Question about Juicers
My Milex juicer's (model MMJ001) filter/blade is stuck and now I am unable to clean it. It works but I cannot remove it. Any suggestions?
4 Suggested Answers
  • 3 Answers
SOURCE: Jack LaLanne Juicer
Try this site for a manual
http://www.powerjuicer.com/pdf/classic.pdf
Posted on Dec 12, 2008
SOURCE: rival juice extractor model 965
I HAVE LOST THE BOOK AND PAPERWORK TO MY RIVAL JUICE EXTRACTOR MODEL 965. IS IT POSSIBLE TO GET ANOTHER BOOK AND PAPERWORK FOR IT?
Posted on Jul 12, 2009
arthurbau
  • 139 Answers
SOURCE: Hello. I have lost my crescent tool and cannot get
Wear leather gloves or double rubber gloves. Hold on right on top of the sharp blades and turn it. You can also bend a 1/8 th inch diameter thick wire, galvanized or anything metal and insert both ends on the holes on the blades and turn it. Make sure you don't slip your hands on the sharp blades.
Posted on Nov 09, 2009
Juicer modele Despose, type 140.2.03, Unable to remove blade help what to clean it
Did you ever come right with figurinf ths out? I am having the same trouble.
Dec 02, 2013 | Moulinex Juicers
Oct 22, 2009 | Juicers
How do you take the filter and blade off to clean? it came together easily, but having trouble taking it apart...
It should unscrew in the opposite direction that the blade turns. Check the blade direction by momentarily spinning the motor with it's own power (don't touch it!). Once you know which direction it goes, unplug it and turn the blade in the opposite direction to remove.
Aug 19, 2009 | Jack Lalanne Power Juicer 250 Watts
Unable to take juiceman apart to clean
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Tom
Jan 25, 2009 | Salton JM411 Juiceman II Elite Juicer
Jack LaLanne Juicer
Dec 07, 2008 | Jack Lalanne Power Juicer 250 Watts
Jack lalanne juicer, 8 yrs.old model?
I have a Jack LaLanne power juicer model number JLS-8 and lost instruction manual and don't remember how to remove filter basket to clean machine.
rhanson616@cox.net
Sep 08, 2008 | Juicers
Cleaning instructions
Try this. It works for the Stainless Steel juicer as well:
http://www.dooyoo.co.uk/juicer/jack-la-lannes-power-juicer/1055142/
Jul 31, 2008 | Jack Lalanne Power Juicer 250 Watts
Take apart and clean the juicer
ok so i am tryin to take apart my juicer to clean it but i can't find a way to do it. Can u help me?
Dec 04, 2007 | Jack Lalanne Power Juicer 250 Watts
How to clean juicer
i had the same problem and figured out an easy way to open it without the tool. DO NOT take out the screws. I simply used chop sticks. I put one in each small hole and held the chop sticks in an X and turned the top counterclockwise!
Jun 10, 2007 | Jack Lalanne Power Juicer 250 Watts
Juicers Logo
145 people viewed this question
Top Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
