Question about RIM Blackberry Curve 9320 Smartphone - Black
Blackberry curve 9320 keyboard not working
I put some rubbing alcohol on my blackberry, and now the keyboard and the trackpad is not working. Rubbing alcohol is suppose to dissolve and suppose to be safe
5 Suggested Answers
  • 50 Answers
SOURCE: Curve 8900 internal membrane!
the area under the track ball can cause this issue if itget's wet. Cleaning that area with a brush can sometime get it upand running again. Ifyou're out of warranty try to remove the trackball and clean the areabelow it if you see any residue from the water. There is a Blackberry Repair Guidethat shows how to open a Blackberry and remove the track ball yourself. Pretty much just pry the chrome ring off and take the track ball out.
Posted on Jun 17, 2009
SOURCE: Trackpad on Blackberry Curve 8520 has stopped
i had the same prob with my bb 8520 .. i have got this info 4rm a site n it waz a video telling u how to remove ur trackpad ... i have removed my trackpad according to the video n cleaned the sides n the trackpad .. n connected it carefully ..Now it works Perfectly ! its not hard but its risky .. n now have a look at the video ' http://www.youtube.com/watch?v=-HgLXRgedvI ' believe me it really works :D !
Posted on Apr 07, 2010
  • 846 Answers
Sounds like your trackpad needs replacement. The part is available on major auction websites for around $10. If you want somebody else to do it for you go to Blackberry Repair. If you want to do it yourself, here is an Blackberry 8520 Repair Guide that shows how to repair a Blackberry.
Posted on Jul 05, 2010
  • 10 Answers
SOURCE: my blackberry curve 8520 trackpad
try upgrading the Operating System, if it doesnt work you will need to take the phone in to a support center?
Posted on Mar 16, 2011
My blackberry 9320 is giving me jvm error 545
Hi George,
  1. Ensure the smartphone is running the latest version of BlackBerry Device Software (see http://support.blackberry.com/kb/articleDetail?articleNumber=000016068
  2. If the smartphone is already running the latest version of BlackBerry Device Software, perform a hard reset by removing the battery from the smartphone and reinserting it (see Article - http://support.blackberry.com/kb/articleDetail?articleNumber=000002141
  3. If the issue persists, reload the BlackBerry Device Software (see Article http://support.blackberry.com/kb/articleDetail?articleNumber=000010144
Jul 07, 2016 | RIM Blackberry Curve 9320 Smartphone -...
Blackberry trackpad not working
you can either change the tpad yourself or take it to a repair shop they are relativley in-expensive and not that difficult to change provided you have the correct screw drivers
Jul 26, 2014 | Research In Motion BlackBerry Curve 9320 -...
How can i fix my blackberry 9320 for keeping on starting itself
take the battery out for 20 seconds then turn it on, if this doesn't work you should do a hard reset
Mar 15, 2014 | RIM Blackberry Curve 9320 Smartphone -...
Free unlock code for blackberry curve 9320
Do you mean the network unlock code?I was not able to get a free unlocking service for the mobile model that you have specified.You can get the unlock code for your Blackberry Curve 9320 from unBBlock.com and remove the network lock easily.
Feb 23, 2013 | RIM Blackberry Curve 9320 Smartphone -...
Roller ball won't work
First Try to carefully clean the track ball with a q-tip dipped in rubbing alcohol, if that does not work see if the device is under warranty before trying this next step (verify warranty by calling carrier) take a small jewelry flathead screwdriver and remove the chrome piece from around the ball and clean the entire assembly with rubbing alcohol
Hope This Helps
William
Sep 22, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
My blackberry has problem with rollerball not responding when pressed
The balls get clogged with grease and skin from your finger over time. turn off the blackberry or pull the battery. Get rubbing alcohol and a cotton swab and rub the top of the ball getting off as much of the black as you can. Rotate it slightly and do the same until the entire ball is done. Then push quickly upward against the ball, downward, left, and then right several times in each direction.
Replace the battery, start the phone, and see how it works.
Apr 11, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
My alt button on the blackberry curve 8320 is stuck...when I do a battery pull the alt icon appears top right hand corner. I have the equipment to open up the blackberry and have to clean it out but still...
One method to fix where an electronic device has a stuck key is to thoroughly clean it with a high percentage isopropyl based rubbing alcohol and a cotton swab.
You may also try to reset your blackberry to factory defaults by following the steps in your user manual for a factory reset.
Nov 25, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blackberry 8300 trackball click button broken it scrolls not click
You either supressed the button under the ball in, and its going to need to be sent in for repair.
Or
Try this:
Rubbing alcohol and a cutip and rub it all over your trackball, if there is some dust that may have got caught under the button, hopefully the rubbing alcohol cleans this and releases the button.
Try it out let me know, Cheers,
Oct 22, 2009 | AT&T Blackberry Curve 8300 Smartphone
I have a trackball that is sticking on a blackberry bold 9000 how do you go about changing one out and is it the same size trackball as a curve
1. It is the same trackball as the curve.
2. Unlike the curve, where you can just pop the silver ring out from the front and the entire trackball comes out, on the Bold, you have to take the unit apart.
3. To take the bold apart follow these instructions:
http://www.youtube.com/watch?v=Yvs4VM5d_rk
4. Make sure that the contact underneath the trackball is not dirty. Take a QTip and some rubbing alcohol and clean the contact on the mainboard which makes contact with the trackball.
5. You can then replace the trackball from the curve into the bold, although, if you dont have a spare trackball, you can also clean the trackball with rubbing alcohol. To do this, I would put a solution of 50% rubbing alcohol and 50% distilled water (regular water is ok, but I prefer distilled). Shake it around (or better yet, use a sonic jewelry cleaner)and make sure to roll the ball around to loosen any dirt in the unit. Underneath the rollerball there is a little tab (that is called the spoon). Do not bend the spoon, rather make sure that the area between the spoon and the ball is cleaned out.
6. let everything dry and reassemble.
If you dont have a spare rollerball and want to buy one, There are many for sale on Ebay at around $5.
Aug 05, 2009 | RIM BlackBerry Bold Smartphone
RIM Blackberry Curve 9320 Smartphone - Black Logo
24 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
