Ga k8vt800 my Ga-k8vt800 motherboard works with a 256 momory stick but i tried to upgrade to 2gig but wont read the memory computer wont come on when it does it pops up with bootlock bios checking hard drive any help would be nice
Daholk
  • 41 Answers
SOURCE: im not sure how much ram to use with my motherboard.
Your board can support 4Gb of RAM.
CLICK HERE for the SPEC sheet.
HERE is the memory support list, there is only 1 type of KINGSTON 2GB stick that is listed as compatible.
Make sure you have the latest BIOS as there are some known issues with this board and certain 4GB RAM configs as well as fixes for 1TB HDD space errors.
Always a good idea to make sure you have the latest XP service pack. In general, XP only recognises 3Gb RAM but mine runs fine with 4 in it.
When you crash, is there any Blue Screen of Death (BSoD) or any other output to your monitor or does it just shut down with no warning or error code or anything? If this is happening then you may be getting a CPU OVERTEMP condition.
Have you recently upgraded other components as well as your RAM?
Posted on Mar 26, 2009
wwjdcgh
  • 114 Answers
SOURCE: GA-8pe800 pro and kvr333x64c25 memory problem
the 1g is defective return it and get a replcement
Posted on Mar 28, 2009
  • 7 Answers
SOURCE: Gigabyte GA-8VM800PMD-775 @ 1.5gb memory
http://america.giga-byte.com/FileList/Manual/motherboard_manual_ga-8vm800pmd-775_e.pdf
Before installing the memory modules, please comply with the following conditions:
1. Please make sure that the memory used is supported by the motherboard. It is
recommended that memory of similar capacity, specifications and brand be used.
2. Before installing or removing memory modules, please make sure that the computer
power is switched off to prevent hardware damage.
3. Memory modules have a foolproof insertion design. A memory module can be installed
in only one direction. If you are unable to insert the module, please switch the direction.
1-4 Installation of Memory
The motherboard supports DDR II memory modules, whereby BIOS will automatically detect memory
capacity and specifications. Memory modules are designed so that they can be inserted only in one
direction. The memory capacity used can differ with each slot.
Posted on Jun 06, 2009
  • 85 Answers
SOURCE: GA-8s648fx scanning bios image in hard drive
update the bios of motherboard, it seems that the bios file is missing somewhere and now the computer bios is searcing for it ..(on Hard drive)
so reinstall or update the bios it will fix the prob. otherwise if u say that the bios is working ok, then go to the bios and turn them to their Defaults, and restart.
good luck
shafky
Posted on Jun 20, 2009
  • 433 Answers
SOURCE: flashed bios wont boot ga-ep43-ud3l
Seems like your bios update failed, was corrupt, wrong version or was interrupted.
It's very difficult to recover from a failed bios flash , but if you are lucky you can try clearing cmos then take the battery out overnight. Then reinstall battery and do a HARD BOOT.
If that does not work try this site and read recent comments.
http://ask-leo.com/flashing_my_bios_failed_how_can_i_recover.html
Good luck,
Hank
Posted on Jul 23, 2009
Descargar diver de video compatible vga .Gigabyte GA-K8VT800 Motherboard
Hello you can download the driver here:
http://www.gigabyte.com/products/product-page.aspx?pid=1709#dl
By selecting your windows system.
But here are other models, of your mainboard:
http://www.gigabyte.com/search/search.aspx?kw=GA-K8VT800#pr-1
If the driver did not fit, select the right mainboard.
Good luck
May 18, 2012 | Gigabyte GA-K8VT800 Motherboard
Hi i just put a new ga k8vt800 rev 1 board and i need too now how to wire it to come on
What you need to do is look for the Power Wire coming from the front of the PC. It will probably say something like PWR BTN on it. It will be two wires twisted together. Now on the bottom right of your motherboard there will be pins sticking up, probably about 12 of them. 2 of the pins will have a label printed on the motherboard that will say PWR BTN. Just plug those in hit the power button on the front.gwidmeyer.jpg
Jan 13, 2011 | Gigabyte GA-K8VT800 Motherboard
My pc was working fine with 128 + 256 ram. few days ago it didnt boot.it was restarting automatically. then i removed 256 ram and it booted normally.means pc works normally with 128 ram but not with 256...
i guess u have 2 different RAM cards in the RAM slots....
the main issue is both dont work together...the primary reason is compatibility....or one of the RAM cards have worn out...
u must use exactly similar kind of RAMs in both slots....
i suggest u use one 512 MB if your motherboard supports....
RAM technology has advanced so mush that you wont get RAMs for old PCs (motherboards)....so u decide...
pls revert back...and kindly leave a feedback and rating for this solution...it will help me move to Guru" here from Expert at Fixya....
regards...
Sep 29, 2010 | Gigabyte GA-8I845GV Motherboard
Video controller ga k8vt800 not support
You can download the drivers from Gigabyte WEB support site, select your model motherboard to download :-
http://www.gigabyte.com.tw/support-downloads/support-downloads.aspx
Sep 18, 2010 | Gigabyte GA-K8VT800 Motherboard
Upgrading an OS on a GA-7VRX now orange LED and will not boot
Sounds like you've stressed the memory out during the upgrade, try just 1 stick at a time and see how that goes......please let me know ....cheers from Scott
Apr 14, 2010 | Gigabyte GA-7VRX Motherboard
What RAM to use. I would like to use 1600mhz RAM but am not sure what would be the best to use. I am installing 12gb of ram. I will install 6gb now and another 6gb later.
Memory  6 x 1.5V DDR3 DIMM sockets supporting up to 24 GB of system memory (Note 1)
 Dual/3 channel memory architecture
 Support for DDR3 2100/1333/1066/800 MHz memory modules
(Go to GIGABYTE's website for the latest memory support list.)
and
Memory support list Date Subject 2005/05/12 Recommended memory module list for GA-8I915P Duo Pro ...More 2005/03/01 Recommended memory module list for GA-K8VT800 (Rev 2.0) ...More 2005/02/21 Recommended memory module list for GA-K8NF-9 ...More 2004/12/13 Recommended memory module list for 8I845GE-RZ/C ...More 2004/10/15 Recommended memory module list for GA-8TRX330-L ...More 2004/09/02 Recommended memory module list for GA-8TRS350MT ...More 2004/03/22 DDR400 support list for FSB800 CPU support - GA-8IE2004P \ 8IE2004P-L ...More 2003/12/23 PC3200(DDR400) Recommended module list for GA-8TRS300M ...More 2003/11/28 DDR400 support list for FSB800 CPU support - GA-8PE800 \ 8PE800-L ...More 2003/10/16 Recommended DDR400 (PC3200), DDR434 and DDR466 memory modules for GA-SINXP1394 ...More 2003/10/02 Recommended DDR200/266/333/400/466 Memory support list for GA-K8NNXP ...More 2003/07/23 Recommended DDR333(PC2700) memory modules for GA-8S650GXM-P (-C) ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SQ800 Ultra and 8SQ800 ...More 2003/03/18 Recommended DDR400 (PC3200)memory modules for GA-8SG800 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-8SG667 ...More 2002/10/30 Recommended DDR400 (PC3200)memory modules for GA-7VAXP Ultra, GA-7VAXP, GA-7VAX, and GA-7VA ...More
Dec 27, 2009 | Gigabyte GA-EX58-UD5 Motherboard
Wont boot
i think the cpu may have a problem with the board or the memeory. either its bad, damaged or incompartible with your system. try out another cpu
Mar 24, 2009 | Gigabyte GA-K8VT800 Motherboard
ADA3700AEP5AP 3700 Clawhammer wont boot
I believe that it should work with that chip. If you have the manual for the MoBo try resetting the cmos on the board. That should put every thing back to its defaults. It is posable that it is trying to run it at the wrong voltage.
Feb 29, 2008 | Gigabyte GA-K8VT800 Motherboard
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
