Question about Hotpoint WMA46 Front Load Washer
Hotpoint bw129 loud noise at high spin
  • 42 Answers
SOURCE: Hotpoint VBSR2080WOWW washing machine vibrates with loud noise
hi,
this is a generic problem with top-loading washing machines. when the distribution of load is not uniform, it gives sound when spinning. if it produces noise even after equal distribution of clothes, the problem lies in the suspension. this is not a major fault, and can be put up with, rather than spending dollars on fixing it. this will in no way cause any special wear and tear for the machine.
cheers
Posted on Jul 22, 2009
SOURCE: hotpoint first edition washing machine fault- full
mine was doing the same it was the bearings
Posted on Sep 23, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius wm64 loud banging noise when
Several possibilities here.
First and fore most is the drum support or main drum bearigs are failing., more likely to be drum support
The pieces of plastic you refer to are from inside the outer drum, because what is happening is the inner drum is catching the outer drum, and breaking the plastic inside.
You are going to have to strip it down to determine the exact cause, what I expect you will find is that the alloy 3 legged drom support has corroded away,a nd the drum has come loose.
Hope this helps you solve your problem
Posted on Nov 28, 2009
Testimonial: "thanks for the info i thought bearings if it is the drum support is it worth fixing machine is over 5 years old and used 3 times a day thanks again "
barkencoa
  • 3463 Answers
SOURCE: Very noisy when Hotpoint Aquarius WMA46 is on spin
It is the main drum bearings that is causing the noise.
There is no provision made for lubrication.
It can be done as a DIY fix, but it is a very involved repair, as it means having to remove the whole inner workings of the washer,
Not a task I would recommend unless you know what you are doing, and feel competent to tackle it.
Good luck.
Posted on Dec 05, 2009
Testimonial: "Great help. Thanks. I think I'll buy a pair of ear muffs"
machinetech7
  • 1344 Answers
SOURCE: hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Posted on Jun 16, 2012
Is it possible to change the bearings on this model?
sealed units are separate to the tub and drum
I would first remove everything down to the outside drum as the noise could be from an obstruction ( coin/s bra wire, metal objects etc)
At 3 years I would not expect bearing trouble in a sealed unit so explore all other avenues of the noise first
bearings will be noisy at all cycles and not specifically at high speed spin
before you touch it -check the warranty period and if inside that period call the technician
Feb 10, 2016 | Hotpoint Washing Machines
Hotpoint 1100 banging very loud when spinning,can thi be repaired please?
the chances are its the bairings in the drum that have gone,can you move the drum towards and away from the door easily? if so its prob the bairns,just like on a bike wheel they make the drum spin free but if they break it wobbles out of true causing problems and loud noise
Mar 19, 2013 | Hotpoint Washing Machines
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
Jun 15, 2012 | Hotpoint Washing Machines
Hotpoint WT965 is making a loud noise when spinnig
Suspect bearings. With door open wiggle the top of the silver drum If it moves up and down inside the tub, replace the bearings
May 15, 2012 | Washing Machines
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Good luck.
Dec 05, 2009 | Hotpoint Washing Machines
hi,
cheers
Jul 22, 2009 | Hotpoint VBSR3100D Top Load Washer
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Dec 30, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
24 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
