Question about Troy Bilt 5.5hp Self Propelled Mower
How much oil do I put into 11A-B29Q711 - Troy Bilt 5.5hp Self Propelled Mower
What kind of oil do you put in briggs and stratton lawn mower 450
generally, all B&S engines use SAE30 oil, however your local temperature range may make this an unwise choice. Google B&S Oil Chart
Jun 17, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
Do i put an oil/gas mixture in gas tank?
the 4 stroke engine only needs petrol in its tank . if your motor has a dipstick for oil it is a four stroke ,,only two strokes requires oil and petrol mix as they have no oil sump in their design
Jun 01, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
11a b29q711 wont stay running
how long does it run for? 5 seconds?? 5 minutes??
May 01, 2014 | Garden
How to change oil on 158cc briggs
remove oil check stick,Tilt it over and let it run out of the hole. New tech,lol.
Oct 26, 2012 | Yard Machines 158cc Push Lawn Mower #11a...
How to change oil on mtd(11a-549r729)
i find the best way to change it is to run it out of gas then tip it on the side and drain it from the dip stick tube
Jul 27, 2012 | Garden
I have a Murray 6.0 hp 20 inch push lawn mower. How much oil do I put in when changing oil.
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
May 20, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Mike
Jul 10, 2009 | Mtd 22" Yard Machine Push Mower
Need to know how to change the oil in my Honda w/Troy Bilt motor 11A-542q711 w/overhead cam GCV 160.
take out the drain plug under the lawn mower drain it put the plug back fill it with oil then you done
Jun 06, 2009 | Garden
Oil
usually straight weight, either SAE 20 or 30 weight.
Aug 31, 2008 | Yard Machines 158cc Push Lawn Mower #11a...
Troy Bilt 5.5hp Self Propelled Mower Logo
293 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
