Question about WAC Lighting Solorail Eight Foot Rail WAC-LM-T8
Troubleshooting flexible monorail lighting
Lights go off after an hour about 30 minutes of being off they go back on...
Speedometer lights
It probablt is the light bulb that blew.
You can change out the bulb but it is a time consuming proses.
Just have a magnet on a flexible stick as you will need it. Might take 2-5 hours to take apart and reassemble it depending on the vehicle.
Oct 23, 2015 | Cars & Trucks
1991 honda civic si low beam lights
Check if there is a light relay in the fuse box, that should be the problem.
Oct 30, 2008 | 1991 Honda Civic
How do i resolve the problem of vga not responding after like 30 minutes to 1 hour of usage
your graphics chip is separating from the board enough to create the fault.Most use a flexible heat pad as a spacer between the chip and cooling assembly.Google to find how to clean fan and replace heat pad.Using a copper shim instead of the flexible pad is best.A reflow of the GPU chip may be required also.
May 28, 2014 | HP EliteBook 6930p Notebook PC
Have a 2003 dodge intrepid 3.5 . the engine sounds a little rough,after running for a few minutes the check engine light comes on as well as the oil light.the car shuts off and will not run untill maybe 30...
You need to get the codes read. My guess would be some sensor is sending an overheating code to the computer which in turn is protecting the engine by shutting it down. If you don't have a reader, most auto parts shops will do a free read for you.
Jun 08, 2017 | Dodge Cars & Trucks
Suzuki troubleshooting
The DRL controller could be defective.
Dec 20, 2013 | Cars & Trucks
We have the Noma Exterior Mechanical No instructions. Shows on and off/dusk and then the hours. Do you turn to dusk and then the hours how do you set it to come at dusk then turn off 6 hours later?
Identify timer on following page:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Page shows instructions and troubleshooting.
That being said, if your timer has a dial with 2 4 6 8, then following instructions probably apply:
Timer turns on automatically at dusk,
Rotate dial to select when timer will turn off.
In your case, rotate dial to 6, and then timer will turn off 6 hours later.
Make sure to keep timer turned away from lights, or where car lights might reach photo-eye located on front of timer.
If timer is exposed to light, it will turn OFF, and then blink back ON few minutes later.
When timer turns ON again, the 6 hour countdown starts over.
Dec 22, 2010 | Garden
Lost Manual and would like instruction on how to set for self clean cycle?
Make sure you have everything out of the oven, including the oven racks.
1. Press SELF CLEAN.
2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
3. Press START.
The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
displayed.
4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
indicator lights will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth.
Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
It is also recommended that you remove anything plastic from the top of the stove during cleaning.
Nov 27, 2010 | Whirlpool RF263LXTQ Range
Microwave heating for 20-30 minutes with no food. Does not work.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hgj
Jun 02, 2010 | GE JVM1630 Microwave Oven
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
WAC Lighting Solorail Eight Foot Rail WAC-LM-T8 Logo
509 people viewed this question
Top WAC Lighting Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a WAC Lighting Garden Expert? Answer questions, earn points and help others
