Question about Pioneer TS-WX75A Car Speaker
Wiring harness
Where can I buy the wire harness at
Wire a aftermarket stereo to 1997 Lincoln town car without using wiring harness
Why would you want to do that? Go to crutchfield.com and buy a harness for $25 With or without JBL Sysyem?
http://www.crutchfield.com/g_103000/Vehicle-specific-Wiring-Harnesses.html?tp=2977 Vehicle specific Wiring Harnesses
Jan 30, 2015 | 1997 Lincoln Town Car
Clarion cz301e
You can purchase a harness adapter that will plug into the original radios harness. The other end of the adapter harness has loose wires with tinned ends which you connect to the new radio's harness, which as the same colors as the adapter wires.
  • Metra Model: 70-8901 is one adapter that I believe will work.
  • Scosche item Number: 16845632 is another adapter.
  • If you want to buy locally, Best Buy will probably have one or the other. If you want to buy on line, just do a search for the name and model numbers.
Subaru ForesterReceiver Wiring Harness
May 12, 2014 | 04-05 Sg5 Front Lip Ds-Style Urethane
I need to know which colour wire from the radio is for what, so i can fit a non standard stereo
My best advise is not to cut the stock wire harness plug. Go online or to your local best buy and buy a wiring harness that will plug into your stock plug and into the radio. then you don't need to know what any wires are. cutting the stock harness is opening a can of worms.
Dec 23, 2009 | Car Audio & Video
How to hook up the pioneer stereo to wire harness?
Not real clear on question, but you can buy a direct fit wire harness and the wires are color coded so you don't have to cut and splice your wires on your factory harness.The harness hooks to your factory plug and you wire it to your pioneer stereo wires. Harness is about 7.99 up at most stores.
Nov 03, 2009 | Boss RT-6CK Car Component System
Need help installing electric trailer brake controller
easiest way is to also buy the wiring adapter almost all elect brake units sell a vehicle specific wire harness that u unplug brake wire harness plug in other harness than plug in brake harness and just connect the wires to elect brake controller eliminates cutting and splicing ur brake harness about $18
Oct 25, 2009 | 1999 GMC Savana
Im puttin a new head unit with a different wire harness, i know what all the wires are on that wire harness, but with the 92 accord stereo wire harness i need to know which wires are speaker, remote, power...
You can buy a cheap harness from the local parts store for your Honda made specifically to put in aftermarket head units. Since you know the pin outs on your head unit, you can wire it up quickly uning this harness and it will plug directly into the factory Honda harness. Go to Scosche dot com part lookup for your number - I think the wiring schematic is on the outside of the package, too.
Apr 14, 2009 | 1992 Honda Accord
Color code for a dual xdma7715
You need to buy a ford wiring harness. They are about $22 at Best Buy. If you want to hardwire the unit to your car then you need to get the wiring colors from Ford. It is 100x times easier to just buy the wire harness.
Mar 24, 2009 | Dual Car Audio & Video
Installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Nov 21, 2008 | 2000 Pontiac Grand Prix
2002 Chevrolet Cavalier wiring harness for radio
absolutely not true. when you take your stock radio out of your vehicle there are clips in it and when u take the clips out and the antenna the radio is free when you buy an aftermarket radio from best buy or wherever it will come with a harness for that specific radio now wherever you buy the radio from they probably have a selection of wiring harness for specific makes and models you just buy that and when u take it to the clips installed in the cavalier it will just snap in then the wires on the radio harness will be color coded to the ones on your new harness good luck!
ps i recommend walmart to buy the harness its about $10 there..
Oct 27, 2008 | 2002 Chevrolet Cavalier Coupe
Pioneer TS-WX75A Car Speaker Logo
46 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
