Question about Husqvarna Garden
Shoots flames from carb - Husqvarna Garden
  • Husqvarna Master
  • 1,807 Answers
Carb flames are causes by a couple of things. Most often the engine is advanced to far or you have a carb leak interally that puts to much fuel in the engine.
Posted on May 06, 2013
Runs good for 10 minutes.then shoots flame out of carburetor then dies with no compression
Hi Leroy:
Sounds like one wicked chainsaw!
- Flame out of the carb is usually not visible. Are you running this with the air filter removed? Considering the dust associated with chain saw operation, that's not a good idea.
- No compression is usually an indication that the saw has overheated and the rings have failed or the piston is damaged.
Is this a repeating problem or is the saw now dead with no compression?
Make and model would be some help for us to troubleshoot.
Please reply by comment to this post.
Cheers.
Dec 02, 2015 | Garden
Gsxr 750 shoots flames
If the bike was running correctly when it was put in storage two years ago, I would start with the easy things first: As the previous poster suggested, install new, correctly gapped plugs, along with a new battery. Your bike uses an electronic ignition system, and it will not opporate correctly if you have a bad battery. The bike will miss, pop, and backfire, because there is not enough electrical power in storage (battery) to properly run the ignition system.
If these two things do not get the bike running correctly you will need to look at the carbs. Was the bike stored with fuel in the tank and carbs? If so, this is the most likely reason for the bike not wanting to run correctly. Flames from the exhaust are an indication of a very rich fuel/air mixture (a float could be stuck open (it can also be caused by the ignition not working properly and allowing unburnt fuel into the exhaust system)). Cleaning and reassembling mulitple carborators is not that difficult if you are careful and reasonably handy, but tuning them properly can be very difficult. You can save a lot of money if you rebuild them yourself, then take the bike to the shop to be tuned (The standard service rate these days is around $75 an hour)
Mar 23, 2014 | 2000 Suzuki GSX-R 750
Backfire
Check no split in exhausted
Jun 23, 2013 | Harley Davidson Motorcycles
I have a 1995 dodge caravan with 3.0 engine that is not getting fuel. i have replace the fuel pump and the relay and the fuse is good also. what am i missing that i need to check?
If you can pull the fuel line, past the fuel pump, off, turn the motor over to see if gas shoots out of the fuel lines. If it doesn't your fuel filter might need to be changed. Also try to see if your getting fuel past the filter useing the same method.After that pull your air filter off so you can look into the carb to see if fuel is being pumped to the carb. Be careful if the car backfires thru the carb. it can catch fire and the flame will pull the gas to the carb and it will keep burning and get bigger and hotter. I had this happen and I just stuck a shop rag in the carb and put the flame out. Don't burn your car up, your house, your self etc.
Sep 03, 2010 | 1995 Dodge Caravan
When letting of throttle it shoots out some flames? bike runs fine no problems.
this is unburnt fuel in the exhaust causing back fires this is due to to much fuel being let in on the carb there is a mixture screw screw it in 1/4 of turns and see if it improves if noit screw it in another 1/4 of turns a picture below will locate it cb0168d.jpg
Aug 26, 2009 | 2000 Harley Davidson FXD Dyna Super Glide
Generator hard to start and backfiring
Sound like you've done things in the correct order, tecumseh's are notorious for carb problems if you let as sit in them. Backfiring is timing related (flywheel key) or valve problems. I would take a closer look at the exhaust valve I don't believe it is closing all the way.
Mar 16, 2009 | Coleman Powermate Powermate 5000W...
Hard to start and backfires from muffler when running
Sounds like the timing may be off or maybethe exhaust valve maybe hanging open.
Mar 15, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
1984 Ford Bronco, engine problems
Yeh, I would say it's out of time. After you time it, and it still does it, check for a bent or broken push rod.
Mar 10, 2009 | 1987 Ford Bronco
Replaced stater,put bike back togeather, and now have flames
If you're seeing fire coming out of your pipes, you need to adjust your timing and lean out your carb. It's running too rich.
Nov 17, 2008 | Harley Davidson XLH 1000 Sportster...
Garden Logo
24 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
