Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
Projection tv doesnt come on
My tv started going out alittle bit at a time, first it would go out for a few min. then for longer time now it don't work at all. ALSO alittle tv done the same thing, it came back on after awhile. For a year orso a limg on a oak tree was on the main power line out side. I called the power company 4 or 5 times for a year or more then the power transformer went out and the cut the lim off the pow line. The little tv works now but the big 1 doesnt. Can u help me, I think its the power supply. Do you know anyone in the Hickory area of North Carolina that can fix it, I'm disabled and need help bad. also the convergence is not good on 1 side. I have a 61" magnavox.
    President:
  • 3,130 Answers
You left so little information my friend, it will be impossible to help you. I did however find Magnavox home page where you can request service on your TV set. You will need to go to the link I leave you and on the right side of the page, click on request service. Then a customer service person should be able to assist you. All I can find from the info you left is that your zip is 28601. The Magnavox site should be able to help you. Good Luck, and I hope you get your set repaired. The link is http://www.usasupport.magnavox.com/productSelector.html
Posted on Aug 10, 2007
91 F150 Warm Start issue
egr passage plugged, for sure..
Dec 15, 2012 | Cars & Trucks
I am not sure what it is called but in the middle of the screen the picture is great but the further you go left or right the colors are not alligned they start off by only alittle bit but get...
You are suffering from a convergence problem. In this case I recommend you see a TV tech. To pull the convergence board is a real chore. Your convergence board will have too many bad grounds to even begin to count. You may not have to replace the convergence IC. The IC will be of a STK-393-110. In many cases this IC will be replaced by an after market part. You will have to check and replace resistors of a 2 watt value of about 3.9 ohms. In good faith, the TV man will replace this convergence IC ,as to try to correct the problem the first time. Good advice for the ,do it your selfer. Take this note to a TV tech. Some knowledge could save you a few bucks. Thanks for asking and show all hands of support!
May 04, 2011 | Mitsubishi WS-55819 55" Rear Projection...
93 won t start, clicking when i try to start... it started after sitting for a few days than now it won t don t know if its my starter battery or alternator
I would change all three. alittle expensive, but on this old of a vehicle I would not waste time and trouble. if this doesnt work then maybe some ignition problems. But i would guess that battery, starter, alternator, should do the trick
Mar 11, 2010 | 1993 Mercury Grand Marquis
TV stays on for few mins and then turns off
IF its the lamp for Lcd. Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Part # is xl-2200 found it here: http://www.discount-merchant.com/SearchResults.asp?Search=XL2200+?Click=48173 God bless you!
Nov 17, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Hln5065wx xaa TV will turn on for few min. then shut off. After unpluging system for 30 sec. I plug back in it comes on for a bit then the color will start to go them shuts down.If I do this a couple of...
- Check the back cover "Switch cover" located bottom right. Make sure it is plugged in properly to the digital board (big silver case board".
- could also be sighns of the light or color wheel going. Lights at the front will let you know with flashing sequence.
Robge
Oct 07, 2009 | Samsung HLN5065W 50" Rear Projection...
Model VS 50501A TV. Works fine for awhile then screen goes black
most likly its your lamp you just need to get a new one off the internet or you can bring it to a repair shop and they will be able to replace it for alittle bit more then the lamp itself will cost
Mar 14, 2009 | Mitsubishi VS-50501 50" Rear Projection...
TV keeps turning off.
could be a couple of things
first i would guess to be convergance ic then IC831S (STR-X6456).and could be loose connection.
you could try this to narrow it down, purchase a can of freeze at radio shock and spray it on these ic one at a time see if it stays on longer or just replace them
Dec 20, 2007 | Samsung HCN4226W 42" Rear Projection...
Automatically powers off, flashing red LED
try removing one neck board at a time and see if it stays on and longer,don;t let the board touch any metal or a short wil follow and you got problems.try the red first,
Sep 03, 2007 | Toshiba 43H70 43" Rear Projection...
Scrambling for first 15 mins
That is the exact problem I am currently having with my toshiba 50 in. I did some reading and it sounds like there is a temperature drift across one of the capacitors on the board and it takes longer and longer to warm up. Havent fixed it yet...
Mar 18, 2007 | Toshiba TP50H50 50" Rear Projection...
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
