Question about Refrigerators
Mr. Freeze portable ice maker Sa 12863
I need a manual for the Sa 12863. Mr. Freeze portable ice maker.
jonniewalker
  • 1031 Answers
SOURCE: Bosch Side by Side, top shelves dont freeze food, bottom does
majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
Posted on Mar 29, 2009
  • 531 Answers
SOURCE: Ice maker makes hollow ice cubes.
check freezer
Posted on Mar 31, 2009
  • 3 Answers
SOURCE: ICE MAKER NOT WORKING PROPERLY. ICE WILL FREEZE
if water is running in, your tubes are not frozen. More than likely it is the arms that eject the ice are not working and turning to move them out. Check that. Ours were moving some, but not all the way around. We called someone out and they said it would be $500 to fix. We ordered the part online after calling the company and getting the part number, it was a $110, looked up the manual online, it took 3 screws removed and 1 connection and me and my mom replaced it. Not as hard as the tell you, just get online and find the manual that tells you how. I promise not hard, we were very proud of ourselves!!
Posted on Jul 14, 2009
SOURCE: mr freeze sa12863 where does the water go.
you lift lid and add water up to the bottom of the plasticslotted tray where ice cubes will be after made. I have a problem with sa12863 also, The water quit filling into tray? like line is plugged or pump quit???
Posted on Jul 19, 2009
  • 220 Answers
SOURCE: Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Posted on Sep 13, 2009
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Have a Hotpoint model HSM25GFRA SA Ice maker stopped did some checking ond found the water solinoid to ice maker was open and replaced it. But still no ice, have removed ice maker, cleaned and defrost
Check to see if there is ice blocking the tube to the icemaker. Sometimes when the valve is giong bad or the icemaker sits too long without making ice the tube will freeze and block up with ice.
Feb 14, 2014 | Hotpoint HSS25GFP Side by Side...
My Mr. Freeze portable Ice Maker Will not turn on When I push the power button
sounds like control problems or power to ice maker not there plug something into the wall socket to see if it is getting power
Oct 29, 2013 | Kitchen Appliances - Others
Find a windchaser portabel ice maker manual, model ICM15S
Believe it or not, this link has the ICM15 manual. Now if I can just get my
dump tray to rotate before the cubes all freeze together ...
Aug 30, 2011 | Windchaser Freezer ICM15 Portable Ice Cube...
I had a Mr. Coffee Ice Tea Maker Given to me with no information on how to use it ? model# tm36p sn tm30p
Unsure of which model number you are looking for a manual. Currently available manuals for Mr. Coffee Ice Tea Makers are available here:
http://www.mrcoffee.com/InstructionManuals.aspx
One of these should be close enough to your design to be of some assistance.
Mar 21, 2011 | Mr. Coffee Iced Tea Maker TM1S
Magic Chef Portable ice maker is not making ice
I have the same problem as above with my portable ice maker. The water is not getting to the trey for the rods to freeze it. I checked and don't think the tubes have any blockage.
Sep 14, 2009 | Freezers
Mr Freeze SA12863 Counter Top Ice Maker parts?
Call the phone number on the back of the machine.
sunpentown 800-330-0388
They helped me diagnose a problem and sent me easy instructions for fixing it. They also had parts I could order.
Apr 22, 2008 | Refrigerators
Refrigerators Logo
89 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
