Question about Sta Rite SR400NA Max E Therm Pool Spa Heater Dual Electronic Ignition LoNox 400000 BTU Natural Gas ASME
Heater won't ignite and leaking water - Sta Rite SR400NA Max E Therm Pool Spa Heater Dual Electronic Ignition LoNox 400000 BTU Natural Gas ASME
    Top Expert:
  • Sta Rite Master
  • 5,775 Answers
Bad heat exchange probably ruined ignitor
Posted on Oct 11, 2017
Hotpoint water heater the electric igniter won't spark
Copy following link for troubleshooting igniter, and troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#igniter
Add a comment and say what manufacturer appears on label.
Open link above and scroll to top for information about FV lockout.
Mar 16, 2013 | Rheem 50 Gallon FVR NATGAS Water Heater...
Bosch Confort S 13 BP tankless water heater won't ignite, It clicks but no gas going thru valve
The S 13 BP is a simple unit that does not have a pilot light. It uses electronic ignition on demand, which is what you hear clicking. If there is no gas going through and you've verified there is gas to the inlet, then it has to be the gas control valve.
Feb 01, 2013 | Bosch & Tankless LP Hot Water Heater
Water won't stay hot long
1) Thermostat may be bad, or out of calibration. Set temperature higher, and/or troubleshoot by type of gas control.
Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Dip tube broken
http://waterheatertimer.org/Water-heater-dip-tube.html
3) Water leak running hot water out of tank.
Turn off all taps and put ear against pipe listening for water leak.
Dec 08, 2012 | Water Heaters
BFG1H4040T3NOV Whirlpool gas water heater won't ignite
Bad thermocouple or gas control valve.
Good luck,
Marty
Jun 08, 2012 | Whirlpool Water Heaters
Low coolant heater not got hot air loosing water
Your post is very vague, but if you are losing coolant, your heater won't work when it's low. Find the leak. Fix it. ??
Feb 18, 2012 | Cars & Trucks
GE (Rheem) SmartShield Water Heater. it rained on the hot water heater and now the pilot won't light. Any ideas?
Does it have an electric ignition? If so, remove the pilot light access panel, blow inside the chamber with a hair dryer. Do this until there is no more moisture inside. Then follow the lighting instructions. Try this even if it's a match start. Thanks and please rate.
Sep 05, 2011 | General Electric Water Heaters
When my trailblazer over heats. there is fluid that leaks out of a drain hose on the fire wall. why is it?
Sounds like you may have water leaking out of your heater core.
This will cause an overheat condition, which you get because your engine cooling system can't pressure up as well.
You may also notice a kind of "sweet" smell to the air that comes from the air vents that blow when A/C or heater is on.
As water leaks into the A/C & Heater core compartment area...it trickles to the overflow drainhose on the firewall. This is usually intended for the condensation of the A/C core but a leaking heater core will drain that way too.
From what I hear, I'd see about disconnecting the heater core hoses going into the firewall and maybe use a splice to connect them to each other OR get a two 5/8 bolts and a couple clamps and plug the hoses.
This allows you to drive car without overheating and buys some time to get you another heater core (basically a "mini-radiator") Its summer, so you don't need the heater right now but keep in mind...you won't have a heater until the core gets replaced.
Hope this helps...
Aug 13, 2011 | 2002 Chevrolet TrailBlazer
Sta Rite SR400NA Max E Therm Pool Spa Heater Dual Electronic Ignition LoNox 400000 BTU Natural Gas ASME Logo
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
