Question about Hoffco TILLER PRO HOE WITH HONDA ENGINE
What kind of grease do you use in a pro hoe rototiller with a honda engine?
My rototiller is missing the data tag with Model and Serial No. The only id I have is the engine SN. Would like to identify engine mfg and Troy-Bilt tiller model.
Google search Troy-bilt Proline Tiller and search through the images to find the model most like yours. I believe the engine was built by Honda.
Good luck,
May 10, 2015 | Troy-Bilt Garden
Need to know where I can get parts for Honda engine pro hoe tiller with Honda engine
Try going into any of the web auctions I perfer eBay and put your model it will show a everything they have on your model..even dealers use this site..good luck..
Sep 30, 2014 | Garden
Have this rototiller without a manual and need to know about fuel
the mixture is usually on the machine somewhere--if not go the honda website and look up info for that model
May 08, 2010 | Honda 25cc 4-cycle Mini Tiller
Sears rototiller wheels locked up engine runs great
After taking the transmission/frame apart, the drive chain for the tires broke and wedged in the case. I cleaned the rest of the gear box and washed all of the gears and sprockets. Ordered up the chain, gasket and grease. I re-installed and greased all of the pieces and reassembled the case. I used a marine wheel bearing grease for the water resistant properties. I installed a zerk fitting right over the shifting lever. This should help keep the grease on the top end of all the gears. After a few hours it is good to go and works just like new.
Aug 20, 2009 | Craftsman Garden
Spark plug gap
All these engines have a magneto ignition. The faster the mag spins the higher (better) the sparkplug voltage. So the gap is only set for the ease of starting and is not a huge part of tunning as it is on a car. Try .020 inches.
Mar 21, 2009 | Garden
I am looking for fender for honda fg100 rototiller?
If It is a Honda FG100 like in the title the part number is 65141-V06-003
If it is a FG110 like in the description the part number will be 63411-V25-000 FENDER, RR. and 65141-V25-000 FENDER, FR.
Nov 24, 2008 | Honda Hmantis Mantis Garden Tiller with...
Hoffco TILLER PRO HOE WITH HONDA ENGINE Logo
43 people viewed this question
Top Hoffco Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Hoffco Garden Expert? Answer questions, earn points and help others
