Question about Clarion DC625 6-Disc CD Changer
Clarion xw1f18c830ab wire diagram
Pin configuration
SOURCE: clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Posted on Apr 15, 2008
SOURCE: Need wiring diagram of connectors for Clarion
you can usually go to the site and put in the model # and request owners manual. it is in there but you need to have adobe reader.
Posted on May 09, 2009
  • 77 Answers
SOURCE: WIRING DIAGRAM
red is ignition power, or power when you turn the key on. yellow is all time power. yellow keeps power all the time, this keeps your presets and clock settings saved. black is ground. once you have then hooked up you will be able to figure out your speaker wires by trail and error, they my be green/green black, purple/purple black, white/white black, ect, but these are your speakers. Once you get the power on it should be no problem to figure out the speaker wires.
Posted on Jun 21, 2009
  • 20 Answers
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
Posted on Aug 11, 2009
SOURCE: clarion db165, need a wiring diagram
i have a clarin db165, and i need a wiring diagram or color sheet.... please! i've looked a;; over the internet with no luck.
Posted on Aug 30, 2009
My network setup is asking for a pin number that is on my router. Obviously there is no pin number for this particular router and my network is asking for a 4 or 8 digit number. What do I do?
If its asking for a pin number I would check the sticker on the bottom of the router. it may have the router PIN you are looking for. If not trying typing in your internet browser address bar 192.168.1.1 and find the network settings and see if there is a pin set up, if so write it down or clear it to have no PIN
Feb 28, 2011 | Linksys Wireless-G WRT54G Router
I received a message about configuration wen i press enter it shows to enter pin number but i dunno what to enter i tried my pin number for mob but it didn't go thru i tried 1234 n 0000 but in vain wat...
Check the operator web page for Configuration settings, you should find the PIN there or Call the customer service, only them knows the PIN for the configuration messages.
Nov 02, 2010 | O2 Samsung SGH-E250 Cellular Phone
I have an old Magellan Meridian XL that has the power cable missing and I cannot locate another cable. Anyone know the pin configuration so I can make up a cable ? Power only, no data in and out.
Hi yakabofski!
There are TWO configurations of the pins with these units. We have the FIVE-pin config and the assignments are as follows:
Top pin- 12v
Bottom pin- ground.
Hope this helps.
Apr 06, 2010 | Humminbird Fishing GPS Receiver
Device asks for passphrase or pin, what is this,(zoom 3g router)
The passphrase is used to generate the encryption code in the router's wireless configuration.
For instructions to configure the router's wireless settings ant to configure the wireless card in the laptop/computer - please click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jan 03, 2010 | Zoom Computers & Internet
Need master slave configuration
You should have a jumper configuration written somewhere on the front (up) side of the hard Disk ... Look there, or look just around the Pins... Look for M, S, CS (Master, Slave, Cable Select)
Darko, Serbia
Mar 20, 2009 | Western Digital 60GB U100 5400RPM 2MB...
P4 motherboard power pin configuration
Order you a schematic online for your TV.Cost $45.00 and some cost as much as $150.00
Feb 17, 2009 | Samsung HCL4715W 47" Rear Projection...
Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Oct 13, 2008 | Computers & Internet
VGA Pin Configuration
Pls find below the Pin configuration.
Pin 1 - Red Signal
Pin 2 - Green Signal
Pin 3 - Blue Signal
Pin 6 - Red Ground
Pin 7 - Green Ground
Pin 8 - Blue Ground
Pin 10- Horizontal Ground
Pin 11- Vertical Ground
Pin 13- Horizontal Signal
Pin 14- Vertical Signal
Best Wishes
Jul 22, 2008 | Samsung 793S 17" CRT Monitor
Switch settings on stanley garage door opener
check the pin configuration on the back of the Stanley 3200
Jul 12, 2008 | Electrical Supplies
Clarion DC625 6-Disc CD Changer Logo
73 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
