Question about Salomon SPX Pro Snowboard Binding - Mens
Mounting plate lost my mounting discs.. where could i get new ones??
Can a pressure plate be resurfaced or should I just get a new one
Pressure plates are no to be resurfaced. They cannot be mounted in any way to ensure trueness when attempting the operation. Also the material is normally too thin to allow for it. Replacement clutch kits come come complete with clutch disc, pressure plate, and release bearing. Considering the effort involved in the removal and replacement of the transmission, it is foolish to skimp on these parts as the labor to do it again later will negate any savings you may obtain now.
Aug 25, 2016 | Cars & Trucks
I need to replace a wall mounted microwave oven. It needs to mount only to the back plate - there is no access to mounting holes in the top. I have replaced this oven once before, but now I cannot find a...
I just replaced one of those myself. New one had totally different back plate which had to be replaced. Both new and old ones were bolted to cabinet above.
Oct 29, 2013 | GE JEB1095 Electric Single Oven
How to install a clutch kit on my 1994 mitsubishi mighty max
Disconnect the battery, disconnect the Hydraulic Line from the Slave Cylinder, Remove the Starter (2 bolts, 2 wires. Bolts are 14mm, 1 wire is 12mm, 1 plugs in), Remove the Driveshaft(s) (4 12mm bolts) Remove the 6 bolts from the bellhousing (4 are 14mm, 2 are 10mm)
Remove the bolt from the Transfer Case Mount, 12mm (only if it's a 4WD, if it's 2WD this doesn't apply), remove the 2 bolts that hold the Transmission Mount to the Crossmember (12mm or 14mm, it varies)
Slide the transmission back on the crossmember, away from the engine, I recommend running a ratchet strap across the frame to balance the transmission.
Remove the Pressure Plate from the Flywheel (Six 10mm bolts), Inspect the Pilot Bearing (if it needs replaced, you'll need to remove the Flywheel which is held on with six 18mm bolts, drive out the old bearing and drive in the new one, reinstall the flywheel, using Threadlocker on the bolts, torque the bolts to 100 ft lbs) Install the new clutch disc and Pressure Plate, with the centering tool inserted through the disc into the pilot bearing. Use thread locker on the pressure plate bolts and torque them to 20 ft lbs. Remove the centering/alignment tool after you've bolted it together
Remove old Throw Out bearing from input shaft on the transmission and slide the new one on. Slide the Transmission forward (make sure the input shaft slides into the pilot bearing, don't force the transmission into place or you could damage the clutch disc or break the input shaft) Torque the Bellhousing Bolts to 40 ft lbs (4 14mm bolts), Torque the 2 10mm bolts to 14 ft lbs, Install the Starter (torque bolts to 23 ft lbs), Reconnect Hydraulic Line to Slave Cylinder. Torque Transmission Mount Bolts to 30 ft lbs.
Reinstall Driveshafts, torque bolts on flange/yoke to 40 ft lbs. Fill Clutch Master Cylinder with DOT-3 Brake & Clutch Fluid, Open Bleeder Screw on Slave Cylinder and bleed the air out of the system, close bleeder screw.
Reconnect the wires to the Starter, Reconnect the battery.
Aug 24, 2011 | Mitsubishi Mighty Max Cars & Trucks
We have burnt the clutch out and are wondering how hard it is to put a new one in?
This requires you removing the cv shafts, taking loose the engine/transmission mounts, unbolt the transmission from the engine, removing the transmission, taking the pressure plate and clutch disc off the flywheel on the engine, then putting everything back once the new clutch parts are put back on. Looking a day of work to complete.
Feb 09, 2011 | 1995 Ford Contour
Need a copy of the manual pages, showing how to replace the clutch
Removal & Installation To Remove:
  1. Remove the transmission.
  2. Install a flywheel locking tool.
  3. Remove the pressure plate mounting bolts from the flywheel.
  4. Remove the pressure plate and clutch disc.
To Install:
  1. Insert a clutch disc alignment tool through the disc splines and into the flywheel pilot bearing. Pressure plate balance mark location subaru-07-00-6722.gif
  2. Install the pressure plate on the flywheel with a gap of 120° or more between the "0" balance marks on the flywheel and pressure plate. Hand tighten the pressure plate mounting bolts.
  3. Tighten the pressure plate mounting bolts using a crisscross pattern 12 ft-lb (16 Nm).
  4. Remove the clutch disc alignment tool.
  5. Install the transmission.
Dec 28, 2010 | 1998 Subaru Legacy
Disc Error on Goodmans ghd8015f2.(Freeview HD Digital Recorder)
Yes, you can install another 80GB Hard Disk Drive.
The copper plates can be fitted to the new hard drive.
You can format it FAT or NTFS.
Nov 25, 2009 | Computers & Internet
How to fit a new clutch into a ford escort 1300cc 1994
1991-96 Models
See Figures 1, 2 and 3
  1. Disconnect the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Remove the transaxle assembly.
  4. If the clutch assembly is to be reused, matchmark the pressure plate and the flywheel so they can be assembled in the same position.
  5. Install flywheel holding tool T84P-6375-A or equivalent, in a transaxle mounting hole on the engine and engage the tooth of the holding tool into the flywheel ring gear.
0900c1528008df86.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Install a flywheel holding tool in a transaxle mounting hole on the engine, and engage the tooth of the tool into the flywheel ring gear
  1. Loosen the pressure plate-to-flywheel retaining bolts one turn at a time, in a crisscross pattern, until the spring tension is relieved, to prevent pressure plate cover distortion.
  2. Support the pressure plate and unfasten the retaining bolts. Remove the pressure plate and clutch disc from the flywheel.
If the flywheel shows any signs of overheating (blue discoloration) or if it is badly grooved or scored, it should be refaced or replaced.
  1. Inspect the flywheel, clutch disc, pressure plate, release bearing, pilot bearing and the clutch fork for wear. Replace parts as needed.
To install:
  1. If removed, install a new pilot bearing using a suitable installation tool.
  2. If removed, install the flywheel. Make sure the flywheel and crankshaft flange mating surfaces are clean. Tighten the flywheel retaining bolts to 71-76 ft. lbs. (96-103 Nm) on the 1.8L engine or 54-67 ft. lbs. (73-91 Nm) on the 1.9L engine.
  3. Clean the pressure plate and flywheel surfaces thoroughly. Position the clutch disc and pressure plate into the installed position and support them with a dummy shaft or clutch aligning tool. If the clutch assembly is being reused, align the matchmarks that were made during the removal procedure.
  4. Install the pressure plate-to-flywheel retaining bolts. Tighten the bolts in the correct sequence to 13-20 ft. lbs. (18-26 Nm). Remove the alignment tool.
0900c1528008df87.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Position the clutch disc and pressure plate into the installed position and support them with a clutch aligning tool
0900c1528008df88.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: Tighten the pressure plate-to-flywheel retaining bolts to specification in the sequence illustrated
  1. If the release bearing was removed, lubricate the release fork where it contacts the bearing and install the bearing in the fork.
  2. Install the transaxle assembly.
  3. Lower the vehicle.
  4. Bleed the hydraulic clutch system, if needed.
  5. Connect the negative battery cable.
  6. Road test the vehicle and check the clutch for proper operation.
Sep 30, 2009 | 1994 Ford Escort
Lost mount for tripod can I get a new one?
Velbon QB-4W Quick-Release Platform is a nearly identical replacement for the plates that come with the Dynex tripod. You buy it from:
http://www.amazon.com/s/?ie=UTF8&keywords=velbon+quick+release&tag=googhydr-20&index=electronics&hvadid=3155273537&ref=pd_sl_6aoq8ub9ut_b
Apr 28, 2009 | Cameras
I need a new plate for my Acme 6001
http://parts.livingright.com/item97.html
Jan 25, 2008 | Acme 6001 Juice Extractor
Salomon SPX Pro Snowboard Binding - Mens Logo
Top Salomon Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Salomon Winter Sport Expert? Answer questions, earn points and help others
