Question about Boating
Simrad ap14 Unit trying to engage but doesnt
My Ap16 Simrad control head died. Any idea of as to 1) where I might get it repaired and/or 2) where I might find a replacement?
Hi John
Boy, you're up against it on this one. The AP16 is a pretty old unit for sure. Here's the link to your owners manual.
I've come across one instance in my experience where although there was enough power showing to the control head, because of corrosion and broken wire strands, there simply was too much voltage drop and not enough current flow for the unit to function when it was turned on. After cutting back/fixing the soldered connections and reconnecting the cable, the unit was good to go.
I hope this information is able to help you out.
Good luck.
-Steve
http://www.simrad-yachting.com/Root/Operator%20Manual/SimradYachting/English/AP16_OM_EN_20221560F.pdf
You MIGHT get some joy contacting Simrad tech. at 1 800 628 4487
if you're in the US. If not, here's the link to their support page.
http://www.simrad-yachting.com/en-US/Contact-Us/
Dec 08, 2014 | Navico Simrad AP16 Autopilot for Inboard...
Why does my simrad ap16 say initializing and doesn't do anything else?
The fact that initialization cannot complete the task at hand is an indicator the device is not capable of accepting new instructions, the circuit prevents reestablishing current instructions from making changes to the unit, or you may need to pay for services to unlock various codes.
May 10, 2014 | Simrad AP16 Second Station
Change MMSI number ? simrad rd 68
Hi!
Sorry to be the bearer of bad news, but according to the Owners Manual for this unit:
http://www.busse-yachtshop.de/pdf/simrad-rd68.pdf (Page 6),
to erase a previously entered MMSI, the radio must be sent to a Simrad authorized dealer. I suppose this feature was put into effect to cut down on stolen Simrad products.
Hope this is helpful, sorry I couldn't do more for you.
Jun 19, 2011 | Simrad RD68F VHF Radio Class D DSC by GPS...
Problem: Autopilot does not engage. This is a new problem as it was working quite recently. Model: Simrad NSE8/AP24 with AC42 Autopilot Computer. Attempts to engage the autopilot result in an...
jimtippettau:
Which drive are you using with the AP24, is it just a hydraulic pump on a powerboat, like our RPU80, or is it a hydraulic linear drive (like our HLD-2000) or draglink drive (like our DD-15) on a sailboat?
Mar 24, 2011 | Simrad AP24 AUTOPILOT DISPLAY UNIT
Hi,Steve from Australia.I have a AP14H and am now having problems.The hand held is showing rudder angle hard to port.If I engage NAV the boat veers hard Port(even though the flagged waypoint is directly...
seems to be a problem with the rudder feedback sensor first check if rudder sensor is not mechanically disconnected,if not try to do de setup procedure,reset the unit to factory condition,try to set rudder limits,if this is not working ,check with other feedback unit.
Jun 26, 2010 | Simrad Ap14h Hydraulic Powerpilot
Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Oct 28, 2009 | Simrad Boating
I cannot get a position on my Simrad CE33 chartplotter/sounder
Ensure that the external position to be OFF, refer to manual below. See interface display in [MENU],7,2
Try resetting the Chart Plotter to factory settings. Use the Delete Memory and Factory Preset options as described in section 9 of the user manual below:
M A N U A L Simrad CP33 Chartplotter
Sep 05, 2009 | Simrad CE44 GPS Receiver
Simrad ac10 current overload
Normally this is the electric motor causing this problem. Just went on a call and had the same thing. Checked voltage coming from the AC unit to the motor and had 12 vdc then put a new one in it's place and it solved the problem. You don't have to change the pump portion, just change the motor itself. Indeed you will have fluid leaking but many times it's better than plumbing in a new pump.
Feb 18, 2009 | Simrad Ac10 Course Computer
Simrad Autopilot won't turn on
Try and turn on the unit at the J300-40 pcb by using a test light one end to gnd and going to the ap35 interconnect and touch the test light to each pin or until you hear the unit start up.
Dec 19, 2008 | Simrad AP35 GPS Receiver
Boating Logo
23 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
