Question about Coffee Makers & Espresso Machines
Wega espresso fault finding
Electronic pad does not work
Im looking to source a wega Mininova espresso machine in SA?
Wega is good, generally, but avoid this Mininova. Tell me if you are looking to a home machine, or for commercial use. Either way, it proved unsuitable. We gave many Mininovas to scrap dealers, having made the mistake of damaging our reputation by promoting them.
Nov 12, 2013 | Wega Mininova EPU Espresso Machine
Need replacement steam wand wega epu 2
wega epu. Commercial machine. I'd check espressoparts.com. Any faema, wega, nouva simonelli wand will screw into the wega valve.
They also have precision wands from japan. Sproline series i believe it is called.
I have no association with the site but i do know that any of the parts Listed will work.
Oct 04, 2013 | Wega Coffee Makers & Espresso Machines
I have a commercial wega double espresso and double frother. The frother works! you can see the fill line filled with water, but the espresso maker is not shooting water, you can hear it work when you...
This issue can happen if the site inlet water pressure falls below 1 bar. The boiler fills but as you draw drinks it won't refill.
Do you service the machine ever and replace the water filter? Limescale build up may be another reason you are experiencing problems.
Trouble shooting guide here
Espresso Maintenance
Sep 29, 2013 | Wega Coffee Makers & Espresso Machines
51 Sony wega won't turn on standby light just
Blinking of standby light are fault indications. To get more details about this fault, vist this site. Type in the site name, either to Google or Yahoo search box and click search. The site is powered by Google. site name is "Electro-help"
Click open the same named site with a hyphen in between words. It is an electronic repair help site.
May 11, 2012 | Sony Televison & Video
Wega Espresso Machine is slow to recover steam pressure
Bad pressurestat or bad heating element. PS feeds power to heating element, heating the machine til its up to pressure, which then turns the pressure stat off. If either of the two pieces are bad neither will work properly.
Could also be the machine is overfilled which causes the machine to take longer to heat up.
Sep 20, 2011 | Wega Mininova EPU Espresso Machine
We have an old Wega model EPU1(grey/burgandy) it is not frothing too well. It is as if there is water diluting the milk and the froth contains very large air bubbles, any ideas on what we we need to do...
i believe, if i am understanding this, as i guess here, when you are frothing the milk, it seems to also fill up faster, like water is not steaming as much as it is filling. As you know, steam is hot water turned into steam, now what is happening the steam is half steam and half water. If this is the symptoms along with air bubble, then it points to O RING replacement, direct water is getting through before it has time to steam, on a commercial type machine, you are better off to have a mobile espresso guy come out in your area, replace the o ring in the wand, and also make sure no other damage has been cause from back water pressure on electronics. I hope this helps, this is a do it yourself job, but would not recommend if you really don't know about guts of the machine and electronics. The computer is the major expense of the machine. Thanks Mike
Jun 12, 2011 | Wega Mininova EPU Espresso Machine
Why isn't the water coming through to make espresso in my wega espresso machine?
Either the shower screen is blocked or the metering jet on the top of the group is blocked.
Aug 22, 2010 | Wega Mininova EPU Espresso Machine
Keypad not working
dear sir
if your air compressor,s key pad is not working then open that key pad box(microcontroller box) and check connecting cable and find any visable fault may be that cable have looseness if it,s loose then make it reconnect and check its if not then try to check its electronics components .and contect to your service provider. hope the question,s answer
thank you
Jul 12, 2010 | Ace Hardware Air Tools & Compressors
Looking 2 reinstate the electronic missing parts so it sautomatic
Yes the autofill is inside the control electronic box . If you know about electronic PCB board you migh need to replace a relay which is welded on the PCB board. Or you have toreplace the whole electronic contraol box which is expensive.
Please remember to vote for a rating for this answer, thanks
Nov 19, 2009 | Astoria Argenta SAE/JUN Espresso Machine
Leaks when filling with water
Check with espressopartsnw, they have a large selection of parts, if you cannot find it under wega look under astoria or rio same machine.
Sep 08, 2009 | Wega Mininova EPU Espresso Machine
Coffee Makers & Espresso Machines Logo
16 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
