Question about Garden
I suspect a head gasket problem with the Tecumseh LEV 80-120 engine on my Toro mower. Can you tell me what the compression spec is on this engine? I have a compression tester but don't know the spec. Thanks!
5 Suggested Answers
  • 190 Answers
SOURCE: cylinder head torque specs
Cyl. Head Bolts torque
200in.lbs
16.5ft.lbs
22.5Nm
Posted on Mar 26, 2009
SOURCE: mower surging
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Posted on Jun 16, 2009
vincob
  • 718 Answers
SOURCE: where is oil drain plug on toro 22'' mower- tecumseh engine
IF you do not see the drain plug o the side of your engine, than most likely it is located on the bottom of the engine you will most likely have to remove the guard that covers the belt if you have self propelled lawn mower and the plug should be under the guard. Good Luck
Posted on Jul 18, 2010
  • 256 Answers
SOURCE: toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
Posted on May 17, 2012
Tecumseh low compression
if its low but has some remove the head and check the head gasket and valves
Jul 31, 2012 | Garden
I have a 2006 recycler model 20070 and am getting oil on the deck and it seems to be getting worse. Can it be a seal on the fill tube or something else? Also can you give me part numbers for what I...
If your Toro mower came equipped with a Tecumseh engine, then the dipstick seal is a common place for oil to leak. Look under the right side of the red plastic cover that is on top of the engine for an engine ID sticker. Take the model and spec numbers from the engine and go to either your local repair shop, or go to www.partstree.com for your parts. This is a simple repair and can be done with basic hand tools and mechanical knowledge. This is a good time to change to oil, too. Drain, replace gasket, refill.
Sep 12, 2010 | Toro Lawn Mower With Toro Power Tools
Replacing a tecumseh carburetor on a toro
PartsTreeRepairClinic may have a video
Jan 30, 2018 | Toro Garden
How to set up a carb with 31840 rebuild kit
what exactly do you want to know? Carb. mixture settings are as follows: L-head engines
Tecumseh carbs.........mainscrew 1 3/4 turns idle screw 1 1/4 turns
Walboro carbs........... mainscrew 1 1/2 turns idle screw 1 1/4 turns
L-head and OHV heavy duty engines 1 turns for both
Dec 21, 2009 | Toro Garden
BROKEN BRAKE PAD UNDER FLYWHEEL ON TORO LAWN MOWER THE ENGINE IS A TECUMSEH MODEL lev120 SPEC 361541b 195cc
If you had replaced the flywheel key & did not engage the saftey bail it would brake the brake. Make sure the bail is engaged befor installing the flywheel.
Sep 23, 2009 | Toro Lawn Mower With Toro Power Tools
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Cylinder head torque specs
200in.lbs
16.5ft.lbs
22.5Nm
Mar 26, 2009 | Craftsman Garden
No compression release; can't turn over
well if you can pinpoint the leak you may be able to repair it. if you test the compression in the engine you can tell if the rings or valve are bad. you need a specail tool to test compression, $45. let me know what you find
Mar 17, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
