Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
A
Anonymous Posted on May 05, 2013
Ps2 controller wiring diagram
When i open my ps2 the controller starts vibrating and won't stop the controller has a cut in the wire to connect to the game
5 Related Answers
Anonymous
  • 466 Answers
  • Posted on Mar 15, 2010
SOURCE: can cut the end of a ps2 controller and wire it to
Electrically, yes, you can. But you need several extra components because the protocol isn't USB; you can find a PS2 diagram here
http://www.wiringdiagrams21.com/2009/11/21/playstation-2-controller-cable-connector-pinout-diagram
and the electric scheme of a converter here
http://www.zen35383.zen.co.uk/stnield/usb2psx.gif
Ready-made adaptors which save both the hassle of cutting and soldering, and the risk of soldering it wrong (you can fry a motherboard with this trick) are available for around US$ 5 - US$ 7 on eBay.
Anonymous
  • 30 Answers
  • Posted on Jul 22, 2011
SOURCE: My PS2 controller isn't working
That's probably the issue. If it isn't even being detected then 9 times out of 10 it is a broken or unseated wire. You can pick them up at used gaming stores for $5 though. Hope that helps.
Anonymous
  • Posted on Apr 03, 2009
SOURCE: PS2 Controller Wiring Diagram
heres the diagram
http://www.curiousinventor.com/guides/ps2
Andy
  • 64 Answers
  • Posted on Apr 16, 2009
SOURCE: i want to splice a ps2 contoller with an xbox
As far i know, that is not possible to splice a PS2 controller with an XBOX. As you said they have different wiring sets, so I highly doubt it will work.
crazytony777
  • 257 Answers
  • Posted on Aug 11, 2009
SOURCE: PS2 controller wont work, but it continually vibrates
clean the contacts in the control,, with achol or eraser
Intec Wired Controller for PS2 (need interior photo)
You could just connect random wires and see what happens. Think of it as a nice electronic puzzle.
1998 Honda Accord Won't Start
Park neutral safety switch maybe be the reason for the no crank ! Try putting the vehicle in park ,then try to crank the engine . Testing the electrical circuit is the best way to trouble shoot this problem , along with do a voltage drop test on the starter circuit ! This will test the battery cables an connections .
Starter Voltage Drop
How to voltage drop test starter motor circuit
Does it have a manual or automatic transmission ? Manual ? clutch switch . Looking at a wiring diagram I also see a starter cut relay !
http://www.bbbind.com/free_tsb.html Free wiring diagrams . Enter vehicle info. year , make , model and engine size . Under system click engine , under subsystem click starting . Then click the search button , then click the blue link ! Check the starter cut relay also . Videos on youtube showing how to test a relay controlled circuit !
Emergency power cut now won't start
you cut cord have open circuit.your electrical cord has three wires neutral wire white wire black wires hot wire and bare wire for ground. if you cut either neutral wire or hot black wire in the electrical cord no power can flow to trimmer motor if you cut wire need to fix wire to get trimmer work again.
2answers
Crazy fit won't stop vibrating when it has power to it
1) You must test the switch stop.
see the diagram for to fix it.
1helpful
3answers
THE VIBRATION OF MY PS2 IS NOT WORKING. HOW CAN I LOCATE THE PROBLEM AND SOLVE?
If your ps2 controllers aren't vibrating anymore then this could be the fix that you were waiting for.
WARNING: Make sure that 1) Its not your controller that is broken, test it in a machine that does have vibration. 2) Make sure that the vibration option is turned ON in your games
If you are sure that your controllers aren't broken, then you may have blown a fuse inside your ps2 on your mainboard.
To fix it you have to remove a blown fuse from the ps2 mainboard and either put a new fuse there or replace it with a piece of single strand wire. The point is fairly small so you need a fine tip soldering iron and a single strand of wire. It may be best to get someone who is good at soldering to do this fix for you:
I take no responsibility for anyone breaking their ps2 when performing this fix. All I know is that i've done it and it worked a treat!
You will need;
1) A fine tip soldering iron and some thin solder.
2) A single strand piece of wire, something thin like kynar or enameled wire.
3) A game with vibration function to test the ps2 afterwards.
4) A controller that works with vibration.
Between the power supply connector and the PS9 fuse there is a small black square with 2 silver prongs on the left hand side. This featured on my mainboard as well, and I was able to locate the correct / broken fuse using a multimeter. Look for a fuse with S7 on the top near here, and check for continuity, If there is none then thats the one! One last thing before it goes into full detail;
Check the track between the black square with the silver prongs and the broken fuse, if its on the same track then you can attatch one end of the wire to that prong that is on the same track, and the other side to the end of the fuse opposite of the black square with silver prongs *
This will take bout 10 mins to do - start to finish.
Below tells you how to do it
Below is a description on where and what to look for i.e. the fuse, and how to repair it.
1. I have a V5 PS2
2. Take the PS2 apart.
3. Remove the Power Supply motherboard.
4. After removing the Power Supply Board, you will need to remove the metal shroud and expose the entire PS2 Motherboard.
5. Once you have done this look around the connector for the Power supply board on the PS2 mother board. You will see a number (maybe around 4 of them all located within 2 inches of the Power supply connector) of fuses with "S7" written on it.
6. The one you are looking for has the text "PS9" written on the motherboard next to it.
7. Check it with a multi-meter, for continuity, there will none. If you are not sure, you can check all of them, when the buzzing on multi-meter stops, that's the one.
8. To repair it, use a strand of wire, possibly from an old extension cable or something, but only one strand. Solder it on both sides of the fuse in order to close the connection.
9. Reassemble the PS2.
10. Boot up and play your game, vibration is back.
Hope This Helps
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
My PS2 controller does the same.
its vibrating because it is probably grounded.. check for stuck buttons...try opening it and check the rubber underneath the keys
2answers
I want to splice a ps2 contoller with an xbox plug, so i can play my xbox with the comfort of my ps2 controller. but my ps2 controller has 8 wires and xbox only has 5 wires, so i need to get a wiring...
1helpful
2answers
How to check terminals on a dualshock2 ps2 controller
does it stop working?or stopped vibrating?if the vibration stopped then wire connecting to the rotating motor is detached this is the common problem with dual shock because of constant vibration.Solution is to open the controller and connect the loose wire,dust is also a big factor if buttons are already not responding so try also to remove accumulated dust on the button touch board.
18helpful
6answers
heres the diagram
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
