Question about Tools & Hardware - Others
Wire diagram 240 vo stop start switch kedu jd2 unit
WAS WORKING BEFORE DISMANTLING NOW NOT SURE OF THE RE-WIRING PLACEMENT
  • 81 Answers
SOURCE: NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
I have a wiring diagram for the standard A-200. If you send me your e-mail to me I will send it to you. capt_rick1912@yahoo.com
Posted on May 31, 2008
  • 1027 Answers
SOURCE: Spark plug wire diagram
Visit a car dealer with same make, look under hood and sketch the wire layout, and copy in yours.
Posted on Jul 04, 2008
tellme2
  • 137 Answers
SOURCE: Wiring Diagram
hi there ,,havent tried these guys yet m8 ,but try the downloadable wiring diagrams ,,if they do them 4 your bike,, try this www.repairmanual.com this is a downloadable manual site,, cheers
Posted on Feb 27, 2009
  • 174 Answers
SOURCE: need wiring diagram for switch.......
try looking at this site .http://www.toolpartsdirect.com/cgi-bin/partbrands.cgi
Posted on May 31, 2009
emissionwiz
  • 80417 Answers
SOURCE: spark plug wire diagram for 91 ford f150 302
here is a diagram, if u can't see it go to the link below.
http://autorepair.about.com/library/firing_orders/bl-fo-9225.htm
Posted on Mar 12, 2010
Need a switch, kedu electric 564
I'm not familiar with this unit but you can replace the switch with any other that has the same or better ratings that will fit the slot its in. You can also relocate the switch to another location like the power cord if you need to, to make it work, as long as you do it safely.
Jul 11, 2014 | McCulloch 4 Ton Electric Log Splitter #...
Headlights wont work
According to my wiring diagram, the headlight switch works a relay which is powered by two different fuses.
I would check the relay for voltage first.
You may need a repair manual to trace the circuits.
Dec 19, 2012 | 1991 Volvo 240
I rewired the unit in its 3-prong orientation and have plugged it into our 20A outlet. In the current orientation, only the dryer works. However, if I switch the black and red wire, only the washer wo
if i understand correctly you have it connected to a 240 volt circuit protected by a 20amp breaker, then you should have it on a minimum of a 240 volt circuit protected by a 30 amp breaker ,then you should have 120volts from the red wire to the white neutral wire and 120 volts from the black wire to the white neutral wire,or 240 volts between the red and black wires, then the unit should operate correctly as the dryer needs 240 volts and the washer uses 120 volts to operate as this is how the unit is wired to operate
Aug 31, 2012 | Whirlpool LTE6234D Top Load Stacked...
How to hook up wires
you will need a 10 -3 wire hook up the red and black to fuse netral and ground to the ground should work
Aug 03, 2012 | Electric 30 Amp Fusible Indoor Safety...
Amana ALE643RBW Dry will not start. I checked the thermal fuse and the high limit thermostat both read 0 to 4 back to 0 ohms. It was jumping around back and forth. Checked the heating coil it read 10...
Hello Dale,
Having checked the thermal fuseto be good i will give you a partial list other things that could make the dryer not start
start switch
door switch
timer
circuit breaker, use your meter set to volts ac and check for 240 vac at the outlet,if 240 not at power outlet check for burnt connection inside outlet or bad circuit breaker
if 240vac at outlet check for 240 vac at terminal block on back of dryer where cord connects,if 240 at outlet but not terminal block replace cord , if burnt connection at terminal block,replace cord and block
finally the motor,manufactures do not publish wiring diagrams online and the only way for me to tell you to use jumper cord to check motor is find the wiring diagram inside of control panel and place one wire on the terminal indicated as neutral on wiring diagram and one wire on terminal indicated on diagram as run winding
firstly though check door switch to have contunity (0 ohms) and the start switch to have (0 ohms)WHILE PUSHING IT IN(the start switch isa momentary contact switch and will only have contunity while its pushed in)
to check timer again use wiring diagram and find chart that shows various cycles and with timer set to a cycle the two wires is says will have contunity will be indicated by a solid black line on the diagram
Good luck, Gene
Jul 26, 2011 | Dryers
I bought a house that had an intermatic t104 running timer running the pool pump. It worked for a little while then the clock stopped turning. The manual switch still worked to turn on the pool. I...
If you only have a Black wire, White wire and a ground wire, you are only wired for 120 volts. For 240 volts you have to have two Black wires or a Black and a Red as well as a White (neutral) and a ground.
Jun 21, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Wiring a sanyo air conditioner in home. when
Follow the manufactures recommendations and ignore the people who sold you the unit. You do not say if it is a 240 Volt unit or 120 Volt. If it is 240 Volts then no way will a 12/2 wire work. What is the model of the unit?
Jun 06, 2010 | Heating & Cooling
Powers on wont heat lg dle2532w
better to unplug the unit for an hour.
Mar 23, 2009 | LG DLE2532W Electric Dryer
Kenmoore 70 series dryer wont start
Are you 100% certain the dryer has 240 VAC? Just because a light may light does not guarantee both legs of 240 VAC are hot.
If you measured motor continuity, then you must be able to read a wiring diagram/schematic. Most Kenmore units have a wiring diagram/schematic glued to the back of the rear service panel, or folded and stored in the control head.
I am unable to find a wiring diagram on the internet, but, you have a door switch, and the timer/control.
Use the wiring diagram to trace the signal path's to determine where the failure is.
Let me know if you have any questions and I will do my best to help.
Jan 21, 2009 | Dryers
Tools & Hardware - Others Logo
114 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
