Question about Microwave Ovens
User manual for High Pointe 1.0 CU FT 900-Watt Built-In RV Microwave w/ Turn Table and Black Trim Kit
Need a users manual for a High Pointe microwave/convection oven
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Instruction book required for High-Point microwave/convection
Here's a roundabout way to help you:
You can find a different High-Pointe RV microwave owner's manual here.
That manual should have contact info to help you get in touch with High-Pointe to get a new one, or it may be close enough to your model to work for you.
Posted on Nov 25, 2008
tbreeze47
  • 3083 Answers
SOURCE: I have a High Pointe
Joe, I'm not sure that's the right model number, since I didn't get any hits on google. Make sure we have the correct number, so that we can help you. Will check back...
Posted on Sep 21, 2010
SOURCE: need instruction manual for Montgomery Ward
Sorry,i have no solution.was needing the same thing. my mother purchased this way back when
Posted on Aug 29, 2011
ZJLimited
  • 17970 Answers
SOURCE: I need to find a
Try to look in this link, just enter the three first letter of your model to find it: OperMan/findmanual.aspx?model=NN6
Or, additionally, could be interesting in check other THIS LINK here.
Hope helps.
Posted on Sep 20, 2011
How do you set the power level
If you have a power level button---press it and then enter 1-0 for 10. Most microwaves automatically come on at power level 10 or Hi power unless you pick a different option like the defrost button which is usually power level 3.
Mar 31, 2015 | Westbend 0.9-cu. Ft. 900-watt Microwave -...
Highpointe combo oven no instruction so have no way to use it can you help
Have you tried contacting Highpointe to get the user's or operator's manual? I suspect you have since I've looked and others seem to have the same problem. Is there any kind of contact information on the serial number plate or area?
If you can, call and ask them for one & tell them you never got one, or better yet, ask them why there wasn't a manual with the unit. That almost always works to get them to send one for free.
Ok, assuming none of this helps try this, I once could get no response from a manufacturer & after two weeks of trying everything I went on-line to search for the item. I found the web site of a supplier that was very positive about this particular item and so I contacted the supplier. The supplier helped me get in touch with the manufacturer and the problem was resolved to my satisfaction. Sometimes you need an intermediary and a reputable supplier is always a good one since they buy many items from the manufacturer in question.
I found this one for you but you can do a search as well, 800-776-6728 for Burnstine's Distributing. They had the following: High Pointe 1.0 CU FT 900-Watt Built-In RV Microwave w/ Turn Table and Black Trim Kit - Black (replaces EM925RSL-B) - call them & tell them your problem and see what they may be able to do to help.
Good-luck.
Jun 08, 2014 | Microwave Ovens
What is the wattage of a goldstar ma- 960m microwave
The Goldstar MA-960M (also 961M and 963M) is 850W, 0.9 Cu.ft. The MA-1080M (1081M and 1083M) is 850W, 1.0 Cu.ft; MA-1280M (1281M and 1283M) is 900W, 1.2 Cu.ft; MA-1523M is 900W, 1.5 Cu.ft. Source: Technical Specifications listed in original user manual for MA-960M.
Jan 31, 2014 | Goldstar MA-960M Microwave Oven
Need a replacment microwave oven (black) for a Dometic DOTR12C. It is built in to the RV and has the light and vent screen at the bottom, over the stove. Dimensions H 16 1/2 W 22 Depth 16 5/8 Weight 48#....
Pretty easy to change.Maybe cash and carry would be a little cheaper, or even trying an appliance dealer to see if they can get the same thing. Perhaps contacting manufacturer of microwave directly will help. (www.dometicusa.com) There was some recalls on some of the models. Are you sure it's not just sitting in an opening above the range hood. Most are just 4 screws or so, and out they come from opening above that.
Jun 02, 2010 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Turntable continues to run
This seems to be a pretty mysterious situation, and you're not alone in being concerned about an inability to find good contact information.
I would strongly suggest that you contact your RV dealer.
If the parts or service department cannot or will not give you good contact information on High Pointe, i would suggest insisting on speaking to the dealership's manager.
Please let us know what you find out so others can benefit.
Dec 23, 2008 | Microwave Ovens
Nov 24, 2008 | Microwave Ovens
Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Nov 21, 2008 | GE JE1640 Microwave Oven
Ihave high-pointe microwave oven serial #0604m00024 manufactured/ april2006 and listed 54nj has benlocked and idont know how to worked please hellpme
I also have a High Pointe Microwave Model EM925BSC SN 0608MO3508 manufactured in Aug 06. Tried to use it for the first time this weekend after buying a new Honda EU2000I to use it. The turntable does not turn automatically or when I try to turn it manually. Cooks OK. Nothing in the owner's manual that came with trailer (Zoom 178) mention how to fix the problem.
Anyone have a Ph# for High Pointe. Their Service center address is High Pointe, 2617 N Great Southwest Parkway, #100 , Grand Prarie, TX 75050.
Jun 26, 2008 | Microwave Ovens
Microwave Ovens Logo
144 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
