2014 | Rio Nike PSC Communicate (14 Channels)...
Reprogramming channels
you can use the user manual, if none you can manually reprogrammed every channel. just go to set up menu then go to channel set up the select manual fine tuned.you can use the channel up/down button then the volume up/down button to search every channel program.
Mar 24, 2013 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
Can not set channels. Stuck on 22. No manual
GO TO THIS LINK AND DOWNLOAD THE OWNERS MANUAL,
LINK : http://www.usersmanualguide.com/funai/television/dwt1304
Jul 24, 2010 | Durabrand DWT1304 13" TV
Cannot set my toshiba television to the input channel manually
if you go to channel 2 then channel down the channels between it and the highest are your input channels hope this helps
Apr 14, 2010 | Toshiba 36A40 36" TV
I can't manually setup the Channels on my Panasonic PV 9451 VCR
In the Menu go to manual channel set-up not auto. When you're in manual set-up change channels until you get to to L-1 and L-2 (should be below Ch 2) and save both to memory. On some TV's the L-1 and L-2 are selected with a separate button labeled "input".
Aug 15, 2009 | Panasonic Televison & Video
Cant figure out how to set TV to cable setting
The company's page for this set is here. There's a link toward the bottom to download the user's manual.
If I read the manual correctly, you're out of luck without an external tuner such as a cable box. This set was made for the European market and its tuning system isn't fully compatible with that used in the US. There's a "channel swap" function which lets you reassign the channels it finds to whatever channel number you want, and it's described in the manual. I assume that's to allow for the different frequency/channel number assignments in use in all the areas it tries to cover. The set's tuner just may not be able to pick up all the channels on your cable system. As long as it gets US channel 3 or 4 correctly, you can use the set with a cable box or video recorder that properly tunes the cable channels.
Apr 23, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
RX-V596 center and rear channels do not have any sound
Nevermind... My center channel output was set to "NONE" I've had this receiver for a few years now, probably set it that way back when I got it. Oh well, Helps to re-read the user manual...
The info is in the "SET MENU" section of the manual, Pages 35-38. Should solve the issue for "almccrum" above as well.
If you don't have your manual it can be downloaded here:
www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V596.pdf
Oct 06, 2007 | Yamaha RX-V596 Receiver
Missing manual for - sharp VC-A560 VHS
I lost my manual and the biggest issue of getting this set up is getting the vcr to the channel you need for play back either channel 3 or channel 4. To change the channel you hold the power button and the tv/vrc button at the same time till you get the channel you want. Three flashing lights is channel three, four flashing lights is channel 4. every time the power goes out mine resets to channel 3 and will not play videos until I reset to channel 4. Hope that helps.
May 24, 2007 | Sharp VC-A560U VHS VCR
Televison & Video Logo
18 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
