Question about Coffee Makers & Espresso Machines
Rival brew thru coffee maker not brewing - Coffee Makers & Espresso Machines
2 Suggested Answers
SOURCE: One year old coffee maker won't brew
This is my second dcc-2000 with the same problem. I tossed the first one and in less than a year the second one exhibits the same issue. I called the Customer Service (1-800-726-0190). The rep told me to unplug the unit for at least 2 hours adding that this would let the system "reset itself". He then instructed me to run vinegar and water through it to clean the pumping system. I am doubtful about this solution but the rep assured me it would be replaced if I still have problems. It's worth calling CS to get it replaced, however, it seems that this model is flawed by design.
Posted on Aug 21, 2008
!0 Cup home Bunn. Does not brew the number of cups of water coffee (water) in craft. 8 cups of water 6cups of coffee.
If you don't brew often enough you will loose a small amount of water in the tank due to evaporation while the tank heater comes on and goes off to maintain the proper brewing temperature, so if it has been a while since you last brewed, without coffee in brew basket put a carafe of water thru the brewer, you will get less than a full carafe out because it fills the evaporated space in the tank first then uses the rest to brew. Once your tank heater shuts off usually 5 minutes on less you will get out all the volume you put in.
Oct 11, 2014 | Bunn 10 Cup Home Coffee Brewer
Brewer stops @ halfway thru airpot, will not let me adjust brew level
take front panel off and on timer board is a little switch. move it from on to 1 then hold breww switch till you hear 3 clicks
Mar 31, 2014 | Bunn CDBCF 15 Coffee Maker
Water coming thru coffee maker very slow
If the spray head is clean and clear and you have run the spring the the brew tube till you can push it almost all the way in (leaving only 1/4") then it should not have issues.
Dec 29, 2012 | Bunn NHB Coffee Maker
How to set the timer
You can download the manual direct from Rival
http://www.rivalproducts.com/product.aspx?pid=2404
This model does not have a timer listed as one of its features.
Rival® 12-cup Coffee Maker FEATURES:
  • Brews 12 (5 oz.) Cups
  • Removable Filter Basket
  • Easy Pour, Non-drip Carafe with Ergonomic Handle
  • Water Level Indicator in Tank
  • Pause 'n Serve Function
  • Convenient Cord Storage
  • Non-stick Warming Plate
  • English & Spanish instruction manual
Mar 07, 2011 | Rival Programmable 12-Cup Coffee Maker
Will not brew
mcdevito75 here, Your coffee maker may need cleaning, if so, fill the resovoir with WHITE VINEGAR and cycle thru 3 times, have clean or new filter in the machine, on the 3rd cycle stop machine for 30 minutes then resume, cycle thru2=-=3 more times if needed, after the vinegar cycle change filter or clean and cycle thru plain water 2--3 times or more to rinse out the vinegar.
Jul 10, 2010 | Kenmore KBC12 Coffee Maker
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. Coffee.com or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
KeurigB50 Coffee Maker will not brew. Gets to the
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
My GE coffee maker is very slow making a pot of coffee I need to clean it. Its digital
run some vinegar thru it a couple of brews and see if this speeds up the water, you will want to run a third brew of plain tap water to rinse vinegar taste out
Oct 02, 2009 | Coffee Makers & Espresso Machines
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
14 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
