Question about Brother MFC-9970CDW
Brother mfc printing pink stripes - Brother MFC-9970CDW
Soulvisitor
  • 1113 Answers
SOURCE: brother MFC-3220C
Error 41 is Print head needs to be replaced, on this model it is not a big job, Heads can be purchased from Brother dealers, ring brother to locate if you wish to repair this machine rather than replace it.
Head sells for about $80 for the part from a brother dealer 1-800-284-4329 and it will need a new set of inks too, not really worth it just replace with new machine with ink and a warranty.
Very common issue, brother extended warranty for this fault for two years but yours would be past it by now, the s/n tells of build date, the first two digits of the LAST NINE of the serial number indicate build date, so a K6J702822 ending serial no. means it was built K6 = Nov 06.
I beleive that this is a result a lot of the time by the use of refills and remanufactured ink cartridges being used.
There is heaps of info on net regarding "error 41".
Posted on Nov 15, 2007
  • 990 Answers
SOURCE: Black stripe down middle of page when copying
open the top cover on the left hand side glass plateform with a narrow piece glass clean it with alcohol.
Posted on Dec 13, 2008
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Posted on Mar 02, 2010
jay767
  • 386 Answers
SOURCE: brother MFC 465CN won't print due to "Unable to
Hi Good day!! try this method
1.pull out the AC plug
2.put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
3.now you are entering the MAINTENANCE mode and "error 46" pops up in the display
4.select 8 by using the arrow buttons ,push OK and select 0 and push OK
5.00:00 00:01 OK (the display is showing this message)
6.now push the MONO button 25 times until you see PURGE: xxxxx
7.Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
8.the purge counter indicates now: purge: 00000
9.switch off the printer ,switch it on
ready to print
Posted on Nov 20, 2010
~Brother MFC 3220c printing problem-o!~
clean the print head with water on a rag. it could need new cartridges also.
Sep 26, 2012 | Brother MFC 3220C All-In-One InkJet...
Hi.. My Brothers MFC-290C printer is printing in pink. I need it to print black
Have you tried to clean the printer heads? usually there is a software application that will offer the ability to clean print heads, align the printer, shows the estimated ink level. This sounds like only one shade of your color head is coming thru.
Brian
Mar 01, 2010 | Brother MFC 240C All-In-One InkJet Printer
Problem with my Brother MFC 210C Printer won't print the colors.
Check your ink cartridge if they are properly installed.
Check your print settings.
Make sure your ink cartridge are not empty.
Replace your ink with the original Brother ink cartridge.
Sep 08, 2009 | Brother MFC 210C All-In-One InkJet Printer
Everything prints in pink
have you checked the cartridge? check if someone is empty. else it can be a electrical problem.
Feb 24, 2009 | Brother Multi-Function Center MFC-240C...
Dec 13, 2008 | Brother MFC-7820N Printer
Brother MFC-215C
Greetings,
Do a head cleaning from the computer using the printer driver.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 17, 2008 | Brother MFC 420CN All-In-One InkJet...
MFC-9840 prints vertical stripe ~2" from right edge on all color printouts
The first thing i would try to do is clean the corona wire on the drum unit. It might also be a faulty magenta cartridge.
Dec 07, 2007 | Brother MFC-9420CN All-In-One Laser...
Brother MFC-9970CDW Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
