Question about Garden
Craftsman 917.251522 belt slipped off. old. got new belt. same size, now mower wont move. I don't think they are related. the belt is on right. the trans pulley is turning. bogs a little when you let off the brske to engage the belt on pulleys. ..idk
5 Suggested Answers
  • 37 Answers
SOURCE: Drive belt comes off the rear pulley.
Hi, this is a easy solution. on your drive pulley, there should be three belt keepers to keep the belt from coming off. ( belt keeper is a 1/4" dia. rod that goes over the pulley)
Posted on Nov 22, 2008
  • 376 Answers
SOURCE: LTX 1000 CRAFTSMAN /42 IN. DECK BELT LODGED ABOVE
Without the model number, I couldn't tell you what belt goes on the ground drive. That 174883 is a 5/8 x 97" and is your deck drive belt. Your ground drive belt may just need replacing. They will wear thin and loosen up between the pulleys and cause the problems you're having. The old belt may still have the numbers on it.
Posted on Jul 04, 2009
Dolfoff
  • 148 Answers
SOURCE: Mower Belt Won't Engage
The fact is that belts don't stretch. They wear down on the sides, causing them to ride deeper in the pulleys and they APPEAR to be longer. Check belt "width" to see if it is less than one half inch. Most craftsman riders use half-inch (AKA: "A section") belts.
Posted on Sep 26, 2009
Testimonial: "I removed the mower & checked everything - pulleys, bearings, mandrells, springs. All OK. Re-assembled and it works again. Thanks for your feedback."
  • 5370 Answers
SOURCE: Need a belt diagram for
So as per your explanation, it indicates that , your mower has 6 pulleys.------ 1 motor driven pulley,3 blade pulleys and 2 accessory pulleys.That in total comes to 6.So for belt routing diagram for Murray 46" 6 pulley.Click this link below and see the belt routing diagram:---
http://technoanswers.blogspot.com/2011/09/belt-routing-diagram-for-murray-pro-16.html ----------- this will help.thanks.Helpmech.
Posted on Sep 05, 2011
Blades on craftsman 18HP won't come on
the belt will be on the mower deck awnd run to the pulley on the bottom of the motor.
Apr 29, 2017 | Craftsman Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Craftsman Lawn Tractor wont move
May slipping or wrong belt.
What attachments can I use for a manual pto lawn tractor?
it would depend on the model/size of the machine i have seen that the snow blower attachments don't work very well on any rider i don't think sears had a tiller for anything modern and what you would pay for most any attachment you can get a stand alone version cheaper if you want a work tractor get a wheel horse a old cub or deere tractor not a riding mower that is to weak to handle the work out
May 21, 2012 | Craftsman Garden
Craftsman mower keeps breaking primary mower belt
Have you check the tensioners? The idler pulleys that are on the arms with springs on them. My reasoning is, if the arms are rusted, or stuck for some reason and not moving freely then the springs can't pull the belt tight. If that's the case, I could see where the belt could be slipping more than it needs to and prematurely wearing out. Just something to check. Good luck.
Jul 29, 2010 | Craftsman Garden
Tractor belt slips so blade doesn't cut
There is an electrical clutch that drives the belts. This clutch may be worn. Some will have adjustments that will allow it to tighten them up and not slip. Now when your tractor is running and you turn on your blades there is power sent to this clutch, it is mounted on the engine shaft and has flexible metal plate that is pulled into a pulley buy an electro magnet this plate is worn or could be full of grass/dirt. You need a good strong light, with the tractor OFF, get under and look at this clutch, look for grass/dirt or if the metal has changed colors meaning it has gotten very hot. If it has gotten very hot it is time for a new clutch... Sorry if this is the case. Good hunting.
May 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Slow moving belt for the mower blades on Craftsman riding mower
craftsman belts are not the same as automotive belts. check with sears for the new belt and how it is routed .
May 21, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Tillers rotate put in gear wont move was moving just stopped is their a belt or chain in gear box or transmisson
Hi pat,
Yes, there are two chains in the tranny. If the wheels spin freely but don't engage, the smaller chain is broken.
If the wheels don't move, in gear or not, the smaller chain is broken and wrapped around the gears.
It's a bit of a chore to get to....
Mike
Apr 30, 2010 | Craftsman Rear Mount Tiller
How to change the v-belt on a craftsman walkbehind lawn mower,
Remove the belt cover, Remove the blade and blade adaptor. Remove belt guard and slip off old belt. Install new belt just like it was removed. Install parts and you should be good to go. Hope this helps
Nov 20, 2009 | Craftsman Garden
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
