Question about HP Touchsmart IQ524 PC Desktop
Error code 100c - HP Touchsmart IQ524 PC Desktop
How to change from Fahrenheit to celcius
formulas and examples here
http://albireo.ch/temperatureconverter/formula.htm
Mar 13, 2015 | Cars & Trucks
I am getting error code E000001-0002 in my IMAGE COPPIER 3545.... how to solve it
E000001-0002 refers to the fuser assy either getting to hot or not hot enough. Fuser error codes cannot be reset by power cycling the machine even though that is what the display tells you to do. In order to reset the fuser error code you must enter the service mode & reset the code. To enter the service mode:
press"Additional Functions" button (looks like a picture of a head with a star inside)
press the #2 and #8 at the same time (simultaneously)
press "additional functions" again
The display should show a choice of
copier,feeder,sorter,fax,or board service modes
Select copier
select clear
select ERR
press OK
Turn power off & back on.
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils at 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Dec 20, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
My canon ir 3300 showing error code E000007-0000 how can solve this problem
Here is what the service manual says about that code.
E007-0000 An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven.
Sounds like a problem that requires a service call.
Sep 20, 2014 | Canon Ir 3300 Black & White Copier
WHAT Cannon image runner 2525 ERROR CODE 000002
The main thermistor (TH1) has poor contact or open circuit. The thermal switch (TP1) has open circuit. The SSR is faulty. the DC controller is faulty.
The temperature of the fixing roller does not reach 100C with 2 min after it has exceeded 70C.
Apr 28, 2014 | Canon imageRUNNER C6800 Copier
Ir6000 error code e246-0002
Select copier
select clear
select ERR
press OK
****IMPORTANT****
After clearing error stay at the machine to see if it comes to ready. The fuser assy can reach 139 degrees C.(Water boils @ 100C) The error can only be cleared through the service mode because a technician should inspect the fuser to verify there is nothing faulty that could possibly start a fire. If you enter the service mode & clear the error, power cycle the machine & during warm up the machine throws a code again- turn it off, unplug it & call a tech for fuser repair.
Jan 11, 2011 | Canon Office Equipment & Supplies
Ineed micro webcam driver ic 100c
get it right here. http://www.driverfiles.net/Cameras/Micro-Innovations/page,level2,298,17,resultpage1.html
Aug 23, 2009 | Micro Innovations Webcam
Engine temp goes above 100c and fan does not come
look for and change the thermo switch ,it should be in the radiator
Mar 08, 2009 | 1993 Suzuki Swift
E 003 error code on power up
The code error is:
E003: After the temperature of the upper fixing roller has reached 180C, it drops to 100C or less for 5 sec or more.
Jan 09, 2009 | Canon NP 6085 Copier
Nextway NMP-100C (64 MB) MP3 Player
It looks like Nextway went out of business. So I found a driver at Driverguide.com that looks like it will do the trick. It's free to join and you have to join to download. This driver is for 3 models - including your model 100C. Here's the link for you.
NMP-100C
Nov 19, 2008 | Nextway NMP-100C MP3 Player
Nextway NMP-100c Player
Have you tried reformatting the memory? The command should be on the Erase menu.
Sep 10, 2007 | Nextway NMP-100C MP3 Player
HP Touchsmart IQ524  PC Desktop Logo
23 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
