Question about Linksys Instant 802.11b Wireless Network Access Point: WAP11 (NTWRLSXWAP11)
Linksys WAP11 Wireless-B (802.11b) Access Point
How do you connect your laptop and PC to the wirless router to run both through one modem?
  • 196 Answers
The manual for your access point is here, and it provides a thorough explanation of setting it up: ftp://ftp.linksys.com/pdf/wap11ug.pdf Do you actually have a router? Some modems provide this function, but many don't. A wireless access point is usually connected to one of the router's ethernet ports, just like a PC, then you run the setup program to set wireless security. If there's only one port on your modem, and you don't have a router, you need to buy one, or swap your access point for a wireless router.
Posted on Aug 11, 2007
  • 24 Answers
Don't forget to reboot the modem once you first put the router in line.
Posted on Aug 10, 2007
    Novelist:
  • 135 Answers
Wireless networking is too complicated to explain here, but Linksys has lots of tools, utilities and explanayions on their site. Below is a link to the tools page. Click the "Learning Center" link for basic explanations on setup. http://www.linksys.com/servlet/Satellite?c=L_CASupport_C1&childpagename=US%2FLayout&cid=1166859678292&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=7829277881B01 Hope that helps! ;)
    President:
  • 2,961 Answers
You have to go into the routers settings, by typing it's ip address (refer to manual) in your internet browser and look for DHCP and make sure that it is enabled to automatically assign both your pcs an ip address. This must be done using a lan RJ45 cable that was supplied; first before going wireless. Next go to each pc and either use the wireless network setup wizard or go to your wireless network connections (in control panel>network connections) and right click on the connection(this is not the lan connection icon, make sure you choose your wireless icon) and select properties, then click the internet protocol line TCP/IP and again click properties. make sure that 'Obtain IP address automatically is ticked and click ok. Your pcs may need a restart and should find the router will be seen in your found connections, click connect and your away
6ya staff
SOURCE:
Hello, im trying to install my wirless printer to my wireless computer and im having some difficulties. for example its asking me to check my wireless LAN access point.. I dont know waht that is? im...
The Canon is trying to connect to a wireless router or wireless access point which is connected to your computer network. Your Sprint 3g device is a wireless broadband device for Internet connection and cannot connect to the Canon using this device.
You need a wireless card that connects to the wireless router or wireless access point.
Otherwise you can connect to your printer using a printer cable.
May 16, 2011 | Canon MP560 All-In-One InkJet Printer
I have a Linksys BEFSR41 router and a Linksys WAP11 wireless access point. How do I make my home network secure?
Assuming your WAP11 still has the default settings... Open a browser, and type the WAP11's address (192.168.1.251) in the Address Bar and press the Enter key. You should immediately get this password dialog; Leave the User Name field empty, enter "admin" (sans quotes) in the Password field and click OK. That will bring you to the main setup screen, below: connect.jpg wap11setup.jpg
Click the WEP Key Setting button and enter your WEP info.
Apr 15, 2011 | Linksys Wireless-B WAP11 Wireless Access...
Hi i bought the smc wireless router and i tries to connect it but i couldnt figure out how to connect it because i have a laptop and my internet is connected from my modem to my laptop but i cant seem to...
I'm unsure of the exact part number here but using the model number I checked the manual. This looks like it's just an access point which extends a current network you have. If you only have your laptop, this device and your internet modem it may not give you the wireless connectivity you're looking for. On a normal setup you would plug your modem into a router, plug your laptop into the router and set it up with all your DSL/Cable connection information as well as wireless on/off. You can then unplug from the router and continue life. with this one it's only connecting to an existing setup (another router or another wireless network) and extending it.
If you are looking for a solution to give you a router that connects to your modem and gives you wireless or adding multiple devices on a single connection I would recommend returning this and getting an all-in-one router such as this: http://homestore.cisco.com/en-us/Routers/Linksys-E1000-Wirelessn-router_stcVVproductId97826160VVcatId551966VVviewprod.htm?icid=linksys-specs-e1000-learnmore-btn&src2=linksys-specs-e1000-learnmore-btn
Mar 07, 2011 | SMC EZ Connect g SMCWEBT-G
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
I have a linksys wrt54GX2 wireless G router and I would like to use it as an access point to pick up our internet signal from downstairs. The modem in use is wireless motorola SBG900. I have a desktop and...
With that particular model you wont be able to use it as a wireless bridge. You can however run an ethernet cable from the modem to any point in your house. the SBG900 i believe has wireless built into it, so you may need up with 2 wireless networks.
Hope that helps.
Feb 05, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
SETTING WIRELESS
1. Shut off the power to your cable or dsl modem for about 30 minutes.
2. Connect the ethernet cable from your modem to the Internet port on the router.
3. After 30 minute power on ONLY the modem NOT the router
4. Wait about 60 seconds and power on the router
Try it now.
Oct 29, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Adapters Compatible with the Westell E90-610014-06 Router?
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
Mar 04, 2008 | Westell Wirespeed LiteLine 6100...
Netgear DG834PN v talktalk modem/router
-could u pls poost the model no. of the netgear product
-it wuld help me to guide u better
srini
Jan 26, 2008 | Linksys Instant 802.11b Wireless Network...
Connecting one network to another?
This is what I would do I would connect the wireless to the internet direct and allow all PC with wireless capabilities to access the net through that wireless irrespective to where I place the wireless router.  Alternative I would link the cable on on the second floor the one you use for the PC to access the net to access the the wireless it should automatic allocate IP addresses as each machine accesses the network.  The speed of that wirless is decreased as each wireless PC comes on line.
Oct 26, 2007 | Efficient Networks SpeedStream 5200 Modem
Cannot obtain internet through router
Try resetting the router and modem. Unplug them both from the electrical outlet. Leave them unplugged for at least 1 minute. Then plug the modem in, let it establish a connection, then plug the router in. Do this with your pc turned off. After you reset the router and modem, plug them all back together and into the pc, then turn the pc back on.
Aug 23, 2007 | Linksys A+G WRT55AG Wireless Router
Computers & Internet Logo
184 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
