Question about Logitech Cordless Click Plus Rechargeable mouse (9311740914)
Cannot reintroduce them to my pc
I have just moved my pc to a new office. When i connected my system back up the keyboard and mouse would not work. I have tried for hours to reintroduce them using the same method initially used when i purchased them but they will not connect. The mouse is fully charged and the batteries in the keyboard are new, the wires are correctly plugged in and i am pulling my hair out.............can you help??
  • stu130771 Aug 13, 2007
    Thanks very much for the advice...........worked first time, soory for the delay in thanking you, cheers
    President:
  • 2,961 Answers
It may be a silly question, but have you connected the reciever back into the same usb port as you took it out from, as if i'ts in a different one you may need to install the drivers again.
Posted on Aug 10, 2007
SOURCE:
My mouse and keyboard won't work...after i restart it several times,then it works,,,it will wake up out of standby or start up,but the mouse won't move,sometimes when the mouse does move the keyboard won't...
i assumed that you use device PS2 (Mouse & Keyboard), this rarely situation, but you haved installed and not more better, because the problem not with your system, but with your hardware, maybe you can change with USB Mouse Device and for Keyboard PS2 is better than USB Keyboard.
Mar 01, 2011 | HP Pavilion Media Center TV M8200n Desktop...
Wireless mouse does not work after changing batteries.it always has in the past The Dell computer and mouse is probably 8 years old but has always worked.
Try moving the mouse receivers usb plug in to another port. Unplug any new devices and restart computer. Then replug in any new usb devices.
If still not working.......
Look at Office Depot and other office stores for a replacement wireless mouse. I have seen them as low a $9.99 on up. You might even want to upgrade and get a wireless mouse and keyboard set.
Mar 08, 2010 | Logitech WIRELESS OPTICAL CORDLESS MOUSE...
During reinstall of XP on Dell Dimension 9100, half way through process the mouse/keyboard locks up and cannot continue with install. Any suggestions? Thanks.
Try using an optical mouse of the latest technology and maybe try a USB key board. Maybe this will make some difference.Try to use the most popular ones for starters...............sodeep
Apr 18, 2009 | Dell Dimension 9100 PC Desktop
Bluetooth keyboard and mouse not working with computer
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Jan 09, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Philips freeline wireless keyboard and Mouse
Have you tried re-installing the software for the keyboard & mouse. It sounds like a driver is missing and the best way to solve it in most cases is to re-install the software from the disk that came with the Keyboard & Mouse. Hope that helps. Bud
Jan 05, 2009 | GE Wireless Optical Mouse
I'm currently having to manually switch between my PC and Mac. When I unplug the Dynex Model DX-WKBD keyboard and mouse (both wired) and service cable from the Mac and plus them into the PC, the Number,...
Rather the switching them, you need a KVM (Keyboard/Video/Mouse).
This will allow you to connect the 2 computers to 1 keyboard an mouse. These can be found at any office supply chain that has computer hardware (Like Staples or Office Depot) or online.
To connect it, power off both computers, connect the KVM to each, and then plug your Monitor, keyboard and mouse into the KVM. Power on the systems (one at a time).
Sep 01, 2008 | Computers & Internet
Acer wireless mouse and keyboard connection problem
Unplug the USB cable associated with the keyboard and mouse while the computer is still on. Plug it back in to a different USB port. This should cause Windows to re-detect them and reinstall the drivers automagically. Let me know if that works.
Mar 17, 2008 | Computers & Internet
Cordless Mouse & Keyboard install I need help
if you have a disc for the new items ,install first,shut down pc, then take the old mouse & keyboard off connect the new wireless ones before rebooting
you may need to sync the mouse & keyboard by holding in the small little button on each item and the reciever unit untill the lights come on indicating it is recieving the signals from both mouse & keyboard.if this does not work put the old mouse back in reboot then go into control panel / mouse, and sellect wireless mouse ,turn off the pc plug the new mouse back in then boot up
good luck
Terry
Mar 09, 2008 | Computers & Internet
Can not get mouse to move and buttons will not work on keyboard. batteries are all good
Dec 12, 2007 | Microsoft Optical Desktop 1000 (BV3000003)
Keyboard wont respond
Often this is simply because the radio link between the receiver and the mouse/keyboard has been broken. Some possible reasons for this are: flat batteries, insertion of new batteries, connector to the computer removed, etc.
In the first instance, you should restore the Logitech devices to a defined status (reset). To reset the device:
Remove the batteries from the mouse/keyboard for approximately ½ hour.
Press and hold the "Connect" button on the receiver for 15-20 seconds. Make sure that the receiver is connected, the PC is switched on and that there are no batteries in the devices. After resetting, insert new batteries and restore the connection as follows:
  1. Press and hold the "Connect" button on the receiver for 1-2 seconds.
  2. Then immediately press the "Connect" button on the bottom of the mouse (locate this button before you start, all cordless mice have a "Connect" button)
  3. Move the mouse around to check that the connection is working correctly
  4. Press and hold the "Connect" button on the receiver again for 1-2 seconds.
  5. Then immediately press the "Connect" button on the bottom of the keyboard (locate this button before you start, all cordless keyboards have a "Connect" button)
  6. Use the keyboard to check that the connection is working correctly
  7. Both devices should now be working correctly
If one or both of these devices is still not working, try them on another compatible PC system to ensure that the fault does not lie with your PC system.
Nov 09, 2007 | Logitech Cordless Desktop MX 3000...
Open Questions:
See all Logitech Cordless Click Plus Rechargeable mouse Questions
Logitech Cordless Click Plus Rechargeable mouse (9311740914) Logo
85 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
