Question about LG Lwhd8008r Air Conditioners
Unit won't turn on, the circuit board appears to be problem
I went to turn unit on, the digital temp started showing one number, and the correct number and i tried switching to cool from fan, it got stuck on power saver, tried switching back, no responce either on controls or remote.now it won't go on at all.
ngfam1
  • 639 Answers
SOURCE: Fan Works But Unit Can't Start Compressor
Friend,
NGFAM! Happy to assist you!
Sounds like the freon is low therefore it will not or stay on!
My words alone can not help you fix the unit!
You need service!
Let me know how it goes??
Please give me a good rating here at fixya.com before you sign off!
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF
Posted on Aug 29, 2008
  • 400 Answers
SOURCE: LG wall unit reads "Co" when I try to shut it off with remote.
Sounds amazing. Correct there is no Co error code, the closest to that is CL (child lock) or LOW meaning temperature below 18C. You can try to reset the remote by opening the cover, you will find a small button which needs to be pressed with a pen or sharp object. If that fails you may have to look at replacing the indoor PC board which has a bad processor
Posted on May 08, 2009
proton77
  • 1183 Answers
SOURCE: My Art cool was working
Are you getting any error message , on the display screen or its just completely a no power situation. The problem could be caused due to bad inverter or control panel . Would request to call up the service guy again so that he can check the voltages on the compressor. If the current is flowing the problem is with the control panel switch.
Thanks
proton
Posted on Jun 22, 2010
richroth
  • 9472 Answers
SOURCE: I HAVE A LG LSK243C-1
There are a lot of test variables to go thru for your unit. Since they are quite extensive, here is the service manual for your unit. It has a wealth of service information that will help you with the repair and any future problems you may encounter.
Happy Holidays The Fixya Team
Posted on Dec 17, 2010
  • 4736 Answers
SOURCE: I've got one single 12000 btu ac unit and one
Taking apart the hand held remote won't serve any real purpose as none of the parts inside are replaceable. Since you have 3 different units, with 3 different hand held remote. I'm wondering, if perhaps, you're using the wrong remote on that one unit. As each one has a different remote code.
In addition, I have learned from experience, that if the display screen on the hand held works, the problem is not in the hand held. Now, that's not to say, Operator Error can't play a role in it. But, most times, it's the receiver in the unit,that may be causing the problem. Or the hand held is to far away or something is blocking the signal in between.
Almost every appliance we sell, has a radio frequency remote control. The most problems we incur is with weak or dead batteries or operator error. The problem with batteries is that you don't now how long they sat in a warehouse, before making to a retail outlet and then how long they sat on the shelves there, before they were sold. They may have enough power to activate the handheld remote, but not enough to transmit a strong signal. So, check the strength of the new batteries you installed.
Hope this helps and thanks for choosing FixYa.
Posted on Jul 29, 2011
Won't start?
Good Morning Lisa - Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the dishwasher. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: wiring failure, damaged cord, faulty door latch assembly or control board. I would personally contact a professional to accurately diagnose the dishwasher to determine the root cause to reduce the risk of unnecessary parts.
Jun 13, 2013 | Electrolux Dishwashers
Cycle won't turn on
Good Afternoon Marcia - Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the dishwasher. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
May 26, 2013 | Frigidaire 24 in. FDB1050RE Built-in...
Omoron is not woking properly
Same problem on my Omron HEM-711. Manufactured in 2003, past the 5-yr warranty. Cust Suppt told me to replace unit. I opened the unit up and looked inside. Two very tight phillips screws, one on back panel, other in battery compartment. Case pries apart. LCD display looked intact, ribbon was undamaged. Unit appeared to work properly, just did not display correct reading, some of the liquid crystals in a few of the digits were not activating. I installed batteries with case still open, turned power on while pressing ribbon along edge of circuit board. Ribbon is manufactured with glue to circuit board, some of the leads come loose after several years due to manufacturing defect. In my case, pressing towards the bottom side corrected problem. You can see when it's working properly because all the display crystals light up simultaneously when unit is first powered up. I clamped down ribbon with two small paper clips insulated with a few bits of paper, works fine now, saved eighty bucks.
Apr 29, 2012 | Omron Health & Beauty
I have a self-cleaning older Frigidaire oven RE36BNL*2 and have had several power interuptions. I went to use the oven and the timer and oven controls won't work. There is an OFF displayed and it...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
The light went out an the turntable won't stop when I close the door...i tried to push clear, but it still turns. I couldn't find my model number on the below pull down, but my model is 721.8001...
721.80019401 (without spaces) is the correct model number.
If it was the cooktop lamp(s) that went out, I would suspect that it shorted, damaging the control circuit board.
We see and repair this problem on a regular basis with our $39.95 repair service.
Or you can order a new control circuit board (part number 6871W1S354A) for $75.80 from the Sears Parts Direct Web site.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 24, 2011 | Kenmore 80012 Microwave Oven
Some water dripped down from the floor above right on my receiver and it shut down. Now that it sat for a bit it turned on but won't go off headphone's even though no headphone's plugged in I...
When water spills on electronic products it causes corrosion to the circuit board and to the components in different circuits, unless you went inside the unit immediately after the water went into the unit and cleaned the effected areas some components and circuit traces have been already damaged and the longer the water sits inside the more damage it can do. Circuit traces may need cleanning and some capacitors or other components may need replacing because water is conductive and can create short circuits to diodes + trasistors, IC chips.
May 19, 2011 | Electronics - Others
OMRON Model Hem-711's display is messed up. Over one-half the top of the numbers are not showing. Is there a fix for this, or should I scrap it. I assume it an eternal problem in the window (Liquid...
Sep 05, 2009 | Omron HEM-711 IntelliSense Automatic Blood...
LG Lwhd8008r Air Conditioners Logo
13 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
