Question about Optics
Can I adjust the trigger pull on my rifle /
  • 243 Answers
Depends on the make and model of your rifle.
Posted on Jun 24, 2014
2 Suggested Answers
  • 4 Answers
SOURCE: I have a beeman rs1 chinease air rifle is the
Yes they are adjustable, both 1st and 2nd stage and also trigger weight.
The trigger group is easily disassebled and honed with fine emery paper. You really dont need a mirror surface but the factory surface is very far from smooth. There are som sharp corners on the sear and the trigger lever, DO NOT ROUND THEM.
Pay close attention to the three small springs inside, if you get them mixed up the rifle will not lock.
This work will make all the difference in your rifle.
Just work slowly and with caution not to change the angles in the trigger geometry, all you want to do is polish the surface.
Tutorial can be found here http://webpages.charter.net/guru1/documents/RSE%20Airguns%20-%20Beeman%20RS2%20trigger%20guide.pdf
Posted on Aug 18, 2010
How do i adjust the trigger pull
Very carefully as if you get it wrong
Most rifles come with limited adjustment to the trigger pull down to 5lbs if you are lucky so to get them lighter say to 2.5lbs final stage you either have to get a after market trigger or
Stone the surfaces of the trigger but doing this is very very dangerous if you make a mistake
Take the weapon out of the action and look at the trigger for small screws or Allen bolts that adjust the sear engagement and if the trigger has them adjust them a little bit and test trigger pull and safety catch to see if it dry fires when you operate the safety if every thing goes OK repeat until you get desired pull weight or run out of adjustment then think about a professional trigger job as if you get it wrong you will start putting rounds in unexpected places
I have gone on about getting it wrong a lot as I have seen weapons with truly hidious trigger jobs that have fired by closing the bolt or setting the safety to safe which has given the other shooters a nasty surprise and the poor nut on the gun a shock
Jun 09, 2015 | Miscellaneous
How do I shoot??
Point gun toward target and place finger on trigger. Pull trigger.
Feb 22, 2015 | Cars & Trucks
How do I adj. the trigger pull on my wetherby .204 cal. rifel
If it came with an adjustable trigger easy to do take action out of stock and check trigger for adjuster screw should have +/- arrows and don't go below 16 oz pull
if not the rifle will have to go to a competent gunsmith or to a wetherby service centre to have the trigger faces honed
Or fit an aftermarket adjustable unit like timney
Feb 21, 2015 | Optics
Trigger problem on my Yugoslavian SKS rifle. when the bolt and carrier are locked in the firing position it pushes down the pin on the trigger group and the hammer will not fire. If you pull the bolt...
I'm having trouble visualizing which pin (firing pin???) you're talking about. How sure are you that the rifle has been reassembled correctly? Could you post a picture so we can see how it's assembled? One shot (no pun) of the assembled trigger group would be good, then another shot of the bolt & carrier.
Aug 07, 2014 | Optics
I need to adjust my trigger pull on a Ruger Model 77 rifle.
If you'll look up into the trigger assembly inside the trigger guard you'll see a set screw. I've got one of those old Rugers and supposedly that set screw is for adjusting trigger pull wt.
Nov 07, 2012 | Refrigerators
I have a beeman rs1 chinease air rifle is the trigger adjustable and if so How?
Mar 21, 2010 | Beeman Optics
Crossman Sierra Pro Air rifle
The piston doesnt lock on the trigger. if trigger is adjustable set adjustment more coarse. Check also sure that trigger mechanism is in forward position and not stuck halfway. If still not hooking see if piston hooh and trigger catch not damaged. very seldom the piston will twist inside making it impossible to hook, just realign piston.
Jun 01, 2009 | Crosman Phantom .177 Caliber Break Barrel...
If the trigger is adjustable set it more coarse to hook the piston rod. Make sure trigger is loose and will reset to it foremost position. Check trigger spring and pin for ease op operation. Lastly check if piston rod did not turn inside cylinder so hook is turned away from trigger.
Feb 08, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
