Question about Nikon Coolpix 5600 Digital Camera
Af and flash button flash continuously when camera switched on
Hi - I can turn my camera on but the lens does nort come out and both the af and flash lights by the viewfinder flash continuously. None of the buttons work and the screen does not light up. I have only taken 500 pictures with this and find it hard to believe taht this is not a trivial fault. £140 to repair is a joke! I have replaced batteries with fresh.
  • 1 more comment
  • cs1952 Aug 29, 2007
    Thanks Jackboy - working direct with Nikon proved to be much cheaper than going through the shop where I purchased the camera - all in hand now. Nikon direct charge between £25 and £50 for complete repairs.
  • anupsingh Dec 19, 2007
    it's exact the same with mine case
    i have tried a number of combination from the settings etc but each time it gives different result so
    plz help
  • tirch Jan 06, 2008
    same exact problem. Don't see a solution here. Any help?
We have had our Nikon 5600 for about 2 yrs we have always had issues with it Some settings are useless Because the "hand shake" always comes on!
Now we are having a new issue , when you take a picture the Af flashes and Flashes then the screen goes black for about 7 seconds and then its ready to take a picture again..Its getting annoying , is there a quick fix for this or should i start shopping around for a new camera
Posted on Jan 01, 2008
    Genius:
  • 2,985 Answers
How old is the camera? Take a new approach to Nikon. But costs are about right- it is no joke.
Posted on Aug 14, 2007
  • john ash
    john ash Aug 29, 2007
    Tick the boxes then give us a vote
    Nice to know I get something right - sometimes
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
Cannot fire shutter on d80
Hi, Have you cleaned the lens' electrical contacts?or is the lens connected loosely?? Examine but probably little need to clean the camera's electric contacts considering its' young age. Do you have access to another AF body on which you can test the lens and another AF lens to test the D80? Do the following things 1.take a dust free eraser and clean the contacts on the camera carefully by keeping it upside down to prevent dust going inside. 2.do the same for lens contacts. re-attach the lens firmly. hope this solves your probs. regards sreejith
Jun 13, 2007 | Nikon D80 Digital Camera with 18-135mm...
My D80 suddenly stopped taking photos while I was in Auto mode. I noticed the flash stopped releasing. I've changed lenses, reset the camera's green buttons, switched out the card, reset the clock. It...
Hi, Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
May 13, 2010 | Nikon D80 Digital Camera with 18-135mm...
I can't get the flash to come on. what do i do?
Switch the photo mode selector knob on top around to P. Then press the little black button on the body behind the AF/MF button on the lens. Flash will pop up and work then (don't forget to switch the camera on before doing this stuff). All of the above takes the camera out of auto mode (the square green box on the selector), so you can tell the flash you want it. It will work in the other manual modes as well of course. Good Luck
Steve
Sep 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My nikon d70 wont focus at all
  • Make sure both lens and body are set for autofocus. There are two switches near each other with "AF" and "M" settings.
  • Check the camera's focusing settings, or do a factory reset (from menu) to 'start over'. Usually helps to have AF-Assist on.
  • Try setting the AE/AF-lock button (upper rear, near right thumb when holding camera) to turn on AF. The camera may respond better to this than half-pressing the shutter release.
  • Make sure the lens is fully attached to the camera. You shouldn't be able to rotate the lens without depressing the lens release button, and you should be able see a tight seal between the two.
Jun 23, 2009 | Nikon D70s Digital Camera
I, too, am raising my hand on this?D40 with same autofocus problem, with all AF-S lens, 18-35 kit, 18-135, 18-200 VR, 50-200 VR. No solution after trying all above.
Please give more detail on this problem .
Have you tried another AFS or G lens.
Also the af switch could be turned off or the
back focus button could be set inthe custom menu .
Apr 05, 2009 | Nikon D40x Digital Camera
Nikon D100
izzy41,
make sure the lens is properly connected and aligned, if it has been remove recently it may not of been put completely back to the right position causing the contacts to not align. Turn off the camera and remove and then remount the lens. The motors and the cost to replace/repair are almost as much as a new lens. Your lens can and should last a long time unless it has recently been dropped or tried on a camera (forced) the wrong way and the contacts were bent or damaged.
randy320sgi
Nov 29, 2008 | Nikon D100 Digital Camera
Nikon D80 display panel F--
The lens ought to be fully functional in every mode. But if you are in a pinch then Manual it is 'til you can get it sorted or serviced if need be...in which case you'll need to swithch the AF Mode lever (under lens release button )from 'AF' to 'M'. Have you cleaned the lens' electrical contacts? Examine but probably little need to clean the camera's electric contacts considering its' young age. Do you have access to another AF body on which you can test the lens and another AF lens to test the D80?
Please keep in mind that if the aperture is not set (locked) at its minimum, the error is a flashing fEE. When the body cannot communicate with the CPU in the lens, the error is F--, which means either the lens has no CPU or a bad electronic contact.
Aug 08, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80
Hi taylorrm, I don't know if you have a solution to this but sometimes the AE-L/AF-L but gets pushed which is the auto focus lock button then the shutter release button cannot be used to focus and yu have to reset by pressing it again.  Even though it's confusing at first it's a feature along with the AE/AF Lock to try out to lock your focal area on a subject prior to shooting.
To sbhoward5, check to make sure the switch on the camera body is switched to AF instead of M mode(looking at the front it's on the lower right hand side below the lens release button), which sometimes happens when changing the lens - so then the mode selected is in P,S,A, or M modes on the mode dial. happy shooting,
randy320sgi
Jun 13, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon Coolpix 5600 Digital Camera Logo
151 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
