Question about Dell HP-150SS (HP150SS) 150-Watt Power Supply
150 W ATX Power Supply HP-150SS
How can start this whitout pc ? This is not a normal psu , is a DELL.
  • FIX-IT_EE Jan 02, 2008
    tried it on my BesteC atx-250-12E. Shorted the green to the black as you showed. NO voltage out on any connector and no fan spinning. Thanks. Fuse internally was still good.
    This was from an emachine desktop.
    Thanks though!
    Ted
    [email protected]
    Welcome Back:
    Visited the website for 2 consecutive days.
Hi...i just bought a okia atx power supply 450 w...and when i turn it on....the pc dosnt turn on or the fan on thr okia dont turn on either.im puting it on a e machine t2824 intel celeron. what can i do?to fix this problem...thank u,jaime
Posted on Mar 13, 2008
Try a 10 watt 10 ohm resistor across the 5 volt wire red or an orange and to a black, they need a minumum load to work, also you need to tie the grey (power ok to and orange3.3v)
Posted on Feb 21, 2008
To identify section of smps and parts
Posted on Dec 05, 2007
I´m afraid the HP-150SS has a propietary configuration. I have one defective unit (there´s no GREEN wire on it), and researching how to fixit I found this: http://www.roboternetz.de/phpBB2/zeigebeitrag.php?t=6924 It´s in german, but doesn´t matter, check the last picture, it shows the Power On location. Good luck Sazabius
Posted on Oct 10, 2007
I have Dell CPU and the power supply is defective This is the model number of the power supply Ps-5201-5D. i want to replace it with other power which is a standard power supply, is that ok? Is my CPU will work? Thanks from Renato
Posted on Aug 30, 2007
    President:
  • 2,961 Answers
All you have to do is connect the green wire (normally thinner than the rest of the cables) to any black wire. This can be done easily with a short piece of wire. If the power supply doesn?t immediately turn on (within 2 seconds) remove the wire, you may have connected it to the wrong wires, although most power supplies won?t allow a short to damage the unit. Once on, the power supply isn?t loaded so the voltages won?t be as stable as if they were used in a full PC, however it?ll be sufficient for most uses. It?s not a good idea to leave a power supply on in this fashion for a long period of time too."
Posted on Aug 10, 2007
  • andrew pester
    andrew pester Aug 10, 2007
    The Dell PSU should be no different from other units as they all connect the same way to the motherboard, although 150W is very low for todays needs.
2 Suggested Answers
SOURCE:
Pinouts power supply for hp d530 ultraslim
Hi lantzgema,
I looked up the specs of your d530 and all I could find out is that you have a 150 power supply, calling HP technical support was no help at all.
I did find some pinouts you can look at and determine which one exactly you have. Hope this help out.
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm
http://pcsupport.about.com/od/insidethepc/a/sata-pinout-15-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/molex-pinout-4-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-4-pin-12v-psu.htm
If this is still not what you have there are other pinouts at the same website.
Dec 28, 2010 | Computers & Internet
I have a burned out Bestec ATX-250-12z power supply for a hp pavilion a320n. I need to know if a Dynex® - 400-Watt ATX CPU Power Supply, will work in its place.
yes it should do provided your current psu is not a small mATX one. ATX power supplies are pretty generic. Make sure you get one that has enough connectors to suit your system, having said that, Considering it's an off the shelf PC I would guess most PSU's would have the right number and type of connections.
Jan 10, 2010 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
The pc wont power up and the green led on the PSU is just flashing, is the bestec atx 250 12z broken?
Most likely yes.
I would also reccomend an upgrade to that PSU when replacing it.
Something in the 450-Watt neighborhood is usually a bit more robust.
Oct 15, 2009 | HP ATX-250-12Z, ATX-250-12Z REV.: D2, HP...
What is the 6 pin
You can replace the power supply in this Dell with a normal ATX power supply. Make sure the total wattage is equal to or greater than the old power supply.
Oct 02, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Hp compaq dc 7100 psu 24 pin SLIM LINE
why wont you buy a new power supply or a plug that converts from a 20 pin to a 24 pin
Mar 31, 2009 | HP Compaq dc7100 PC Desktop
Need to replace the power supply on a m370n hp pavillon
A normal ATX power supply will work for your system. When purchasing make sure it is an ATX style psu. Hope this helps & please remember to rate my answer. Thanks.
Dec 28, 2008 | HP Media Center M370N (DM163A#ABA) PC...
HP-150SS
Hello diallo
Do you mean which wire is the +5VDC on?
There is an industry standard for coloring of computer power supply wires.
+5VDC is on the RED wires.
HERE is a link on Computer Power Supplies "ABCs" that will be very helpful to you, I think.
Please, let us know if this response was helpful for you or, of course, if you have any further questions.
Thank you
BJ
Apr 03, 2008 | Dell HP-150SS (HP150SS) 150-Watt Power...
Compaq power supply HP212 (old)
If connector have two big brown wires (pins 1 and 11) and a small brown wire (pin 2). then short circuit the small brown wire with a big brown wire (pins 1 and 2).
Also short circuit the small black wire (pin 16) with a big black wire (pin 17).
Ps. The Power Supply needs a minimal load ex: 1A.
Dec 04, 2007 | Dell HP-150SS (HP150SS) 150-Watt Power...
Computers & Internet Logo
1,207 people viewed this question
Ekse
Clive
Clive
